root/radiance/ray/src/rt/glass.c
Revision: 1.10
Committed: Mon Aug 12 08:20:57 1991 UTC (32 years, 9 months ago) by greg
fixed source tracing
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * glass.c - simpler shading function for thin glass surfaces.
9 *
10 * 11/14/86
11 */
12
13 #include "ray.h"
14
15 /*
16 * This definition of glass provides for a quick calculation
17 * using a single surface where two closely spaced parallel
18 * dielectric surfaces would otherwise be used. The chief
19 * advantage to using this material is speed, since internal
20 * reflections are avoided.
21 *
22 * The specification for glass is as follows:
23 *
24 * modifier glass id
25 * 0
26 * 0
27 * 3 red grn blu
28 *
29 * The color is used for the transmission at normal incidence.
30 * To compute transmission (tn) from transmissivity (Tn) use:
31 *
32 * tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn
33 *
34 * The transmission of standard 88% transmissivity glass is 0.96.
35 * If we appear to hit the back side of the surface, then we
36 * turn the normal around.
37 */
38
39 #define RINDEX 1.52 /* refractive index of glass */
40
41
42 m_glass(m, r) /* color a ray which hit a thin glass surface */
43 OBJREC *m;
44 register RAY *r;
45 {
46 double sqrt(), pow();
47 COLOR mcolor;
48 double pdot;
49 FVECT pnorm;
50 double cos2;
51 COLOR trans, refl;
52 double d, r1;
53 double transtest, transdist;
54 RAY p;
55 register int i;
56
57 if (m->oargs.nfargs != 3)
58 objerror(m, USER, "bad arguments");
59
60 setcolor(mcolor, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]);
61
62 if (r->rod < 0.0) /* reorient if necessary */
63 flipsurface(r);
64 transtest = 0;
65 /* get modifiers */
66 raytexture(r, m->omod);
67 pdot = raynormal(pnorm, r);
68 /* angular transmission */
69 cos2 = sqrt( (1.0-1.0/RINDEX/RINDEX) +
70 pdot*pdot/(RINDEX*RINDEX) );
71 setcolor(mcolor, pow(colval(mcolor,RED), 1.0/cos2),
72 pow(colval(mcolor,GRN), 1.0/cos2),
73 pow(colval(mcolor,BLU), 1.0/cos2));
74
75 /* compute reflection */
76 r1 = (pdot - RINDEX*cos2) / (pdot + RINDEX*cos2);
77 d = (1.0/pdot - RINDEX/cos2) / (1.0/pdot + RINDEX/cos2);
78 r1 = (r1*r1 + d*d) / 2.0;
79 /* compute transmittance */
80 for (i = 0; i < 3; i++) {
81 d = colval(mcolor, i);
82 colval(trans,i) = (1.0-r1)*(1.0-r1)*d / (1.0 - r1*r1*d*d);
83 }
84 /* transmitted ray */
85 if (rayorigin(&p, r, TRANS, bright(trans)) == 0) {
86 if (!(r->crtype & SHADOW) &&
87 DOT(r->pert,r->pert) > FTINY*FTINY) {
88 for (i = 0; i < 3; i++) /* perturb direction */
89 p.rdir[i] = r->rdir[i] - r->pert[i]/RINDEX;
90 normalize(p.rdir);
91 } else {
92 VCOPY(p.rdir, r->rdir);
93 transtest = 2;
94 }
95 rayvalue(&p);
96 multcolor(p.rcol, r->pcol); /* modify */
97 multcolor(p.rcol, trans);
98 addcolor(r->rcol, p.rcol);
99 transtest *= bright(p.rcol);
100 transdist = r->rot + p.rt;
101 }
102
103 if (r->crtype & SHADOW) /* skip reflected ray */
104 return;
105 /* compute reflectance */
106 for (i = 0; i < 3; i++) {
107 d = colval(mcolor, i);
108 d *= d;
109 colval(refl,i) = r1 * (1.0 + (1.0-2.0*r1)*d) / (1.0 - r1*r1*d);
110 }
111 /* reflected ray */
112 if (rayorigin(&p, r, REFLECTED, bright(refl)) == 0) {
113 for (i = 0; i < 3; i++)
114 p.rdir[i] = r->rdir[i] + 2.0*pdot*pnorm[i];
115 rayvalue(&p);
116 multcolor(p.rcol, refl);
117 addcolor(r->rcol, p.rcol);
118 }
119 if (transtest > bright(r->rcol))
120 r->rt = transdist;
121 }
