root/radiance/ray/src/rt/m_brdf.c
Revision: 2.21
Committed: Tue Mar 30 16:13:01 2004 UTC (21 years, 3 months ago) by schorsch
Changes since 2.20: +28 -21 lines
2 static const char RCSid[] = "$Id: m_brdf.c,v 2.20 2003/08/28 03:22:16 greg Exp $";
5 * Shading for materials with arbitrary BRDF's
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "ambient.h"
12 #include "data.h"
13 #include "source.h"
14 #include "otypes.h"
15 #include "rtotypes.h"
16 #include "func.h"
17
18 /*
19 * Arguments to this material include the color and specularity.
20 * String arguments include the reflection function and files.
21 * The BRDF is currently used just for the specular component to light
22 * sources. Reflectance values or data coordinates are functions
23 * of the direction to the light source. (Data modification functions
24 * are passed the source direction as args 2-4.)
25 * We orient the surface towards the incoming ray, so a single
26 * surface can be used to represent an infinitely thin object.
27 *
28 * Arguments for MAT_PFUNC and MAT_MFUNC are:
29 * 2+ func funcfile transform
30 * 0
31 * 4+ red grn blu specularity A5 ..
32 *
33 * Arguments for MAT_PDATA and MAT_MDATA are:
34 * 4+ func datafile funcfile v0 .. transform
35 * 0
36 * 4+ red grn blu specularity A5 ..
37 *
38 * Arguments for MAT_TFUNC are:
39 * 2+ func funcfile transform
40 * 0
41 * 4+ red grn blu rspec trans tspec A7 ..
42 *
43 * Arguments for MAT_TDATA are:
44 * 4+ func datafile funcfile v0 .. transform
45 * 0
46 * 4+ red grn blu rspec trans tspec A7 ..
47 *
48 * Arguments for the more general MAT_BRTDF are:
49 * 10+ rrefl grefl brefl
50 * rtrns gtrns btrns
51 * rbrtd gbrtd bbrtd
52 * funcfile transform
53 * 0
54 * 9+ rdf gdf bdf
55 * rdb gdb bdb
56 * rdt gdt bdt A10 ..
57 *
58 * In addition to the normal variables available to functions,
59 * we define the following:
60 * NxP, NyP, NzP - perturbed surface normal
61 * RdotP - perturbed ray dot product
62 * CrP, CgP, CbP - perturbed material color (or pattern)
63 */
64
65 typedef struct {
66 OBJREC *mp; /* material pointer */
67 RAY *pr; /* intersected ray */
68 DATARRAY *dp; /* data array for PDATA, MDATA or TDATA */
69 COLOR mcolor; /* material (or pattern) color */
70 COLOR rdiff; /* diffuse reflection */
71 COLOR tdiff; /* diffuse transmission */
72 double rspec; /* specular reflectance (1 for BRDTF) */
73 double trans; /* transmissivity (.5 for BRDTF) */
74 double tspec; /* specular transmittance (1 for BRDTF) */
75 FVECT pnorm; /* perturbed surface normal */
76 double pdot; /* perturbed dot product */
77 } BRDFDAT; /* BRDF material data */
78
79
80 static srcdirf_t dirbrdf;
81 static int setbrdfunc(BRDFDAT *np);
82
83
84 static void
85 dirbrdf( /* compute source contribution */
86 COLOR cval, /* returned coefficient */
87 void *nnp, /* material data */
88 FVECT ldir, /* light source direction */
89 double omega /* light source size */
90 )
91 {
92 register BRDFDAT *np = nnp;
93 double ldot;
94 double dtmp;
95 COLOR ctmp;
96 FVECT ldx;
97 static double vldx[5], pt[MAXDIM];
98 register char **sa;
99 register int i;
100 #define lddx (vldx+1)
101
102 setcolor(cval, 0.0, 0.0, 0.0);
103
104 ldot = DOT(np->pnorm, ldir);
105
106 if (ldot <= FTINY && ldot >= -FTINY)
107 return; /* too close to grazing */
108
109 if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY)
110 return; /* wrong side */
111
112 if (ldot > 0.0) {
113 /*
114 * Compute and add diffuse reflected component to returned
115 * color. The diffuse reflected component will always be
116 * modified by the color of the material.
117 */
118 copycolor(ctmp, np->rdiff);
119 dtmp = ldot * omega / PI;
120 scalecolor(ctmp, dtmp);
121 addcolor(cval, ctmp);
122 } else {
123 /*
124 * Diffuse transmitted component.
125 */
126 copycolor(ctmp, np->tdiff);
127 dtmp = -ldot * omega / PI;
128 scalecolor(ctmp, dtmp);
129 addcolor(cval, ctmp);
130 }
131 if (ldot > 0.0 ? np->rspec <= FTINY : np->tspec <= FTINY)
132 return; /* no specular component */
133 /* set up function */
134 setbrdfunc(np);
135 sa = np->mp->oargs.sarg;
136 errno = 0;
137 /* transform light vector */
138 multv3(ldx, ldir, funcxf.xfm);
139 for (i = 0; i < 3; i++)
140 lddx[i] = ldx[i]/funcxf.sca;
141 lddx[3] = omega;
142 /* compute BRTDF */
143 if (np->mp->otype == MAT_BRTDF) {
144 if (sa[6][0] == '0') /* special case */
145 colval(ctmp,RED) = 0.0;
146 else
147 colval(ctmp,RED) = funvalue(sa[6], 4, lddx);
148 if (!strcmp(sa[7],sa[6]))
149 colval(ctmp,GRN) = colval(ctmp,RED);
150 else
151 colval(ctmp,GRN) = funvalue(sa[7], 4, lddx);
152 if (!strcmp(sa[8],sa[6]))
153 colval(ctmp,BLU) = colval(ctmp,RED);
154 else if (!strcmp(sa[8],sa[7]))
155 colval(ctmp,BLU) = colval(ctmp,GRN);
156 else
157 colval(ctmp,BLU) = funvalue(sa[8], 4, lddx);
158 dtmp = bright(ctmp);
159 } else if (np->dp == NULL) {
160 dtmp = funvalue(sa[0], 4, lddx);
161 setcolor(ctmp, dtmp, dtmp, dtmp);
162 } else {
163 for (i = 0; i < np->dp->nd; i++)
164 pt[i] = funvalue(sa[3+i], 4, lddx);
165 vldx[0] = datavalue(np->dp, pt);
166 dtmp = funvalue(sa[0], 5, vldx);
167 setcolor(ctmp, dtmp, dtmp, dtmp);
168 }
169 if (errno == EDOM || errno == ERANGE) {
170 objerror(np->mp, WARNING, "compute error");
171 return;
172 }
173 if (dtmp <= FTINY)
174 return;
175 if (ldot > 0.0) {
176 /*
177 * Compute reflected non-diffuse component.
178 */
179 if ((np->mp->otype == MAT_MFUNC) | (np->mp->otype == MAT_MDATA))
180 multcolor(ctmp, np->mcolor);
181 dtmp = ldot * omega * np->rspec;
182 scalecolor(ctmp, dtmp);
183 addcolor(cval, ctmp);
184 } else {
185 /*
186 * Compute transmitted non-diffuse component.
187 */
188 if ((np->mp->otype == MAT_TFUNC) | (np->mp->otype == MAT_TDATA))
189 multcolor(ctmp, np->mcolor);
190 dtmp = -ldot * omega * np->tspec;
191 scalecolor(ctmp, dtmp);
192 addcolor(cval, ctmp);
193 }
194 #undef lddx
195 }
196
197
198 extern int
199 m_brdf( /* color a ray that hit a BRDTfunc material */
200 register OBJREC *m,
201 register RAY *r
202 )
203 {
204 int hitfront = 1;
205 BRDFDAT nd;
206 RAY sr;
207 double transtest, transdist;
208 int hasrefl, hastrans;
209 COLOR ctmp;
210 FVECT vtmp;
211 register MFUNC *mf;
212 register int i;
213 /* check arguments */
214 if ((m->oargs.nsargs < 10) | (m->oargs.nfargs < 9))
215 objerror(m, USER, "bad # arguments");
216 nd.mp = m;
217 nd.pr = r;
218 /* dummy values */
219 nd.rspec = nd.tspec = 1.0;
220 nd.trans = 0.5;
221 /* diffuse reflectance */
222 if (r->rod > 0.0)
223 setcolor(nd.rdiff, m->oargs.farg[0],
224 m->oargs.farg[1],
225 m->oargs.farg[2]);
226 else
227 setcolor(nd.rdiff, m->oargs.farg[3],
228 m->oargs.farg[4],
229 m->oargs.farg[5]);
230 /* diffuse transmittance */
231 setcolor(nd.tdiff, m->oargs.farg[6],
232 m->oargs.farg[7],
233 m->oargs.farg[8]);
234 /* get modifiers */
235 raytexture(r, m->omod);
236 nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */
237 if (r->rod < 0.0) { /* orient perturbed values */
238 nd.pdot = -nd.pdot;
239 for (i = 0; i < 3; i++) {
240 nd.pnorm[i] = -nd.pnorm[i];
241 r->pert[i] = -r->pert[i];
242 }
243 hitfront = 0;
244 }
245 copycolor(nd.mcolor, r->pcol); /* get pattern color */
246 multcolor(nd.rdiff, nd.mcolor); /* modify diffuse values */
247 multcolor(nd.tdiff, nd.mcolor);
248 hasrefl = bright(nd.rdiff) > FTINY;
249 hastrans = bright(nd.tdiff) > FTINY;
250 /* load cal file */
251 nd.dp = NULL;
252 mf = getfunc(m, 9, 0x3f, 0);
253 /* compute transmitted ray */
254 setbrdfunc(&nd);
255 transtest = 0;
256 transdist = r->rot;
257 errno = 0;
258 setcolor(ctmp, evalue(mf->ep[3]),
259 evalue(mf->ep[4]),
260 evalue(mf->ep[5]));
261 if (errno == EDOM || errno == ERANGE)
262 objerror(m, WARNING, "compute error");
263 else if (rayorigin(&sr, r, TRANS, bright(ctmp)) == 0) {
264 if (!(r->crtype & SHADOW) &&
265 DOT(r->pert,r->pert) > FTINY*FTINY) {
266 for (i = 0; i < 3; i++) /* perturb direction */
267 sr.rdir[i] = r->rdir[i] - .75*r->pert[i];
268 if (normalize(sr.rdir) == 0.0) {
269 objerror(m, WARNING, "illegal perturbation");
270 VCOPY(sr.rdir, r->rdir);
271 }
272 } else {
273 VCOPY(sr.rdir, r->rdir);
274 transtest = 2;
275 }
276 rayvalue(&sr);
277 multcolor(sr.rcol, ctmp);
278 addcolor(r->rcol, sr.rcol);
279 transtest *= bright(sr.rcol);
280 transdist = r->rot + sr.rt;
281 }
282 if (r->crtype & SHADOW) /* the rest is shadow */
283 return(1);
284 /* compute reflected ray */
285 setbrdfunc(&nd);
286 errno = 0;
287 setcolor(ctmp, evalue(mf->ep[0]),
288 evalue(mf->ep[1]),
289 evalue(mf->ep[2]));
290 if (errno == EDOM || errno == ERANGE)
291 objerror(m, WARNING, "compute error");
292 else if (rayorigin(&sr, r, REFLECTED, bright(ctmp)) == 0) {
293 for (i = 0; i < 3; i++)
294 sr.rdir[i] = r->rdir[i] + 2.0*nd.pdot*nd.pnorm[i];
295 rayvalue(&sr);
296 multcolor(sr.rcol, ctmp);
297 addcolor(r->rcol, sr.rcol);
298 }
299 /* compute ambient */
300 if (hasrefl) {
301 if (!hitfront)
302 flipsurface(r);
303 ambient(ctmp, r, nd.pnorm);
304 multcolor(ctmp, nd.rdiff);
305 addcolor(r->rcol, ctmp); /* add to returned color */
306 if (!hitfront)
307 flipsurface(r);
308 }
309 if (hastrans) { /* from other side */
310 if (hitfront)
311 flipsurface(r);
312 vtmp[0] = -nd.pnorm[0];
313 vtmp[1] = -nd.pnorm[1];
314 vtmp[2] = -nd.pnorm[2];
315 ambient(ctmp, r, vtmp);
316 multcolor(ctmp, nd.tdiff);
317 addcolor(r->rcol, ctmp);
318 if (hitfront)
319 flipsurface(r);
320 }
321 if (hasrefl | hastrans || m->oargs.sarg[6][0] != '0')
322 direct(r, dirbrdf, &nd); /* add direct component */
323 /* check distance */
324 if (transtest > bright(r->rcol))
325 r->rt = transdist;
326
327 return(1);
328 }
329
330
331
332 extern int
333 m_brdf2( /* color a ray that hit a BRDF material */
334 register OBJREC *m,
335 register RAY *r
336 )
337 {
338 BRDFDAT nd;
339 COLOR ctmp;
340 FVECT vtmp;
341 double dtmp;
342 /* always a shadow */
343 if (r->crtype & SHADOW)
344 return(1);
345 /* check arguments */
346 if ((m->oargs.nsargs < (hasdata(m->otype)?4:2)) | (m->oargs.nfargs <
347 ((m->otype==MAT_TFUNC)|(m->otype==MAT_TDATA)?6:4)))
348 objerror(m, USER, "bad # arguments");
349 /* check for back side */
350 if (r->rod < 0.0) {
351 if (!backvis && m->otype != MAT_TFUNC
352 && m->otype != MAT_TDATA) {
353 raytrans(r);
354 return(1);
355 }
356 raytexture(r, m->omod);
357 flipsurface(r); /* reorient if backvis */
358 } else
359 raytexture(r, m->omod);
360
361 nd.mp = m;
362 nd.pr = r;
363 /* get material color */
364 setcolor(nd.mcolor, m->oargs.farg[0],
365 m->oargs.farg[1],
366 m->oargs.farg[2]);
367 /* get specular component */
368 nd.rspec = m->oargs.farg[3];
369 /* compute transmittance */
370 if ((m->otype == MAT_TFUNC) | (m->otype == MAT_TDATA)) {
371 nd.trans = m->oargs.farg[4]*(1.0 - nd.rspec);
372 nd.tspec = nd.trans * m->oargs.farg[5];
373 dtmp = nd.trans - nd.tspec;
374 setcolor(nd.tdiff, dtmp, dtmp, dtmp);
375 } else {
376 nd.tspec = nd.trans = 0.0;
377 setcolor(nd.tdiff, 0.0, 0.0, 0.0);
378 }
379 /* compute reflectance */
380 dtmp = 1.0 - nd.trans - nd.rspec;
381 setcolor(nd.rdiff, dtmp, dtmp, dtmp);
382 nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */
383 multcolor(nd.mcolor, r->pcol); /* modify material color */
384 multcolor(nd.rdiff, nd.mcolor);
385 multcolor(nd.tdiff, nd.mcolor);
386 /* load auxiliary files */
387 if (hasdata(m->otype)) {
388 nd.dp = getdata(m->oargs.sarg[1]);
389 getfunc(m, 2, 0, 0);
390 } else {
391 nd.dp = NULL;
392 getfunc(m, 1, 0, 0);
393 }
394 /* compute ambient */
395 if (nd.trans < 1.0-FTINY) {
396 ambient(ctmp, r, nd.pnorm);
397 scalecolor(ctmp, 1.0-nd.trans);
398 multcolor(ctmp, nd.mcolor); /* modified by material color */
399 addcolor(r->rcol, ctmp); /* add to returned color */
400 }
401 if (nd.trans > FTINY) { /* from other side */
402 flipsurface(r);
403 vtmp[0] = -nd.pnorm[0];
404 vtmp[1] = -nd.pnorm[1];
405 vtmp[2] = -nd.pnorm[2];
406 ambient(ctmp, r, vtmp);
407 scalecolor(ctmp, nd.trans);
408 multcolor(ctmp, nd.mcolor);
409 addcolor(r->rcol, ctmp);
410 flipsurface(r);
411 }
412 /* add direct component */
413 direct(r, dirbrdf, &nd);
414
415 return(1);
416 }
417
418
419 static int
420 setbrdfunc( /* set up brdf function and variables */
421 register BRDFDAT *np
422 )
423 {
424 FVECT vec;
425
426 if (setfunc(np->mp, np->pr) == 0)
427 return(0); /* it's OK, setfunc says we're done */
428 /* else (re)assign special variables */
429 multv3(vec, np->pnorm, funcxf.xfm);
430 varset("NxP", '=', vec[0]/funcxf.sca);
431 varset("NyP", '=', vec[1]/funcxf.sca);
432 varset("NzP", '=', vec[2]/funcxf.sca);
433 varset("RdotP", '=', np->pdot <= -1.0 ? -1.0 :
434 np->pdot >= 1.0 ? 1.0 : np->pdot);
435 varset("CrP", '=', colval(np->mcolor,RED));
436 varset("CgP", '=', colval(np->mcolor,GRN));
437 varset("CbP", '=', colval(np->mcolor,BLU));
438 return(1);
439 }
