root/radiance/ray/src/rt/m_alias.c
Revision: 2.5
Committed: Tue Mar 30 16:13:01 2004 UTC (21 years, 1 month ago) by schorsch
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1
Changes since 2.4: +8 -5 lines
2 static const char RCSid[] = "$Id: m_alias.c,v 2.4 2004/01/20 22:16:53 greg Exp $";
5 * Handler for modifier alias
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "otypes.h"
12 #include "rtotypes.h"
13 #include "otspecial.h"
14
15 /*
16 * If the alias has a single string argument, it's the
17 * name of the target modifier, and we must substitute the
18 * target and its arguments in place of this alias. The
19 * only difference is that we use our modifier rather than
20 * theirs.
21 * If the alias has no string arguments, then we simply
22 * pass through to our modifier as if we weren't in the
23 * chain at all.
24 */
25
26 extern int
27 m_alias( /* transfer shading to alias target */
28 OBJREC *m,
29 RAY *r
30 )
31 {
32 OBJECT aobj;
33 OBJREC *aop;
34 OBJREC arec;
35 int rval;
36 /* straight replacement? */
37 if (!m->oargs.nsargs)
38 return(rayshade(r, m->omod));
39 /* else replace alias */
40 if (m->oargs.nsargs != 1)
41 objerror(m, INTERNAL, "bad # string arguments");
42 aobj = lastmod(objndx(m), m->oargs.sarg[0]);
43 if (aobj < 0)
44 objerror(m, USER, "bad reference");
45 aop = objptr(aobj);
46 arec = *aop;
47 /* irradiance hack */
48 if (do_irrad && !(r->crtype & ~(PRIMARY|TRANS)) &&
49 m->otype != MAT_CLIP &&
50 (ofun[arec.otype].flags & (T_M|T_X))) {
51 if (irr_ignore(arec.otype)) {
52 raytrans(r);
53 return(1);
54 }
55 if (!islight(arec.otype))
56 return((*ofun[Lamb.otype].funp)(&Lamb, r));
57 }
58 /* substitute modifier */
59 arec.omod = m->omod;
60 /* replacement shader */
61 rval = (*ofun[arec.otype].funp)(&arec, r);
62 /* save allocated struct */
63 if (arec.os != aop->os) {
64 if (aop->os != NULL) /* should never happen */
65 free_os(aop);
66 aop->os = arec.os;
67 }
68 return(rval);
69 }
