root/radiance/ray/src/rt/glass.c
Wed Nov 15 18:02:52 2023 UTC (18 months, 1 week ago) by greg
Changes since 2.28: +20 -16 lines
Diff to previous 2.28 , to selected 2.4
Fri Apr 19 19:01:32 2019 UTC (6 years, 1 month ago) by greg
CVS Tags: rad5R3, rad5R4
Changes since 2.27: +3 -2 lines
Diff to previous 2.27 , to selected 2.4
Make sure reflected ray distance is not infinite if there's a reflection
Tue Nov 13 19:58:33 2018 UTC (6 years, 6 months ago) by greg
Changes since 2.26: +7 -21 lines
Diff to previous 2.26 , to selected 2.4
Wed Oct 28 15:45:58 2015 UTC (9 years, 6 months ago) by greg
CVS Tags: rad5R1, rad5R2
Diff to previous 2.25 , to selected 2.4
Added back ambient ray testing for photon map, which is needed by rcontrib
Thu May 21 13:54:59 2015 UTC (10 years ago) by greg
Diff to previous 2.24 , to selected 2.4
Added calls to findmaterial() and simplified photon map shadow check
Wed May 20 13:11:25 2015 UTC (10 years ago) by rschregle
Changes since 2.23: +4 -3 lines
Diff to previous 2.23 , to selected 2.4
Fixed photon map double-counting bug with ambient rays
Tue Feb 24 19:39:26 2015 UTC (10 years, 3 months ago) by greg
Changes since 2.22: +6 -1 lines
Diff to previous 2.22 , to selected 2.4
Sat May 10 17:43:01 2014 UTC (11 years ago) by greg
Changes since 2.21: +7 -6 lines
Diff to previous 2.21 , to selected 2.4
Fixed virtual distance so as not to undermine ambient calculation
Sat Jan 25 18:27:39 2014 UTC (11 years, 4 months ago) by greg
Changes since 2.20: +6 -1 lines
Diff to previous 2.20 , to selected 2.4
Wed Aug 7 05:10:09 2013 UTC (11 years, 9 months ago) by greg
Diff to previous 2.19 , to selected 2.4
Mon Oct 25 22:57:45 2010 UTC (14 years, 7 months ago) by greg
Changes since 2.18: +3 -6 lines
Diff to previous 2.18 , to selected 2.4
Sun Sep 26 15:51:15 2010 UTC (14 years, 8 months ago) by greg
Diff to previous 2.17 , to selected 2.4
Tue Jun 21 15:06:50 2005 UTC (19 years, 11 months ago) by greg
Changes since 2.16: +38 -29 lines
Diff to previous 2.16 , to selected 2.4
Fixed bugs in black glass transmission and source weight computation
Tue Apr 19 01:15:06 2005 UTC (20 years, 1 month ago) by greg
Changes since 2.15: +6 -6 lines
Diff to previous 2.15 , to selected 2.4
Tue Mar 30 16:13:01 2004 UTC (21 years, 2 months ago) by schorsch
Changes since 2.14: +7 -5 lines
Diff to previous 2.14 , to selected 2.4
Diff to previous 2.13 , to selected 2.4
Wed Mar 12 04:59:05 2003 UTC (22 years, 2 months ago) by greg
Mon Mar 3 00:10:51 2003 UTC (22 years, 2 months ago) by greg
Changed call order for proper function of two-sided, textured surfaces
Tue Feb 25 02:47:22 2003 UTC (22 years, 3 months ago) by greg
Sat Feb 22 02:07:28 2003 UTC (22 years, 3 months ago) by greg
Changes since 2.9: +57 -5 lines
Thu Jun 6 10:23:28 1996 UTC (28 years, 11 months ago) by greg
minor fix in comment
Thu Apr 11 15:59:56 1996 UTC (29 years, 1 month ago) by greg
Changes since 2.7: +25 -7 lines
added better computation of apparent distance for bright reflections
Thu Jan 13 09:45:10 1994 UTC (31 years, 4 months ago) by greg
added missing material function return values
Tue Aug 24 12:59:24 1993 UTC (31 years, 9 months ago) by greg
fixed potential use of unassigned transdist when bright(r->rcol)<0
Mon Nov 30 12:02:54 1992 UTC (32 years, 6 months ago) by greg
fixed comment terminology
Wed Oct 14 12:27:47 1992 UTC (32 years, 7 months ago) by greg
added test for illegal perturbation
Fri Oct 2 16:17:31 1992 UTC (32 years, 7 months ago) by greg
Wed May 20 10:24:26 1992 UTC (33 years ago) by greg
Changes since 2.1: +2 -1 lines
fixed perturbation of transmitted ray to consider both sides
Tue Nov 12 17:09:32 1991 UTC (33 years, 6 months ago) by greg
Diff to previous 1.12 , to selected 2.4
Tue Oct 29 16:36:44 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.11: +15 -8 lines
Diff to previous 1.11 , to selected 2.4
added option for fourth argument -- refractive index
Tue Oct 29 16:30:46 1991 UTC (33 years, 7 months ago) by greg
Changes since 1.10: +9 -6 lines
Diff to previous 1.10 , to selected 2.4
improved accuracy through separate treatment of polarizations
Mon Aug 12 08:20:57 1991 UTC (33 years, 9 months ago) by greg
Diff to previous 1.9 , to selected 2.4
fixed source tracing
Thu Jun 13 13:58:20 1991 UTC (33 years, 11 months ago) by greg
Changes since 1.8: +0 -1 lines
Diff to previous 1.8 , to selected 2.4
Fri May 10 08:51:00 1991 UTC (34 years ago) by greg
Changes since 1.7: +3 -1 lines
Diff to previous 1.7 , to selected 2.4
fixed bug introduced by better trans distance comp.
Wed May 8 08:27:46 1991 UTC (34 years ago) by greg
Changes since 1.6: +13 -6 lines
Diff to previous 1.6 , to selected 2.4
fixed code for determining when to use trans distance
Tue May 7 17:45:51 1991 UTC (34 years ago) by greg
Changes since 1.5: +3 -1 lines
Diff to previous 1.5 , to selected 2.4
changed trans types to modify transmitted color
and added perturbation to transmitted ray direction
Mon Oct 15 20:39:32 1990 UTC (34 years, 7 months ago) by greg
Changes since 1.4: +3 -6 lines
Diff to previous 1.4 , to selected 2.4
improved setting of rt RAY parameter
Wed May 30 19:57:01 1990 UTC (35 years ago) by greg
Changes since 1.3: +4 -1 lines
Diff to previous 1.3 , to selected 2.4
improved computation of r->rt using brightness comparison
Tue Mar 27 11:40:00 1990 UTC (35 years, 2 months ago) by greg
Changes since 1.2: +4 -0 lines
Diff to previous 1.2 , to selected 2.4
Wed Jun 7 08:38:33 1989 UTC (35 years, 11 months ago) by greg
Diff to previous 1.1 , to selected 2.4
Thu Feb 2 10:41:24 1989 UTC (36 years, 3 months ago) by greg
Diff to selected 2.4
