root/radiance/ray/src/rt/m_alias.c
Revision: 2.9
Committed: Fri Feb 16 18:37:51 2018 UTC (6 years, 4 months ago) by greg
Changes since 2.8: +4 -4 lines
Fixed sloppy code copy from raytrace.c
2 static const char RCSid[] = "$Id: m_alias.c,v 2.8 2018/01/09 05:01:15 greg Exp $";
5 * Handler for modifier alias
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "otypes.h"
12 #include "rtotypes.h"
13 #include "otspecial.h"
14
15 /*
16 * If the alias has a single string argument, it's the
17 * name of the target modifier, and we must substitute the
18 * target and its arguments in place of this alias. The
19 * only difference is that we use our modifier rather than
20 * theirs.
21 * If the alias has no string arguments, then we simply
22 * pass through to our modifier as if we weren't in the
23 * chain at all.
24 */
25
26 int
27 m_alias( /* transfer shading to alias target */
28 OBJREC *m,
29 RAY *r
30 )
31 {
32 OBJECT aobj;
33 OBJREC *aop;
34 OBJREC arec;
35 int rval;
36 /* straight replacement? */
37 if (!m->oargs.nsargs)
38 return(rayshade(r, m->omod));
39 /* else replace alias */
40 if (m->oargs.nsargs != 1)
41 objerror(m, INTERNAL, "bad # string arguments");
42 aop = m;
43 aobj = objndx(aop);
44 do { /* follow alias trail */
45 if (aop->oargs.nsargs == 1)
46 aobj = lastmod(aobj, aop->oargs.sarg[0]);
47 else
48 aobj = aop->omod;
49 if (aobj < 0)
50 objerror(aop, USER, "bad reference");
51 aop = objptr(aobj);
52 } while (aop->otype == MOD_ALIAS);
53 /* copy struct */
54 arec = *aop;
55 /* irradiance hack */
56 if (do_irrad && !(r->crtype & ~(PRIMARY|TRANS)) &&
57 (ofun[arec.otype].flags & (T_M|T_X)) &&
58 arec.otype != MAT_CLIP) {
59 if (istransp(arec.otype) || isBSDFproxy(&arec)) {
60 raytrans(r);
61 return(1);
62 }
63 if (!islight(arec.otype))
64 return((*ofun[Lamb.otype].funp)(&Lamb, r));
65 }
66 /* substitute modifier */
67 arec.omod = m->omod;
68 /* replacement shader */
69 rval = (*ofun[arec.otype].funp)(&arec, r);
70 /* save allocated struct */
71 if (arec.os != aop->os) {
72 if (aop->os != NULL) /* should never happen */
73 free_os(aop);
74 aop->os = arec.os;
75 }
76 return(rval);
77 }
