root/radiance/ray/src/rt/lookamb.c
Sun Aug 2 01:32:15 2015 UTC (8 years, 10 months ago) by greg
Minor compiler warnings fixed
Thu Jun 19 16:26:55 2014 UTC (9 years, 11 months ago) by greg
Sun May 11 19:51:39 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.13: +5 -5 lines
Moved blank line to end for annotated output
Wed May 7 01:16:03 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.12: +9 -2 lines
Diff to previous 2.12
Wed Apr 23 06:04:18 2014 UTC (10 years, 1 month ago) by greg
Fixed numerous errors in Hessian (-DNEWAMB) calculation, doubtless more to go
Fri Apr 11 20:31:37 2014 UTC (10 years, 2 months ago) by greg
Changes since 2.10: +160 -62 lines
Changes since 2.9: +15 -10 lines
Changes since 2.8: +4 -8 lines
Changes since 2.6: +60 -12 lines
Sun Feb 27 10:17:33 1994 UTC (30 years, 3 months ago) by greg
Thu Nov 18 09:43:02 1993 UTC (30 years, 6 months ago) by greg
minor compiler warning fixes
Thu Oct 15 21:13:13 1992 UTC (31 years, 8 months ago) by greg
Changes since 2.3: +10 -0 lines
added setmode(fd,O_BINARY) where needed for MSDOS
Thu Jul 16 12:08:44 1992 UTC (31 years, 11 months ago) by greg
Changes since 2.2: +26 -3 lines
Mon Jul 13 16:17:42 1992 UTC (31 years, 11 months ago) by greg
Tue Nov 12 17:08:36 1991 UTC (32 years, 7 months ago) by greg
Diff to previous 1.5 , to selected 2.12
Fri Jun 7 14:24:34 1991 UTC (33 years ago) by greg
Diff to previous 1.4 , to selected 2.12
fixed small bug
Fri Jun 7 10:04:27 1991 UTC (33 years ago) by greg
Changes since 1.3: +20 -9 lines
Diff to previous 1.3 , to selected 2.12
Thu Jun 6 10:09:50 1991 UTC (33 years ago) by greg
Changes since 1.2: +5 -7 lines
Diff to previous 1.2 , to selected 2.12
changed size of AMBVAL structure
Fri Jan 19 00:00:13 1990 UTC (34 years, 4 months ago) by greg
Diff to previous 1.1 , to selected 2.12
Thu Feb 2 10:41:25 1989 UTC (35 years, 4 months ago) by greg
Diff to selected 2.12
