| 1 | #ifndef lint |
| 2 | static const char RCSid[] = "$Id: glass.c,v 2.28 2019/04/19 19:01:32 greg Exp $"; |
| 3 | #endif |
| 4 | /* |
| 5 | *  glass.c - simpler shading function for thin glass surfaces. |
| 6 | */ |
| 7 |  |
| 8 | #include "copyright.h" |
| 9 |  |
| 10 | #include  "ray.h" |
| 11 | #include  "otypes.h" |
| 12 | #include  "rtotypes.h" |
| 13 | #include  "pmapmat.h" |
| 14 |  |
| 15 | /* |
| 16 | *  This definition of glass provides for a quick calculation |
| 17 | *  using a single surface where two closely spaced parallel |
| 18 | *  dielectric surfaces would otherwise be used.  The chief |
| 19 | *  advantage to using this material is speed, since internal |
| 20 | *  reflections are avoided. |
| 21 | * |
| 22 | *  The specification for glass is as follows: |
| 23 | * |
| 24 | *      modifier glass id |
| 25 | *      0 |
| 26 | *      0 |
| 27 | *      3+ red grn blu [refractive_index] |
| 28 | * |
| 29 | *  The color is used for the transmission at normal incidence. |
| 30 | *  To compute transmissivity (tn) from transmittance (Tn) use: |
| 31 | * |
| 32 | *      tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn |
| 33 | * |
| 34 | *  The transmissivity of standard 88% transmittance glass is 0.96. |
| 35 | *  A refractive index other than the default can be used by giving |
| 36 | *  it as the fourth real argument.  The above formula no longer applies. |
| 37 | * |
| 38 | *  If we appear to hit the back side of the surface, then we |
| 39 | *  turn the normal around. |
| 40 | */ |
| 41 |  |
| 42 | #define  RINDEX         1.52            /* refractive index of glass */ |
| 43 |  |
| 44 |  |
| 45 | int |
| 46 | m_glass(                /* color a ray which hit a thin glass surface */ |
| 47 | OBJREC  *m, |
| 48 | RAY  *r |
| 49 | ) |
| 50 | { |
| 51 | COLOR  mcolor; |
| 52 | SCOLOR  scoef; |
| 53 | double  ctemp[3]; |
| 54 | double  pdot; |
| 55 | FVECT  pnorm; |
| 56 | double  rindex=0, cos2; |
| 57 | int  hastexture, hastrans; |
| 58 | double  d, r1e, r1m; |
| 59 | RAY  p; |
| 60 | int  i; |
| 61 |  |
| 62 | /* PMAP: skip refracted shadow or ambient ray if accounted for in |
| 63 | photon map */ |
| 64 | if (shadowRayInPmap(r) || ambRayInPmap(r)) |
| 65 | return(1); |
| 66 | /* check arguments */ |
| 67 | if (m->oargs.nfargs == 3) |
| 68 | rindex = RINDEX;                /* default value of n */ |
| 69 | else if (m->oargs.nfargs == 4) |
| 70 | rindex = m->oargs.farg[3];      /* use their value */ |
| 71 | else |
| 72 | objerror(m, USER, "bad arguments"); |
| 73 | /* check back face visibility */ |
| 74 | if (!backvis && r->rod <= 0.0) { |
| 75 | raytrans(r); |
| 76 | return(1); |
| 77 | } |
| 78 | /* check transmission */ |
| 79 | setcolor(mcolor, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]); |
| 80 | if ((hastrans = (intens(mcolor) > 1e-15))) { |
| 81 | for (i = 0; i < 3; i++) |
| 82 | if (colval(mcolor,i) < 1e-15) |
| 83 | colval(mcolor,i) = 1e-15; |
| 84 | } else if (r->crtype & SHADOW) |
| 85 | return(1); |
| 86 | /* get modifiers */ |
| 87 | raytexture(r, m->omod); |
| 88 | if (r->rod < 0.0)                       /* reorient if necessary */ |
| 89 | flipsurface(r); |
| 90 | /* perturb normal */ |
| 91 | hastexture = (DOT(r->pert,r->pert) > FTINY*FTINY); |
| 92 | if (hastexture) { |
| 93 | pdot = raynormal(pnorm, r); |
| 94 | } else { |
| 95 | VCOPY(pnorm, r->ron); |
| 96 | pdot = r->rod; |
| 97 | } |
| 98 | /* angular transmission */ |
| 99 | cos2 = sqrt( (1.0-1.0/(rindex*rindex)) + |
| 100 | pdot*pdot/(rindex*rindex) ); |
| 101 | if (hastrans) |
| 102 | setcolor(mcolor, pow(colval(mcolor,RED), 1.0/cos2), |
| 103 | pow(colval(mcolor,GRN), 1.0/cos2), |
| 104 | pow(colval(mcolor,BLU), 1.0/cos2)); |
| 105 |  |
| 106 | /* compute reflection */ |
| 107 | r1e = (pdot - rindex*cos2) / (pdot + rindex*cos2); |
| 108 | r1e *= r1e; |
| 109 | r1m = (1.0/pdot - rindex/cos2) / (1.0/pdot + rindex/cos2); |
| 110 | r1m *= r1m; |
| 111 | /* compute transmission */ |
| 112 | if (hastrans) { |
| 113 | for (i = 0; i < 3; i++) { |
| 114 | d = colval(mcolor, i); |
| 115 | ctemp[i] = .5*(1.0-r1e)*(1.0-r1e)*d / |
| 116 | (1.0-r1e*r1e*d*d) + |
| 117 | .5*(1.0-r1m)*(1.0-r1m)*d / |
| 118 | (1.0-r1m*r1m*d*d); |
| 119 | } |
| 120 | setscolor(scoef, ctemp[RED], ctemp[GRN], ctemp[BLU]); |
| 121 | smultscolor(scoef, r->pcol);    /* modify by pattern */ |
| 122 | /* transmitted ray */ |
| 123 | if (rayorigin(&p, TRANS, r, scoef) == 0) { |
| 124 | if (!(r->crtype & (SHADOW|AMBIENT)) && hastexture) { |
| 125 | VSUM(p.rdir, r->rdir, r->pert, 2.*(1.-rindex)); |
| 126 | if (normalize(p.rdir) == 0.0) { |
| 127 | objerror(m, WARNING, "bad perturbation"); |
| 128 | VCOPY(p.rdir, r->rdir); |
| 129 | } |
| 130 | } else { |
| 131 | VCOPY(p.rdir, r->rdir); |
| 132 | } |
| 133 | rayvalue(&p); |
| 134 | smultscolor(p.rcol, p.rcoef); |
| 135 | saddscolor(r->rcol, p.rcol); |
| 136 | if (!hastexture || r->crtype & (SHADOW|AMBIENT)) |
| 137 | r->rxt = r->rot + raydistance(&p); |
| 138 | } |
| 139 | } |
| 140 | if (r->crtype & SHADOW)                 /* skip reflected ray */ |
| 141 | return(1); |
| 142 | /* compute reflectance */ |
| 143 | for (i = 0; i < 3; i++) { |
| 144 | d = colval(mcolor, i); |
| 145 | d *= d; |
| 146 | ctemp[i] = .5*r1e*(1.0+(1.0-2.0*r1e)*d)/(1.0-r1e*r1e*d) + |
| 147 | .5*r1m*(1.0+(1.0-2.0*r1m)*d)/(1.0-r1m*r1m*d); |
| 148 | } |
| 149 | setscolor(scoef, ctemp[RED], ctemp[GRN], ctemp[BLU]); |
| 150 | /* reflected ray */ |
| 151 | if (rayorigin(&p, REFLECTED, r, scoef) == 0) { |
| 152 | VSUM(p.rdir, r->rdir, pnorm, 2.*pdot); |
| 153 | checknorm(p.rdir); |
| 154 | rayvalue(&p); |
| 155 | smultscolor(p.rcol, p.rcoef); |
| 156 | copyscolor(r->mcol, p.rcol); |
| 157 | saddscolor(r->rcol, p.rcol); |
| 158 | r->rmt = r->rot; |
| 159 | if (r->ro != NULL && isflat(r->ro->otype) && |
| 160 | !hastexture | (r->crtype & AMBIENT)) |
| 161 | r->rmt += raydistance(&p); |
| 162 | } |
| 163 | return(1); |
| 164 | } |
