root/Development/ray/src/rt/m_alias.c
Mon Feb 1 16:19:49 2021 UTC (4 years, 11 months ago) by greg
perf: made use of OVOID and findmaterial() more consistent and efficient
Wed Dec 5 02:12:23 2018 UTC (7 years, 1 month ago) by greg
Changes since 2.9: +11 -19 lines
Created raytirrad() call to take care of irradiance hack
Fri Feb 16 18:37:51 2018 UTC (7 years, 10 months ago) by greg
Changes since 2.8: +4 -4 lines
Fixed sloppy code copy from raytrace.c
Tue Jan 9 05:01:15 2018 UTC (7 years, 11 months ago) by greg
Made proximity test (plugaleak) more robust with transparent surfaces, etc.
Tue Jul 8 18:25:00 2014 UTC (11 years, 5 months ago) by greg
Wed Jul 12 05:47:05 2006 UTC (19 years, 5 months ago) by greg
Changes since 2.5: +13 -5 lines
Tue Mar 30 16:13:01 2004 UTC (21 years, 9 months ago) by schorsch
Changes since 2.4: +8 -5 lines
Tue Jan 20 22:16:53 2004 UTC (21 years, 11 months ago) by greg
Changes since 2.3: +13 -3 lines
Fixed bug where aliases with object structures were leaking memory
Tue Sep 9 03:28:43 2003 UTC (22 years, 4 months ago) by greg
Bug fix for -i option using antimatter.
Mon Jul 21 22:30:19 2003 UTC (22 years, 5 months ago) by schorsch
Tue Mar 11 19:29:05 2003 UTC (22 years, 9 months ago) by greg
Diff to selected 2.10
