root/radiance/ray/src/rt/lookamb.c
Revision 2.19 - (view) (download) (annotate) - [selected]
Mon Dec 18 20:19:48 2023 UTC (5 months ago) by greg
Changes since 2.18: +5 -3 lines
Diff to previous 2.18
fix(lookamb): Added step to ensure normals are normalized
Wed Nov 15 18:02:52 2023 UTC (6 months ago) by greg
Changes since 2.17: +17 -14 lines
Diff to previous 2.17 , to selected 2.19
Tue May 14 17:39:10 2019 UTC (5 years ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 2.16: +1 -90 lines
Diff to previous 2.16 , to selected 2.19
Stripped out code related to old (pre-Hessian) ambient calculation
Sun Aug 2 01:32:15 2015 UTC (8 years, 9 months ago) by greg
Diff to previous 2.15 , to selected 2.19
Minor compiler warnings fixed
Thu Jun 19 16:26:55 2014 UTC (9 years, 11 months ago) by greg
Diff to previous 2.14 , to selected 2.19
Sun May 11 19:51:39 2014 UTC (10 years ago) by greg
Changes since 2.13: +5 -5 lines
Diff to previous 2.13 , to selected 2.19
Moved blank line to end for annotated output
Wed May 7 01:16:03 2014 UTC (10 years ago) by greg
Changes since 2.12: +9 -2 lines
Diff to previous 2.12 , to selected 2.19
Wed Apr 23 06:04:18 2014 UTC (10 years, 1 month ago) by greg
Diff to previous 2.11 , to selected 2.19
Fixed numerous errors in Hessian (-DNEWAMB) calculation, doubtless more to go
Fri Apr 11 20:31:37 2014 UTC (10 years, 1 month ago) by greg
Changes since 2.10: +160 -62 lines
Diff to previous 2.10 , to selected 2.19
Changes since 2.9: +15 -10 lines
Diff to previous 2.9 , to selected 2.19
Changes since 2.8: +4 -8 lines
Diff to previous 2.8 , to selected 2.19
Diff to previous 2.7 , to selected 2.19
Changes since 2.6: +60 -12 lines
Diff to previous 2.6 , to selected 2.19
Sun Feb 27 10:17:33 1994 UTC (30 years, 2 months ago) by greg
Diff to previous 2.5 , to selected 2.19
Thu Nov 18 09:43:02 1993 UTC (30 years, 6 months ago) by greg
Diff to previous 2.4 , to selected 2.19
minor compiler warning fixes
Thu Oct 15 21:13:13 1992 UTC (31 years, 7 months ago) by greg
Changes since 2.3: +10 -0 lines
Diff to previous 2.3 , to selected 2.19
added setmode(fd,O_BINARY) where needed for MSDOS
Thu Jul 16 12:08:44 1992 UTC (31 years, 10 months ago) by greg
Changes since 2.2: +26 -3 lines
Diff to previous 2.2 , to selected 2.19
Mon Jul 13 16:17:42 1992 UTC (31 years, 10 months ago) by greg
Diff to previous 2.1 , to selected 2.19
Tue Nov 12 17:08:36 1991 UTC (32 years, 6 months ago) by greg
Diff to previous 1.5 , to selected 2.19
Fri Jun 7 14:24:34 1991 UTC (32 years, 11 months ago) by greg
Diff to previous 1.4 , to selected 2.19
fixed small bug
Fri Jun 7 10:04:27 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.3: +20 -9 lines
Diff to previous 1.3 , to selected 2.19
Thu Jun 6 10:09:50 1991 UTC (32 years, 11 months ago) by greg
Changes since 1.2: +5 -7 lines
Diff to previous 1.2 , to selected 2.19
changed size of AMBVAL structure
Fri Jan 19 00:00:13 1990 UTC (34 years, 4 months ago) by greg
Diff to previous 1.1 , to selected 2.19
Thu Feb 2 10:41:25 1989 UTC (35 years, 3 months ago) by greg
Diff to selected 2.19
