root/radiance/ray/src/rt/initotypes.c
Tue Jul 8 18:25:00 2014 UTC (9 years, 9 months ago) by greg
Diff to previous 2.18 , to selected 2.8
Sun Jul 29 19:01:39 2012 UTC (11 years, 9 months ago) by greg
Changes since 2.17: +3 -1 lines
Diff to previous 2.17 , to selected 2.8
Fri Feb 18 00:40:25 2011 UTC (13 years, 2 months ago) by greg
Changes since 2.16: +2 -1 lines
Diff to previous 2.16 , to selected 2.8
Mon Oct 8 18:07:57 2007 UTC (16 years, 6 months ago) by greg
CVS Tags: rad3R9, rad4R0
Thu Jun 23 11:51:47 2005 UTC (18 years, 10 months ago) by greg
Mon Oct 25 17:07:35 2004 UTC (19 years, 6 months ago) by greg
CVS Tags: rad3R6P1
Fixed Mark Stock's abort error caused by source & mist combination
Fri Sep 10 17:08:36 2004 UTC (19 years, 7 months ago) by greg
Fixed bug in last fix -- distant sources weren't working
Changes since 2.11: +7 -28 lines
Changes since 2.10: +11 -1 lines
Tue Mar 11 19:29:05 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.9: +2 -0 lines
Tue Mar 11 17:08:55 2003 UTC (21 years, 1 month ago) by greg
Changes since 2.8: +4 -2 lines
Changes since 2.6: +60 -4 lines
Wed Jan 20 14:10:06 1999 UTC (25 years, 3 months ago) by gwlarson
added "mixpict" primitive
Sat Jun 22 09:48:55 1996 UTC (27 years, 10 months ago) by greg
changed text(), which is reserved word on PowerPC, to do_text()
Fri Dec 8 18:22:37 1995 UTC (28 years, 5 months ago) by greg
Changes since 2.3: +3 -0 lines
Thu May 27 15:27:59 1993 UTC (30 years, 11 months ago) by greg
removed approximation to Fresnel reflection, since the direct
component was not being calculated accordingly (BRDF not bidirectional)
changed BRDTfunc arguments and operation, fixed one or two bugs there also
Sat Jan 4 19:54:53 1992 UTC (32 years, 4 months ago) by greg
Tue Nov 12 17:08:31 1991 UTC (32 years, 5 months ago) by greg
Diff to previous 1.6 , to selected 2.8
Tue Jul 16 15:56:38 1991 UTC (32 years, 9 months ago) by greg
Changes since 1.5: +3 -0 lines
added redirecting materials
Wed Jun 19 16:38:10 1991 UTC (32 years, 10 months ago) by greg
added virtual sources and mirrors
Tue May 7 15:57:01 1991 UTC (33 years ago) by greg
Changes since 1.3: +4 -1 lines
added MAT_BRTDF, MAT_TFUNC and MAT_TDATA types
Wed May 1 11:45:09 1991 UTC (33 years ago) by greg
Changes since 1.2: +0 -1 lines
fixed special case for illum type
Wed May 1 11:16:52 1991 UTC (33 years ago) by greg
Changes since 1.1: +7 -0 lines
Thu Dec 13 10:44:17 1990 UTC (33 years, 4 months ago) by greg
Diff to selected 2.8
