root/radiance/ray/src/rt/m_brdf.c
Wed Jan 10 17:45:11 2018 UTC (6 years, 5 months ago) by greg
Diff to previous 2.34 , to selected 2.10
Fixed bug introduced in last change
Wed Jan 10 04:08:50 2018 UTC (6 years, 5 months ago) by greg
Changes since 2.33: +12 -9 lines
Diff to previous 2.33 , to selected 2.10
Made behavior of BRTDfunc more consistent with other materials
Wed Sep 2 18:59:01 2015 UTC (8 years, 9 months ago) by greg
CVS Tags: rad5R0, rad5R1
Changes since 2.32: +4 -2 lines
Diff to previous 2.32 , to selected 2.10
Had to reinstate ambRayInPmap() macro to avoid over-counting bug
Thu Aug 6 16:06:06 2015 UTC (8 years, 10 months ago) by greg
Changes since 2.31: +6 -4 lines
Diff to previous 2.31 , to selected 2.10
Improved error-checking for 0 arguments in place of BRTDfunc direcitonal-diffuse
Sat Jan 25 18:27:39 2014 UTC (10 years, 4 months ago) by greg
Changes since 2.30: +2 -3 lines
Diff to previous 2.30 , to selected 2.10
Wed Aug 7 05:10:09 2013 UTC (10 years, 10 months ago) by greg
Diff to previous 2.29 , to selected 2.10
Wed Mar 20 23:07:51 2013 UTC (11 years, 2 months ago) by greg
Changes since 2.28: +3 -3 lines
Diff to previous 2.28 , to selected 2.10
Corrected comments
Sun Jul 29 21:56:16 2012 UTC (11 years, 10 months ago) by greg
Changes since 2.27: +14 -15 lines
Diff to previous 2.27 , to selected 2.10
Bug fixes in Ashikhmin-Shirley and code cleanup
Mon Oct 25 22:57:45 2010 UTC (13 years, 7 months ago) by greg
Changes since 2.26: +4 -5 lines
Diff to previous 2.26 , to selected 2.10
Sun Sep 26 15:51:15 2010 UTC (13 years, 8 months ago) by greg
Changes since 2.25: +2 -1 lines
Diff to previous 2.25 , to selected 2.10
Fri Sep 7 15:25:01 2007 UTC (16 years, 9 months ago) by greg
CVS Tags: rad3R9, rad4R0
Changes since 2.24: +4 -4 lines
Diff to previous 2.24 , to selected 2.10
Minor efficiency improvements
Wed Aug 22 21:21:51 2007 UTC (16 years, 9 months ago) by greg
Changes since 2.23: +5 -3 lines
Diff to previous 2.23 , to selected 2.10
Added check for '0' green directional-diffuse function in BRTDfunc
Changes since 2.22: +13 -13 lines
Diff to previous 2.22 , to selected 2.10
Thu Sep 9 15:40:02 2004 UTC (19 years, 9 months ago) by greg
Changes since 2.21: +25 -11 lines
Diff to previous 2.21 , to selected 2.10
Fixed effective ray length for rays reflected from BRTDfunc
Changes since 2.20: +28 -21 lines
Diff to previous 2.20 , to selected 2.10
Thu Aug 28 03:22:16 2003 UTC (20 years, 9 months ago) by greg
Changes since 2.19: +3 -1 lines
Diff to previous 2.19 , to selected 2.10
Created proper prototypes for function pointers and included missing headers
Changes since 2.18: +7 -7 lines
Diff to previous 2.18 , to selected 2.10
Wed Mar 5 16:16:53 2003 UTC (21 years, 3 months ago) by greg
Diff to previous 2.17 , to selected 2.10
Mon Mar 3 00:10:51 2003 UTC (21 years, 3 months ago) by greg
Diff to previous 2.16 , to selected 2.10
Changed call order for proper function of two-sided, textured surfaces
Changes since 2.15: +1 -56 lines
Diff to previous 2.15 , to selected 2.10
Changes since 2.14: +74 -23 lines
Wed Nov 22 09:27:53 1995 UTC (28 years, 6 months ago) by greg
Changes since 2.13: +20 -5 lines
fixed problem with back side normal computation for ambient()
Mon Nov 6 12:03:22 1995 UTC (28 years, 7 months ago) by greg
Changes since 2.12: +5 -5 lines
added texturing to ambient value computation using extambient()
Wed May 17 17:31:39 1995 UTC (29 years, 1 month ago) by greg
Changes since 2.11: +10 -9 lines
added solid angle to passed function parameters
Wed Dec 21 09:51:46 1994 UTC (29 years, 5 months ago) by greg
Changes since 2.10: +11 -3 lines
added -bv option for back face visibility (normally on)
Wed Jan 12 16:46:35 1994 UTC (30 years, 5 months ago) by greg
Changes since 2.9: +6 -2 lines
Thu Nov 18 09:43:04 1993 UTC (30 years, 6 months ago) by greg
Changes since 2.8: +0 -1 lines
minor compiler warning fixes
Tue Aug 24 12:59:25 1993 UTC (30 years, 9 months ago) by greg
fixed potential use of unassigned transdist when bright(r->rcol)<0
Thu Aug 12 17:50:40 1993 UTC (30 years, 10 months ago) by greg
Changes since 2.6: +6 -3 lines
added source direction to data value function parameters
Thu May 27 15:28:01 1993 UTC (31 years ago) by greg
Changes since 2.5: +175 -121 lines
removed approximation to Fresnel reflection, since the direct
component was not being calculated accordingly (BRDF not bidirectional)
changed BRDTfunc arguments and operation, fixed one or two bugs there also
Thu May 20 10:08:24 1993 UTC (31 years ago) by greg
BRTDfunc no longer reorients surface
Wed Oct 14 12:30:54 1992 UTC (31 years, 8 months ago) by greg
*** empty log message ***
Tue Jun 30 18:28:22 1992 UTC (31 years, 11 months ago) by greg
Changes since 2.2: +7 -7 lines
fixed bug associated with -DSMLFLT option
Mon Nov 25 09:51:03 1991 UTC (32 years, 6 months ago) by greg
Changes since 2.1: +18 -25 lines
Tue Nov 12 17:09:08 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.16 , to selected 2.10
Mon Aug 12 08:20:53 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.15: +2 -1 lines
Diff to previous 1.15 , to selected 2.10
fixed source tracing
Thu Aug 8 11:30:01 1991 UTC (32 years, 10 months ago) by greg
Changes since 1.14: +3 -6 lines
Diff to previous 1.14 , to selected 2.10
added contexts to function files
Tue Jul 16 16:45:55 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.13: +1 -2 lines
Diff to previous 1.13 , to selected 2.10
removed rspec and tspec from ideal specular components
Wed Jul 10 09:35:26 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.12: +11 -15 lines
Diff to previous 1.12 , to selected 2.10
changed computation of diffuse ambient
Fri Jun 28 10:04:02 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.11: +6 -6 lines
Diff to previous 1.11 , to selected 2.10
small correction in argument ordering
Tue Jun 18 08:59:55 1991 UTC (33 years ago) by greg
Changes since 1.10: +2 -1 lines
Diff to previous 1.10 , to selected 2.10
put in test to guarantee range of dot product as [-1,1]
Mon Jun 17 08:53:58 1991 UTC (33 years ago) by greg
Changes since 1.9: +22 -11 lines
Diff to previous 1.9 , to selected 2.10
fixed potential bug in setting of variables
Thu Jun 13 13:58:16 1991 UTC (33 years ago) by greg
Changes since 1.8: +0 -1 lines
Diff to previous 1.8 , to selected 2.10
Fri May 10 08:51:02 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.7: +3 -1 lines
Diff to previous 1.7 , to selected 2.10
fixed bug introduced by better trans distance comp.
Wed May 8 08:27:50 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.6: +18 -7 lines
Diff to previous 1.6 , to selected 2.10
fixed code for determining when to use trans distance
Tue May 7 17:45:47 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.5: +20 -26 lines
Diff to previous 1.5 , to selected 2.10
changed trans types to modify transmitted color
and added perturbation to transmitted ray direction
Tue May 7 17:19:52 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.4: +212 -54 lines
Diff to previous 1.4 , to selected 2.10
added MAT_TFUNC, MAT_TDATA and MAT_BRTDF types
Sat Dec 15 15:03:44 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.3: +13 -7 lines
Diff to previous 1.3 , to selected 2.10
Fri Dec 14 21:57:59 1990 UTC (33 years, 6 months ago) by greg
Changes since 1.2: +0 -7 lines
Diff to previous 1.2 , to selected 2.10
removed Fresnel approximation for specularity
Wed Dec 12 22:35:07 1990 UTC (33 years, 6 months ago) by greg
Diff to previous 1.1 , to selected 2.10
added missing declaration of funvalue()
Wed Dec 12 22:02:58 1990 UTC (33 years, 6 months ago) by greg
Diff to selected 2.10
