--- ray/src/rt/m_alias.c 2006/07/12 05:47:05 2.6 +++ ray/src/rt/m_alias.c 2018/12/05 02:12:23 2.10 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: m_alias.c,v 2.6 2006/07/12 05:47:05 greg Exp $"; +static const char RCSid[] = "$Id: m_alias.c,v 2.10 2018/12/05 02:12:23 greg Exp $"; #endif /* * Handler for modifier alias @@ -23,7 +23,7 @@ static const char RCSid[] = "$Id: m_alias.c,v 2.6 2006 * chain at all. */ -extern int +int m_alias( /* transfer shading to alias target */ OBJREC *m, RAY *r @@ -36,35 +36,27 @@ m_alias( /* transfer shading to alias target */ /* straight replacement? */ if (!m->oargs.nsargs) return(rayshade(r, m->omod)); - /* else replace alias */ - if (m->oargs.nsargs != 1) - objerror(m, INTERNAL, "bad # string arguments"); - aop = m; + + aop = m; /* else look it up */ aobj = objndx(aop); - do { /* follow alias trail */ - if (aop->oargs.nsargs == 1) + do { /* follow entire alias trail */ + if (!aop->oargs.nsargs) + aobj = aop->omod; + else if (aop->oargs.nsargs == 1) aobj = lastmod(aobj, aop->oargs.sarg[0]); else - aobj = aop->omod; + objerror(aop, INTERNAL, "bad # string arguments"); if (aobj < 0) objerror(aop, USER, "bad reference"); aop = objptr(aobj); } while (aop->otype == MOD_ALIAS); /* copy struct */ arec = *aop; - /* irradiance hack */ - if (do_irrad && !(r->crtype & ~(PRIMARY|TRANS)) && - m->otype != MAT_CLIP && - (ofun[arec.otype].flags & (T_M|T_X))) { - if (irr_ignore(arec.otype)) { - raytrans(r); - return(1); - } - if (!islight(arec.otype)) - return((*ofun[Lamb.otype].funp)(&Lamb, r)); - } /* substitute modifier */ arec.omod = m->omod; + /* irradiance hack */ + if (do_irrad && !(r->crtype & ~(PRIMARY|TRANS)) && raytirrad(&arec, r)) + return(1); /* replacement shader */ rval = (*ofun[arec.otype].funp)(&arec, r); /* save allocated struct */
