--- ray/src/rt/m_brdf.c 2018/01/10 17:45:11 2.35 +++ ray/src/rt/m_brdf.c 2023/11/15 18:02:52 2.40 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: m_brdf.c,v 2.35 2018/01/10 17:45:11 greg Exp $"; +static const char RCSid[] = "$Id: m_brdf.c,v 2.40 2023/11/15 18:02:52 greg Exp $"; #endif /* * Shading for materials with arbitrary BRDF's @@ -67,9 +67,9 @@ typedef struct { OBJREC *mp; /* material pointer */ RAY *pr; /* intersected ray */ DATARRAY *dp; /* data array for PDATA, MDATA or TDATA */ - COLOR mcolor; /* material (or pattern) color */ - COLOR rdiff; /* diffuse reflection */ - COLOR tdiff; /* diffuse transmission */ + SCOLOR mcolor; /* material (or pattern) color */ + SCOLOR rdiff; /* diffuse reflection */ + SCOLOR tdiff; /* diffuse transmission */ double rspec; /* specular reflectance (1 for BRDTF) */ double trans; /* transmissivity (.5 for BRDTF) */ double tspec; /* specular transmittance (1 for BRDTF) */ @@ -83,8 +83,8 @@ static int setbrdfunc(BRDFDAT *np); static void dirbrdf( /* compute source contribution */ - COLOR cval, /* returned coefficient */ - void *nnp, /* material data */ + SCOLOR scval, /* returned coefficient */ + void *nnp, /* material data */ FVECT ldir, /* light source direction */ double omega /* light source size */ ) @@ -92,14 +92,15 @@ dirbrdf( /* compute source contribution */ BRDFDAT *np = nnp; double ldot; double dtmp; + SCOLOR sctmp; COLOR ctmp; FVECT ldx; - static double vldx[5], pt[MAXDIM]; + static double vldx[5], pt[MAXDDIM]; char **sa; int i; #define lddx (vldx+1) - setcolor(cval, 0.0, 0.0, 0.0); + scolorblack(scval); ldot = DOT(np->pnorm, ldir); @@ -115,18 +116,18 @@ dirbrdf( /* compute source contribution */ * color. The diffuse reflected component will always be * modified by the color of the material. */ - copycolor(ctmp, np->rdiff); + copyscolor(sctmp, np->rdiff); dtmp = ldot * omega / PI; - scalecolor(ctmp, dtmp); - addcolor(cval, ctmp); + scalescolor(sctmp, dtmp); + saddscolor(scval, sctmp); } else { /* * Diffuse transmitted component. */ - copycolor(ctmp, np->tdiff); + copyscolor(sctmp, np->tdiff); dtmp = -ldot * omega / PI; - scalecolor(ctmp, dtmp); - addcolor(cval, ctmp); + scalescolor(sctmp, dtmp); + saddscolor(scval, sctmp); } if ((ldot > 0.0 ? np->rspec <= FTINY : np->tspec <= FTINY) || ambRayInPmap(np->pr)) @@ -177,24 +178,25 @@ dirbrdf( /* compute source contribution */ } if (dtmp <= FTINY) return; + setscolor(sctmp, colval(ctmp,RED), colval(ctmp,GRN), colval(ctmp,BLU)); if (ldot > 0.0) { /* * Compute reflected non-diffuse component. */ if ((np->mp->otype == MAT_MFUNC) | (np->mp->otype == MAT_MDATA)) - multcolor(ctmp, np->mcolor); + smultscolor(sctmp, np->mcolor); dtmp = ldot * omega * np->rspec; - scalecolor(ctmp, dtmp); - addcolor(cval, ctmp); + scalescolor(sctmp, dtmp); + saddscolor(scval, sctmp); } else { /* * Compute transmitted non-diffuse component. */ if ((np->mp->otype == MAT_TFUNC) | (np->mp->otype == MAT_TDATA)) - multcolor(ctmp, np->mcolor); + smultscolor(sctmp, np->mcolor); dtmp = -ldot * omega * np->tspec; - scalecolor(ctmp, dtmp); - addcolor(cval, ctmp); + scalescolor(sctmp, dtmp); + saddscolor(scval, sctmp); } #undef lddx } @@ -209,11 +211,9 @@ m_brdf( /* color a ray that hit a BRDTfunc material int hitfront = 1; BRDFDAT nd; RAY sr; - double mirtest=0, mirdist; - double transtest=0, transdist; int hasrefl, hastrans; int hastexture; - COLOR ctmp; + SCOLOR sctmp; FVECT vtmp; double d; MFUNC *mf; @@ -228,15 +228,15 @@ m_brdf( /* color a ray that hit a BRDTfunc material nd.trans = 0.5; /* diffuse reflectance */ if (r->rod > 0.0) - setcolor(nd.rdiff, m->oargs.farg[0], + setscolor(nd.rdiff, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]); else - setcolor(nd.rdiff, m->oargs.farg[3], + setscolor(nd.rdiff, m->oargs.farg[3], m->oargs.farg[4], m->oargs.farg[5]); /* diffuse transmittance */ - setcolor(nd.tdiff, m->oargs.farg[6], + setscolor(nd.tdiff, m->oargs.farg[6], m->oargs.farg[7], m->oargs.farg[8]); /* get modifiers */ @@ -256,24 +256,23 @@ m_brdf( /* color a ray that hit a BRDTfunc material } hitfront = 0; } - copycolor(nd.mcolor, r->pcol); /* get pattern color */ - multcolor(nd.rdiff, nd.mcolor); /* modify diffuse values */ - multcolor(nd.tdiff, nd.mcolor); - hasrefl = (bright(nd.rdiff) > FTINY); - hastrans = (bright(nd.tdiff) > FTINY); - mirdist = transdist = r->rot; + copyscolor(nd.mcolor, r->pcol); /* get pattern color */ + smultscolor(nd.rdiff, nd.mcolor); /* modify diffuse values */ + smultscolor(nd.tdiff, nd.mcolor); + hasrefl = (sintens(nd.rdiff) > FTINY); + hastrans = (sintens(nd.tdiff) > FTINY); /* load cal file */ nd.dp = NULL; mf = getfunc(m, 9, 0x3f, 0); /* compute transmitted ray */ setbrdfunc(&nd); errno = 0; - setcolor(ctmp, evalue(mf->ep[3]), + setscolor(sctmp, evalue(mf->ep[3]), evalue(mf->ep[4]), evalue(mf->ep[5])); if ((errno == EDOM) | (errno == ERANGE)) objerror(m, WARNING, "compute error"); - else if (rayorigin(&sr, TRANS, r, ctmp) == 0) { + else if (rayorigin(&sr, TRANS, r, sctmp) == 0) { if (hastexture && !(r->crtype & (SHADOW|AMBIENT))) { /* perturb direction */ VSUB(sr.rdir, r->rdir, r->pert); @@ -285,43 +284,42 @@ m_brdf( /* color a ray that hit a BRDTfunc material VCOPY(sr.rdir, r->rdir); } rayvalue(&sr); - multcolor(sr.rcol, sr.rcoef); - addcolor(r->rcol, sr.rcol); - if (!hastexture || r->crtype & (SHADOW|AMBIENT)) { - transtest = 2.0*bright(sr.rcol); - transdist = r->rot + sr.rt; - } + smultscolor(sr.rcol, sr.rcoef); + saddscolor(r->rcol, sr.rcol); + if ((!hastexture || r->crtype & (SHADOW|AMBIENT)) && + nd.tspec > pbright(nd.tdiff) + pbright(nd.rdiff)) + r->rxt = r->rot + raydistance(&sr); } - if (r->crtype & SHADOW) { /* the rest is shadow */ - r->rt = transdist; + if (r->crtype & SHADOW) /* the rest is shadow */ return(1); - } + /* compute reflected ray */ setbrdfunc(&nd); errno = 0; - setcolor(ctmp, evalue(mf->ep[0]), + setscolor(sctmp, evalue(mf->ep[0]), evalue(mf->ep[1]), evalue(mf->ep[2])); if ((errno == EDOM) | (errno == ERANGE)) objerror(m, WARNING, "compute error"); - else if (rayorigin(&sr, REFLECTED, r, ctmp) == 0) { + else if (rayorigin(&sr, REFLECTED, r, sctmp) == 0) { VSUM(sr.rdir, r->rdir, nd.pnorm, 2.*nd.pdot); checknorm(sr.rdir); rayvalue(&sr); - multcolor(sr.rcol, sr.rcoef); - addcolor(r->rcol, sr.rcol); - if (!hastexture && r->ro != NULL && isflat(r->ro->otype)) { - mirtest = 2.0*bright(sr.rcol); - mirdist = r->rot + sr.rt; - } + smultscolor(sr.rcol, sr.rcoef); + copyscolor(r->mcol, sr.rcol); + saddscolor(r->rcol, sr.rcol); + r->rmt = r->rot; + if (r->ro != NULL && isflat(r->ro->otype) && + !hastexture | (r->crtype & AMBIENT)) + r->rmt += raydistance(&sr); } /* compute ambient */ if (hasrefl) { if (!hitfront) flipsurface(r); - copycolor(ctmp, nd.rdiff); - multambient(ctmp, r, nd.pnorm); - addcolor(r->rcol, ctmp); /* add to returned color */ + copyscolor(sctmp, nd.rdiff); + multambient(sctmp, r, nd.pnorm); + saddscolor(r->rcol, sctmp); /* add to returned color */ if (!hitfront) flipsurface(r); } @@ -331,21 +329,15 @@ m_brdf( /* color a ray that hit a BRDTfunc material vtmp[0] = -nd.pnorm[0]; vtmp[1] = -nd.pnorm[1]; vtmp[2] = -nd.pnorm[2]; - copycolor(ctmp, nd.tdiff); - multambient(ctmp, r, vtmp); - addcolor(r->rcol, ctmp); + copyscolor(sctmp, nd.tdiff); + multambient(sctmp, r, vtmp); + saddscolor(r->rcol, sctmp); if (hitfront) flipsurface(r); } if (hasrefl | hastrans || m->oargs.sarg[6][0] != '0') direct(r, dirbrdf, &nd); /* add direct component */ - d = bright(r->rcol); /* set effective distance */ - if (transtest > d) - r->rt = transdist; - else if (mirtest > d) - r->rt = mirdist; - return(1); } @@ -358,7 +350,7 @@ m_brdf2( /* color a ray that hit a BRDF material */ ) { BRDFDAT nd; - COLOR ctmp; + SCOLOR sctmp; FVECT vtmp; double dtmp; /* always a shadow */ @@ -382,7 +374,7 @@ m_brdf2( /* color a ray that hit a BRDF material */ nd.mp = m; nd.pr = r; /* get material color */ - setcolor(nd.mcolor, m->oargs.farg[0], + setscolor(nd.mcolor, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]); /* get specular component */ @@ -392,18 +384,18 @@ m_brdf2( /* color a ray that hit a BRDF material */ nd.trans = m->oargs.farg[4]*(1.0 - nd.rspec); nd.tspec = nd.trans * m->oargs.farg[5]; dtmp = nd.trans - nd.tspec; - setcolor(nd.tdiff, dtmp, dtmp, dtmp); + setscolor(nd.tdiff, dtmp, dtmp, dtmp); } else { nd.tspec = nd.trans = 0.0; - setcolor(nd.tdiff, 0.0, 0.0, 0.0); + scolorblack(nd.tdiff); } /* compute reflectance */ dtmp = 1.0 - nd.trans - nd.rspec; - setcolor(nd.rdiff, dtmp, dtmp, dtmp); + setscolor(nd.rdiff, dtmp, dtmp, dtmp); nd.pdot = raynormal(nd.pnorm, r); /* perturb normal */ - multcolor(nd.mcolor, r->pcol); /* modify material color */ - multcolor(nd.rdiff, nd.mcolor); - multcolor(nd.tdiff, nd.mcolor); + smultscolor(nd.mcolor, r->pcol); /* modify material color */ + smultscolor(nd.rdiff, nd.mcolor); + smultscolor(nd.tdiff, nd.mcolor); /* load auxiliary files */ if (hasdata(m->otype)) { nd.dp = getdata(m->oargs.sarg[1]); @@ -414,20 +406,20 @@ m_brdf2( /* color a ray that hit a BRDF material */ } /* compute ambient */ if (nd.trans < 1.0-FTINY) { - copycolor(ctmp, nd.mcolor); /* modified by material color */ - scalecolor(ctmp, 1.0-nd.trans); - multambient(ctmp, r, nd.pnorm); - addcolor(r->rcol, ctmp); /* add to returned color */ + copyscolor(sctmp, nd.mcolor); /* modified by material color */ + scalescolor(sctmp, 1.0-nd.trans); + multambient(sctmp, r, nd.pnorm); + saddscolor(r->rcol, sctmp); /* add to returned color */ } - if (nd.trans > FTINY) { /* from other side */ + if (nd.trans > FTINY) { /* from other side */ flipsurface(r); vtmp[0] = -nd.pnorm[0]; vtmp[1] = -nd.pnorm[1]; vtmp[2] = -nd.pnorm[2]; - copycolor(ctmp, nd.mcolor); - scalecolor(ctmp, nd.trans); - multambient(ctmp, r, vtmp); - addcolor(r->rcol, ctmp); + copyscolor(sctmp, nd.mcolor); + scalescolor(sctmp, nd.trans); + multambient(sctmp, r, vtmp); + saddscolor(r->rcol, sctmp); flipsurface(r); } /* add direct component */ @@ -443,18 +435,20 @@ setbrdfunc( /* set up brdf function and variables */ ) { FVECT vec; + COLOR ctmp; if (setfunc(np->mp, np->pr) == 0) return(0); /* it's OK, setfunc says we're done */ /* else (re)assign special variables */ multv3(vec, np->pnorm, funcxf.xfm); - varset("NxP", '=', vec[0]/funcxf.sca); - varset("NyP", '=', vec[1]/funcxf.sca); - varset("NzP", '=', vec[2]/funcxf.sca); - varset("RdotP", '=', np->pdot <= -1.0 ? -1.0 : + varset("NxP`", '=', vec[0]/funcxf.sca); + varset("NyP`", '=', vec[1]/funcxf.sca); + varset("NzP`", '=', vec[2]/funcxf.sca); + varset("RdotP`", '=', np->pdot <= -1.0 ? -1.0 : np->pdot >= 1.0 ? 1.0 : np->pdot); - varset("CrP", '=', colval(np->mcolor,RED)); - varset("CgP", '=', colval(np->mcolor,GRN)); - varset("CbP", '=', colval(np->mcolor,BLU)); + scolor_color(ctmp, np->mcolor); /* should use scolor_rgb()? */ + varset("CrP", '=', colval(ctmp,RED)); + varset("CgP", '=', colval(ctmp,GRN)); + varset("CbP", '=', colval(ctmp,BLU)); return(1); }
