--- ray/src/rt/lookamb.c 2004/03/30 16:13:01 2.10 +++ ray/src/rt/lookamb.c 2014/06/19 16:26:55 2.15 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: lookamb.c,v 2.10 2004/03/30 16:13:01 schorsch Exp $"; +static const char RCSid[] = "$Id: lookamb.c,v 2.15 2014/06/19 16:26:55 greg Exp $"; #endif /* * lookamb.c - program to examine ambient components. @@ -19,76 +19,110 @@ int reverse = 0; AMBVAL av; +#ifndef OLDAMB -int -main( /* load ambient values from a file */ - int argc, - char *argv[] + +static void +lookamb( /* load & convert ambient values from a file */ + FILE *fp ) { - FILE *fp; - int i; + FVECT norm, uvec; - for (i = 1; i < argc; i++) - if (argv[i][0] == '-') - switch (argv[i][1]) { - case 'd': - dataonly = 1; - break; - case 'r': - reverse = 1; - break; - case 'h': - header = 0; - break; - default: - fprintf(stderr, "%s: unknown option '%s'\n", - argv[0], argv[i]); - return(1); - } - else - break; - - if (i >= argc) - fp = stdin; - else if ((fp = fopen(argv[i], "r")) == NULL) { - fprintf(stderr, "%s: file not found\n", argv[i]); - return(1); - } - if (reverse) { - if (header) { - if (checkheader(fp, "ascii", stdout) < 0) - goto formaterr; + while (readambval(&av, fp)) { + decodedir(norm, av.ndir); + decodedir(uvec, av.udir); + if (dataonly) { + printf("%f\t%f\t%f\t", av.pos[0], av.pos[1], av.pos[2]); + printf("%f\t%f\t%f\t", norm[0], norm[1], norm[2]); + printf("%f\t%f\t%f\t", uvec[0], uvec[1], uvec[2]); + printf("%d\t%f\t%f\t%f\t", av.lvl, av.weight, + av.rad[0], av.rad[1]); + printf("%e\t%e\t%e\t", colval(av.val,RED), + colval(av.val,GRN), + colval(av.val,BLU)); + printf("%f\t%f\t", av.gpos[0], av.gpos[1]); + printf("%f\t%f\t", av.gdir[0], av.gdir[1]); + printf("%u\n", av.corral); } else { - newheader("RADIANCE", stdout); - printargs(argc, argv, stdout); + printf("Position:\t%f\t%f\t%f\n", av.pos[0], + av.pos[1], av.pos[2]); + printf("Normal:\t\t%f\t%f\t%f\n", + norm[0], norm[1], norm[2]); + printf("Uvector:\t%f\t%f\t%f\n", + uvec[0], uvec[1], uvec[2]); + printf("Lvl,Wt,UVrad:\t%d\t\t%f\t%f\t%f\n", av.lvl, + av.weight, av.rad[0], av.rad[1]); + printf("Value:\t\t%e\t%e\t%e\n", colval(av.val,RED), + colval(av.val,GRN), colval(av.val,BLU)); + printf("Pos.Grad:\t%f\t%f\n", av.gpos[0], av.gpos[1]); + printf("Dir.Grad:\t%f\t%f\n", av.gdir[0], av.gdir[1]); + printf("Corral:\t\t%8X\n\n", av.corral); } - fputformat(AMBFMT, stdout); - putchar('\n'); - SET_FILE_BINARY(stdout); - putambmagic(stdout); - writamb(fp); - } else { - SET_FILE_BINARY(fp); - if (checkheader(fp, AMBFMT, header ? stdout : (FILE *)NULL) < 0) - goto formaterr; - if (!hasambmagic(fp)) - goto formaterr; - if (header) { - fputformat("ascii", stdout); - putchar('\n'); - } - lookamb(fp); + if (ferror(stdout)) + exit(1); } - fclose(fp); - return(0); -formaterr: - fprintf(stderr, "%s: format error on input\n", argv[0]); - exit(1); } -extern void +static void +writamb( /* write binary ambient values to stdout */ + FILE *fp +) +{ + FVECT norm; + + for ( ; ; ) { + if (!dataonly) + fscanf(fp, "%*s"); + if (fscanf(fp, "%f %f %f", + &av.pos[0], &av.pos[1], &av.pos[2]) != 3) + return; + if (!dataonly) + fscanf(fp, "%*s"); + if (fscanf(fp, FVFORMAT, &norm[0], &norm[1], &norm[2]) != 3) + return; + av.ndir = encodedir(norm); + if (!dataonly) + fscanf(fp, "%*s"); + if (fscanf(fp, FVFORMAT, &norm[0], &norm[1], &norm[2]) != 3) + return; + av.udir = encodedir(norm); + if (!dataonly) + fscanf(fp, "%*s"); + if (fscanf(fp, "%d %f %f %f", &av.lvl, &av.weight, + &av.rad[0], &av.rad[1]) != 4) + return; + if (!dataonly) + fscanf(fp, "%*s"); + if (fscanf(fp, "%f %f %f", + &av.val[RED], &av.val[GRN], &av.val[BLU]) != 3) + return; + if (!dataonly) + fscanf(fp, "%*s"); + if (fscanf(fp, "%f %f", &av.gpos[0], &av.gpos[1]) != 2) + return; + if (!dataonly) + fscanf(fp, "%*s"); + if (fscanf(fp, "%f %f", &av.gdir[0], &av.gdir[1]) != 2) + return; + if (dataonly) { + if (fscanf(fp, "%u", &av.corral) != 1) + return; + } else if (fscanf(fp, "%*s %X", &av.corral) != 1) + return; + av.next = NULL; + writambval(&av, stdout); + if (ferror(stdout)) + exit(1); + } +} + + +#else /* ! NEWAMB */ + + +static void lookamb( /* get ambient values from a file */ FILE *fp ) @@ -106,7 +140,7 @@ lookamb( /* get ambient values from a file */ printf("%f\t%f\t%f\n", av.gdir[0], av.gdir[1], av.gdir[2]); } else { - printf("\nPosition:\t%f\t%f\t%f\n", av.pos[0], + printf("Position:\t%f\t%f\t%f\n", av.pos[0], av.pos[1], av.pos[2]); printf("Direction:\t%f\t%f\t%f\n", av.dir[0], av.dir[1], av.dir[2]); @@ -116,7 +150,7 @@ lookamb( /* get ambient values from a file */ colval(av.val,GRN), colval(av.val,BLU)); printf("Pos.Grad:\t%f\t%f\t%f\n", av.gpos[0], av.gpos[1], av.gpos[2]); - printf("Dir.Grad:\t%f\t%f\t%f\n", av.gdir[0], + printf("Dir.Grad:\t%f\t%f\t%f\n\n", av.gdir[0], av.gdir[1], av.gdir[2]); } if (ferror(stdout)) @@ -125,7 +159,7 @@ lookamb( /* get ambient values from a file */ } -extern void +static void writamb( /* write binary ambient values */ FILE *fp ) @@ -166,4 +200,75 @@ writamb( /* write binary ambient values */ if (ferror(stdout)) exit(1); } +} + + +#endif /* ! NEWAMB */ + + +int +main( /* load ambient values from a file */ + int argc, + char *argv[] +) +{ + FILE *fp; + int i; + + for (i = 1; i < argc; i++) + if (argv[i][0] == '-') + switch (argv[i][1]) { + case 'd': + dataonly = 1; + break; + case 'r': + reverse = 1; + break; + case 'h': + header = 0; + break; + default: + fprintf(stderr, "%s: unknown option '%s'\n", + argv[0], argv[i]); + return(1); + } + else + break; + + if (i >= argc) + fp = stdin; + else if ((fp = fopen(argv[i], "r")) == NULL) { + fprintf(stderr, "%s: file not found\n", argv[i]); + return(1); + } + if (reverse) { + if (header) { + if (checkheader(fp, "ascii", stdout) < 0) + goto formaterr; + } else { + newheader("RADIANCE", stdout); + printargs(argc, argv, stdout); + } + fputformat(AMBFMT, stdout); + putchar('\n'); + SET_FILE_BINARY(stdout); + putambmagic(stdout); + writamb(fp); + } else { + SET_FILE_BINARY(fp); + if (checkheader(fp, AMBFMT, header ? stdout : (FILE *)NULL) < 0) + goto formaterr; + if (!hasambmagic(fp)) + goto formaterr; + if (header) { + fputformat("ascii", stdout); + putchar('\n'); + } + lookamb(fp); + } + fclose(fp); + return(0); +formaterr: + fprintf(stderr, "%s: format error on input\n", argv[0]); + exit(1); }
