root/radiance/ray/src/rt/glass.c
Revision: 1.11
Committed: Tue Oct 29 16:30:46 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.10: +9 -6 lines
improved accuracy through separate treatment of polarizations
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * glass.c - simpler shading function for thin glass surfaces.
9 *
10 * 11/14/86
11 */
12
13 #include "ray.h"
14
15 /*
16 * This definition of glass provides for a quick calculation
17 * using a single surface where two closely spaced parallel
18 * dielectric surfaces would otherwise be used. The chief
19 * advantage to using this material is speed, since internal
20 * reflections are avoided.
21 *
22 * The specification for glass is as follows:
23 *
24 * modifier glass id
25 * 0
26 * 0
27 * 3 red grn blu
28 *
29 * The color is used for the transmission at normal incidence.
30 * To compute transmission (tn) from transmissivity (Tn) use:
31 *
32 * tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn
33 *
34 * The transmission of standard 88% transmissivity glass is 0.96.
35 * If we appear to hit the back side of the surface, then we
36 * turn the normal around.
37 */
38
39 #define RINDEX 1.52 /* refractive index of glass */
40
41
42 m_glass(m, r) /* color a ray which hit a thin glass surface */
43 OBJREC *m;
44 register RAY *r;
45 {
46 double sqrt(), pow();
47 COLOR mcolor;
48 double pdot;
49 FVECT pnorm;
50 double cos2;
51 COLOR trans, refl;
52 double d, r1e, r1m;
53 double transtest, transdist;
54 RAY p;
55 register int i;
56
57 if (m->oargs.nfargs != 3)
58 objerror(m, USER, "bad arguments");
59
60 setcolor(mcolor, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]);
61
62 if (r->rod < 0.0) /* reorient if necessary */
63 flipsurface(r);
64 transtest = 0;
65 /* get modifiers */
66 raytexture(r, m->omod);
67 pdot = raynormal(pnorm, r);
68 /* angular transmission */
69 cos2 = sqrt( (1.0-1.0/RINDEX/RINDEX) +
70 pdot*pdot/(RINDEX*RINDEX) );
71 setcolor(mcolor, pow(colval(mcolor,RED), 1.0/cos2),
72 pow(colval(mcolor,GRN), 1.0/cos2),
73 pow(colval(mcolor,BLU), 1.0/cos2));
74
75 /* compute reflection */
76 r1e = (pdot - RINDEX*cos2) / (pdot + RINDEX*cos2);
77 r1e *= r1e;
78 r1m = (1.0/pdot - RINDEX/cos2) / (1.0/pdot + RINDEX/cos2);
79 r1m *= r1m;
80 /* compute transmittance */
81 for (i = 0; i < 3; i++) {
82 d = colval(mcolor, i);
83 colval(trans,i) = .5*(1.0-r1e)*(1.0-r1e)*d/(1.0-r1e*r1e*d*d);
84 colval(trans,i) += .5*(1.0-r1m)*(1.0-r1m)*d/(1.0-r1m*r1m*d*d);
85 }
86 /* transmitted ray */
87 if (rayorigin(&p, r, TRANS, bright(trans)) == 0) {
88 if (!(r->crtype & SHADOW) &&
89 DOT(r->pert,r->pert) > FTINY*FTINY) {
90 for (i = 0; i < 3; i++) /* perturb direction */
91 p.rdir[i] = r->rdir[i] - r->pert[i]/RINDEX;
92 normalize(p.rdir);
93 } else {
94 VCOPY(p.rdir, r->rdir);
95 transtest = 2;
96 }
97 rayvalue(&p);
98 multcolor(p.rcol, r->pcol); /* modify */
99 multcolor(p.rcol, trans);
100 addcolor(r->rcol, p.rcol);
101 transtest *= bright(p.rcol);
102 transdist = r->rot + p.rt;
103 }
104
105 if (r->crtype & SHADOW) /* skip reflected ray */
106 return;
107 /* compute reflectance */
108 for (i = 0; i < 3; i++) {
109 d = colval(mcolor, i);
110 d *= d;
111 colval(refl,i) = .5*r1e*(1.0+(1.0-2.0*r1e)*d)/(1.0-r1e*r1e*d);
112 colval(refl,i) += .5*r1m*(1.0+(1.0-2.0*r1m)*d)/(1.0-r1m*r1m*d);
113 }
114 /* reflected ray */
115 if (rayorigin(&p, r, REFLECTED, bright(refl)) == 0) {
116 for (i = 0; i < 3; i++)
117 p.rdir[i] = r->rdir[i] + 2.0*pdot*pnorm[i];
118 rayvalue(&p);
119 multcolor(p.rcol, refl);
120 addcolor(r->rcol, p.rcol);
121 }
122 if (transtest > bright(r->rcol))
123 r->rt = transdist;
124 }
