root/radiance/ray/src/rt/glass.c
Revision: 2.5
Committed: Mon Nov 30 12:02:54 1992 UTC (31 years, 5 months ago) by greg
fixed comment terminology
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * glass.c - simpler shading function for thin glass surfaces.
9 *
10 * 11/14/86
11 */
12
13 #include "ray.h"
14
15 /*
16 * This definition of glass provides for a quick calculation
17 * using a single surface where two closely spaced parallel
18 * dielectric surfaces would otherwise be used. The chief
19 * advantage to using this material is speed, since internal
20 * reflections are avoided.
21 *
22 * The specification for glass is as follows:
23 *
24 * modifier glass id
25 * 0
26 * 0
27 * 3 red grn blu
28 *
29 * The color is used for the transmission at normal incidence.
30 * To compute transmissivity (tn) from transmittance (Tn) use:
31 *
32 * tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn
33 *
34 * The transmissivity of standard 88% transmittance glass is 0.96.
35 * A refractive index other than the default can be used by giving
36 * it as the fourth real argument. The above formula no longer applies.
37 *
38 * If we appear to hit the back side of the surface, then we
39 * turn the normal around.
40 */
41
42 #define RINDEX 1.52 /* refractive index of glass */
43
44
45 m_glass(m, r) /* color a ray which hit a thin glass surface */
46 OBJREC *m;
47 register RAY *r;
48 {
49 COLOR mcolor;
50 double pdot;
51 FVECT pnorm;
52 double rindex, cos2;
53 COLOR trans, refl;
54 double d, r1e, r1m;
55 double transtest, transdist;
56 RAY p;
57 register int i;
58 /* check arguments */
59 if (m->oargs.nfargs == 3)
60 rindex = RINDEX; /* default value of n */
61 else if (m->oargs.nfargs == 4)
62 rindex = m->oargs.farg[3]; /* use their value */
63 else
64 objerror(m, USER, "bad arguments");
65
66 setcolor(mcolor, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]);
67
68 if (r->rod < 0.0) /* reorient if necessary */
69 flipsurface(r);
70 transtest = 0;
71 /* get modifiers */
72 raytexture(r, m->omod);
73 pdot = raynormal(pnorm, r);
74 /* angular transmission */
75 cos2 = sqrt( (1.0-1.0/(rindex*rindex)) +
76 pdot*pdot/(rindex*rindex) );
77 setcolor(mcolor, pow(colval(mcolor,RED), 1.0/cos2),
78 pow(colval(mcolor,GRN), 1.0/cos2),
79 pow(colval(mcolor,BLU), 1.0/cos2));
80
81 /* compute reflection */
82 r1e = (pdot - rindex*cos2) / (pdot + rindex*cos2);
83 r1e *= r1e;
84 r1m = (1.0/pdot - rindex/cos2) / (1.0/pdot + rindex/cos2);
85 r1m *= r1m;
86 /* compute transmittance */
87 for (i = 0; i < 3; i++) {
88 d = colval(mcolor, i);
89 colval(trans,i) = .5*(1.0-r1e)*(1.0-r1e)*d/(1.0-r1e*r1e*d*d);
90 colval(trans,i) += .5*(1.0-r1m)*(1.0-r1m)*d/(1.0-r1m*r1m*d*d);
91 }
92 /* transmitted ray */
93 if (rayorigin(&p, r, TRANS, bright(trans)) == 0) {
94 if (!(r->crtype & SHADOW) &&
95 DOT(r->pert,r->pert) > FTINY*FTINY) {
96 for (i = 0; i < 3; i++) /* perturb direction */
97 p.rdir[i] = r->rdir[i] +
98 2.*(1.-rindex)*r->pert[i];
99 if (normalize(p.rdir) == 0.0) {
100 objerror(m, WARNING, "bad perturbation");
101 VCOPY(p.rdir, r->rdir);
102 }
103 } else {
104 VCOPY(p.rdir, r->rdir);
105 transtest = 2;
106 }
107 rayvalue(&p);
108 multcolor(p.rcol, r->pcol); /* modify */
109 multcolor(p.rcol, trans);
110 addcolor(r->rcol, p.rcol);
111 transtest *= bright(p.rcol);
112 transdist = r->rot + p.rt;
113 }
114
115 if (r->crtype & SHADOW) /* skip reflected ray */
116 return;
117 /* compute reflectance */
118 for (i = 0; i < 3; i++) {
119 d = colval(mcolor, i);
120 d *= d;
121 colval(refl,i) = .5*r1e*(1.0+(1.0-2.0*r1e)*d)/(1.0-r1e*r1e*d);
122 colval(refl,i) += .5*r1m*(1.0+(1.0-2.0*r1m)*d)/(1.0-r1m*r1m*d);
123 }
124 /* reflected ray */
125 if (rayorigin(&p, r, REFLECTED, bright(refl)) == 0) {
126 for (i = 0; i < 3; i++)
127 p.rdir[i] = r->rdir[i] + 2.0*pdot*pnorm[i];
128 rayvalue(&p);
129 multcolor(p.rcol, refl);
130 addcolor(r->rcol, p.rcol);
131 }
132 if (transtest > bright(r->rcol))
133 r->rt = transdist;
134 }
