--- ray/src/rt/m_brdf.c 1990/12/12 22:35:07 1.2 +++ ray/src/rt/m_brdf.c 1991/06/18 08:59:55 1.11 @@ -1,4 +1,4 @@ -/* Copyright (c) 1990 Regents of the University of California */ +/* Copyright (c) 1991 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -24,28 +24,53 @@ static char SCCSid[] = "$SunId$ LBL"; * surface can be used to represent an infinitely thin object. * * Arguments for MAT_PFUNC and MAT_MFUNC are: - * 2+ func funcfile transform .. + * 2+ func funcfile transform * 0 - * 4+ red grn blu specularity args .. + * 4+ red grn blu specularity A5 .. * * Arguments for MAT_PDATA and MAT_MDATA are: - * 4+ func datafile funcfile v0 .. transform .. + * 4+ func datafile funcfile v0 .. transform * 0 - * 4+ red grn blu specularity args .. + * 4+ red grn blu specularity A5 .. + * + * Arguments for MAT_TFUNC are: + * 2+ func funcfile transform + * 0 + * 4+ red grn blu rspec trans tspec A7 .. + * + * Arguments for MAT_TDATA are: + * 4+ func datafile funcfile v0 .. transform + * 0 + * 4+ red grn blu rspec trans tspec A7 .. + * + * Arguments for the more general MAT_BRTDF are: + * 10+ rrefl grefl brefl + * rtrns gtrns btrns + * rbrtd gbrtd bbrtd + * funcfile transform + * 0 + * 6+ red grn blu rspec trans tspec A7 .. + * + * In addition to the normal variables available to functions, + * we define the following: + * NxP, NyP, NzP - perturbed surface normal + * RdotP - perturbed ray dot product + * CrP, CgP, CbP - perturbed material color */ extern double funvalue(), varvalue(); +extern XF funcxf; -#define BSPEC(m) (6.0) /* specular parameter b */ - typedef struct { OBJREC *mp; /* material pointer */ RAY *pr; /* intersected ray */ - DATARRAY *dp; /* data array for PDATA or MDATA */ + DATARRAY *dp; /* data array for PDATA, MDATA or TDATA */ COLOR mcolor; /* color of this material */ - COLOR scolor; /* color of specular component */ double rspec; /* specular reflection */ double rdiff; /* diffuse reflection */ + double trans; /* transmissivity */ + double tspec; /* specular transmission */ + double tdiff; /* diffuse transmission */ FVECT pnorm; /* perturbed surface normal */ double pdot; /* perturbed dot product */ } BRDFDAT; /* BRDF material data */ @@ -60,17 +85,21 @@ double omega; /* light source size */ double ldot; double dtmp; COLOR ctmp; + FVECT ldx; double pt[MAXDIM]; + register char **sa; register int i; setcolor(cval, 0.0, 0.0, 0.0); ldot = DOT(np->pnorm, ldir); - if (ldot < 0.0) + if (ldot <= FTINY && ldot >= -FTINY) + return; /* too close to grazing */ + if (ldot < 0.0 ? np->trans <= FTINY : np->trans >= 1.0-FTINY) return; /* wrong side */ - if (np->rdiff > FTINY) { + if (ldot > 0.0 && np->rdiff > FTINY) { /* * Compute and add diffuse reflected component to returned * color. The diffuse reflected component will always be @@ -81,30 +110,72 @@ double omega; /* light source size */ scalecolor(ctmp, dtmp); addcolor(cval, ctmp); } - if (np->rspec > FTINY) { + if (ldot < 0.0 && np->tdiff > FTINY) { /* - * Compute specular component. + * Diffuse transmitted component. */ - setfunc(np->mp, np->pr); - errno = 0; - if (np->dp == NULL) - dtmp = funvalue(np->mp->oargs.sarg[0], 3, ldir); - else { - for (i = 0; i < np->dp->nd; i++) - pt[i] = funvalue(np->mp->oargs.sarg[3+i], - 3, ldir); - dtmp = datavalue(np->dp, pt); - dtmp = funvalue(np->mp->oargs.sarg[0], 1, &dtmp); - } - if (errno) - goto computerr; - if (dtmp > FTINY) { - copycolor(ctmp, np->scolor); - dtmp *= ldot * omega; - scalecolor(ctmp, dtmp); - addcolor(cval, ctmp); - } + copycolor(ctmp, np->mcolor); + dtmp = -ldot * omega * np->tdiff / PI; + scalecolor(ctmp, dtmp); + addcolor(cval, ctmp); } + if (ldot > 0.0 ? np->rspec <= FTINY : np->tspec <= FTINY) + return; /* no specular component */ + /* set up function */ + setbrdfunc(np); + sa = np->mp->oargs.sarg; + errno = 0; + /* transform light vector */ + multv3(ldx, ldir, funcxf.xfm); + for (i = 0; i < 3; i++) + ldx[i] /= funcxf.sca; + /* compute BRTDF */ + if (np->mp->otype == MAT_BRTDF) { + colval(ctmp,RED) = funvalue(sa[6], 3, ldx); + if (!strcmp(sa[7],sa[6])) + colval(ctmp,GRN) = colval(ctmp,RED); + else + colval(ctmp,GRN) = funvalue(sa[7], 3, ldx); + if (!strcmp(sa[8],sa[6])) + colval(ctmp,BLU) = colval(ctmp,RED); + else if (!strcmp(sa[8],sa[7])) + colval(ctmp,BLU) = colval(ctmp,GRN); + else + colval(ctmp,BLU) = funvalue(sa[8], 3, ldx); + dtmp = bright(ctmp); + } else if (np->dp == NULL) { + dtmp = funvalue(sa[0], 3, ldx); + setcolor(ctmp, dtmp, dtmp, dtmp); + } else { + for (i = 0; i < np->dp->nd; i++) + pt[i] = funvalue(sa[3+i], 3, ldx); + dtmp = datavalue(np->dp, pt); + dtmp = funvalue(sa[0], 1, &dtmp); + setcolor(ctmp, dtmp, dtmp, dtmp); + } + if (errno) + goto computerr; + if (dtmp <= FTINY) + return; + if (ldot > 0.0) { + /* + * Compute reflected non-diffuse component. + */ + if (np->mp->otype == MAT_MFUNC || np->mp->otype == MAT_MDATA) + multcolor(ctmp, np->mcolor); + dtmp = ldot * omega * np->rspec; + scalecolor(ctmp, dtmp); + addcolor(cval, ctmp); + } else { + /* + * Compute transmitted non-diffuse component. + */ + if (np->mp->otype == MAT_TFUNC || np->mp->otype == MAT_TDATA) + multcolor(ctmp, np->mcolor); + dtmp = -ldot * omega * np->tspec; + scalecolor(ctmp, dtmp); + addcolor(cval, ctmp); + } return; computerr: objerror(np->mp, WARNING, "compute error"); @@ -116,20 +187,59 @@ m_brdf(m, r) /* color a ray which hit a BRDF materia register OBJREC *m; register RAY *r; { + int minsa, minfa; BRDFDAT nd; - double dtmp; + double transtest, transdist; COLOR ctmp; + double dtmp; register int i; - - if (m->oargs.nsargs < 2 || m->oargs.nfargs < 4) + /* check arguments */ + switch (m->otype) { + case MAT_PFUNC: case MAT_MFUNC: + minsa = 2; minfa = 4; break; + case MAT_PDATA: case MAT_MDATA: + minsa = 4; minfa = 4; break; + case MAT_TFUNC: + minsa = 2; minfa = 6; break; + case MAT_TDATA: + minsa = 4; minfa = 6; break; + case MAT_BRTDF: + minsa = 10; minfa = 6; break; + } + if (m->oargs.nsargs < minsa || m->oargs.nfargs < minfa) objerror(m, USER, "bad # arguments"); - /* easy shadow test */ - if (r->crtype & SHADOW) - return; nd.mp = m; nd.pr = r; + /* get specular component */ + nd.rspec = m->oargs.farg[3]; + /* compute transmission */ + if (m->otype == MAT_TFUNC || m->otype == MAT_TDATA + || m->otype == MAT_BRTDF) { + nd.trans = m->oargs.farg[4]*(1.0 - nd.rspec); + nd.tspec = nd.trans * m->oargs.farg[5]; + nd.tdiff = nd.trans - nd.tspec; + } else + nd.tdiff = nd.tspec = nd.trans = 0.0; + /* early shadow check */ + if (r->crtype & SHADOW && (m->otype != MAT_BRTDF || nd.tspec <= FTINY)) + return; + /* diffuse reflection */ + nd.rdiff = 1.0 - nd.trans - nd.rspec; + /* get material color */ + setcolor(nd.mcolor, m->oargs.farg[0], + m->oargs.farg[1], + m->oargs.farg[2]); + /* fix orientation */ + if (r->rod < 0.0) + flipsurface(r); + /* get modifiers */ + raytexture(r, m->omod); + nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */ + multcolor(nd.mcolor, r->pcol); /* modify material color */ + transtest = 0; /* load auxiliary files */ - if (m->otype == MAT_PDATA || m->otype == MAT_MDATA) { + if (m->otype == MAT_PDATA || m->otype == MAT_MDATA + || m->otype == MAT_TDATA) { nd.dp = getdata(m->oargs.sarg[1]); for (i = 3; i < m->oargs.nsargs; i++) if (m->oargs.sarg[i][0] == '-') @@ -138,47 +248,112 @@ register RAY *r; objerror(m, USER, "dimension error"); if (!fundefined(m->oargs.sarg[3])) loadfunc(m->oargs.sarg[2]); + } else if (m->otype == MAT_BRTDF) { + nd.dp = NULL; + if (!fundefined(m->oargs.sarg[7])) + loadfunc(m->oargs.sarg[9]); } else { nd.dp = NULL; if (!fundefined(m->oargs.sarg[0])) loadfunc(m->oargs.sarg[1]); } - /* get material color */ - setcolor(nd.mcolor, m->oargs.farg[0], - m->oargs.farg[1], - m->oargs.farg[2]); - /* get roughness */ - if (r->rod < 0.0) - flipsurface(r); - /* get modifiers */ - raytexture(r, m->omod); - nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */ - multcolor(nd.mcolor, r->pcol); /* modify material color */ - r->rt = r->rot; /* default ray length */ - /* get specular component */ - nd.rspec = m->oargs.farg[3]; - - if (nd.rspec > FTINY) { /* has specular component */ - /* compute specular color */ - if (m->otype == MAT_MFUNC || m->otype == MAT_MDATA) - copycolor(nd.scolor, nd.mcolor); - else - setcolor(nd.scolor, 1.0, 1.0, 1.0); - scalecolor(nd.scolor, nd.rspec); - /* improved model */ - dtmp = exp(-BSPEC(m)*nd.pdot); - for (i = 0; i < 3; i++) - colval(nd.scolor,i) += (1.0-colval(nd.scolor,i))*dtmp; - nd.rspec += (1.0-nd.rspec)*dtmp; + /* set special variables */ + setbrdfunc(&nd); + /* compute transmitted ray */ + if (m->otype == MAT_BRTDF && nd.tspec > FTINY) { + RAY sr; + errno = 0; + setcolor(ctmp, varvalue(m->oargs.sarg[0]), + varvalue(m->oargs.sarg[1]), + varvalue(m->oargs.sarg[2])); + scalecolor(ctmp, nd.tspec); + if (errno) + objerror(m, WARNING, "compute error"); + else if ((dtmp = bright(ctmp)) > FTINY && + rayorigin(&sr, r, TRANS, dtmp) == 0) { + if (DOT(r->pert,r->pert) > FTINY*FTINY) { + for (i = 0; i < 3; i++) /* perturb direction */ + sr.rdir[i] = r->rdir[i] - + .75*r->pert[i]; + normalize(sr.rdir); + } else { + VCOPY(sr.rdir, r->rdir); + transtest = 2; + } + rayvalue(&sr); + multcolor(sr.rcol, ctmp); + addcolor(r->rcol, sr.rcol); + transtest *= bright(sr.rcol); + transdist = r->rot + sr.rt; + } } - /* diffuse reflection */ - nd.rdiff = 1.0 - nd.rspec; + if (r->crtype & SHADOW) /* the rest is shadow */ + return; + /* compute reflected ray */ + if (m->otype == MAT_BRTDF && nd.rspec > FTINY) { + RAY sr; + errno = 0; + setcolor(ctmp, varvalue(m->oargs.sarg[3]), + varvalue(m->oargs.sarg[4]), + varvalue(m->oargs.sarg[5])); + scalecolor(ctmp, nd.rspec); + if (errno) + objerror(m, WARNING, "compute error"); + else if ((dtmp = bright(ctmp)) > FTINY && + rayorigin(&sr, r, REFLECTED, dtmp) == 0) { + for (i = 0; i < 3; i++) + sr.rdir[i] = r->rdir[i] + + 2.0*nd.pdot*nd.pnorm[i]; + rayvalue(&sr); + multcolor(sr.rcol, ctmp); + addcolor(r->rcol, sr.rcol); + } + } /* compute ambient */ if (nd.rdiff > FTINY) { ambient(ctmp, r); + if (m->otype == MAT_BRTDF) + scalecolor(ctmp, nd.rdiff); + else + scalecolor(ctmp, 1.0-nd.trans); multcolor(ctmp, nd.mcolor); /* modified by material color */ addcolor(r->rcol, ctmp); /* add to returned color */ } + if (nd.tdiff > FTINY) { /* from other side */ + flipsurface(r); + ambient(ctmp, r); + if (m->otype == MAT_BRTDF) + scalecolor(ctmp, nd.tdiff); + else + scalecolor(ctmp, nd.trans); + multcolor(ctmp, nd.mcolor); + addcolor(r->rcol, ctmp); + flipsurface(r); + } /* add direct component */ direct(r, dirbrdf, &nd); + /* check distance */ + if (transtest > bright(r->rcol)) + r->rt = transdist; +} + + +setbrdfunc(np) /* set up brdf function and variables */ +register BRDFDAT *np; +{ + FVECT vec; + + if (setfunc(np->mp, np->pr) == 0) + return(0); /* it's OK, setfunc says we're done */ + /* else (re)assign special variables */ + multv3(vec, np->pnorm, funcxf.xfm); + varset("NxP", '=', vec[0]/funcxf.sca); + varset("NyP", '=', vec[1]/funcxf.sca); + varset("NzP", '=', vec[2]/funcxf.sca); + varset("RdotP", '=', np->pdot <= -1.0 ? -1.0 : + np->pdot >= 1.0 ? 1.0 : np->pdot); + varset("CrP", '=', colval(np->mcolor,RED)); + varset("CgP", '=', colval(np->mcolor,GRN)); + varset("CbP", '=', colval(np->mcolor,BLU)); + return(1); }
