--- ray/src/rt/glass.c 1991/05/08 08:27:46 1.7 +++ ray/src/rt/glass.c 2015/05/20 13:11:25 2.24 @@ -1,16 +1,16 @@ -/* Copyright (c) 1991 Regents of the University of California */ - #ifndef lint -static char SCCSid[] = "$SunId$ LBL"; +static const char RCSid[] = "$Id: glass.c,v 2.24 2015/05/20 13:11:25 rschregle Exp $"; #endif - /* * glass.c - simpler shading function for thin glass surfaces. - * - * 11/14/86 */ +#include "copyright.h" + #include "ray.h" +#include "otypes.h" +#include "rtotypes.h" +#include "pmapmat.h" /* * This definition of glass provides for a quick calculation @@ -24,14 +24,17 @@ static char SCCSid[] = "$SunId$ LBL"; * modifier glass id * 0 * 0 - * 3 red grn blu + * 3+ red grn blu [refractive_index] * * The color is used for the transmission at normal incidence. - * To compute transmission (tn) from transmissivity (Tn) use: + * To compute transmissivity (tn) from transmittance (Tn) use: * * tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn * - * The transmission of standard 88% transmissivity glass is 0.96. + * The transmissivity of standard 88% transmittance glass is 0.96. + * A refractive index other than the default can be used by giving + * it as the fourth real argument. The above formula no longer applies. + * * If we appear to hit the back side of the surface, then we * turn the normal around. */ @@ -39,81 +42,132 @@ static char SCCSid[] = "$SunId$ LBL"; #define RINDEX 1.52 /* refractive index of glass */ -m_glass(m, r) /* color a ray which hit a thin glass surface */ -OBJREC *m; -register RAY *r; +int +m_glass( /* color a ray which hit a thin glass surface */ + OBJREC *m, + RAY *r +) { - double sqrt(), pow(); COLOR mcolor; double pdot; FVECT pnorm; - double cos2; + double rindex=0, cos2; COLOR trans, refl; - double d, r1; + int hastexture, hastrans; + double d, r1e, r1m; double transtest, transdist; + double mirtest, mirdist; RAY p; - register int i; + int i; - if (m->oargs.nfargs != 3) + /* PMAP: skip refracted shadow or ambient ray if accounted for in + photon map */ + if (shadowRayInPmap(r) || ambRayInPmap(r)) + return(1); + /* check arguments */ + if (m->oargs.nfargs == 3) + rindex = RINDEX; /* default value of n */ + else if (m->oargs.nfargs == 4) + rindex = m->oargs.farg[3]; /* use their value */ + else objerror(m, USER, "bad arguments"); - + /* check back face visibility */ + if (!backvis && r->rod <= 0.0) { + raytrans(r); + return(1); + } + /* check transmission */ setcolor(mcolor, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]); - - if (r->rod < 0.0) /* reorient if necessary */ - flipsurface(r); - r->rt = r->rot; /* default ray length */ - transtest = 0; + if ((hastrans = (intens(mcolor) > 1e-15))) { + for (i = 0; i < 3; i++) + if (colval(mcolor,i) < 1e-15) + colval(mcolor,i) = 1e-15; + } else if (r->crtype & SHADOW) + return(1); /* get modifiers */ raytexture(r, m->omod); - pdot = raynormal(pnorm, r); + if (r->rod < 0.0) /* reorient if necessary */ + flipsurface(r); + mirtest = transtest = 0; + mirdist = transdist = r->rot; + /* perturb normal */ + if ( (hastexture = (DOT(r->pert,r->pert) > FTINY*FTINY)) ) { + pdot = raynormal(pnorm, r); + } else { + VCOPY(pnorm, r->ron); + pdot = r->rod; + } /* angular transmission */ - cos2 = sqrt( (1.0-1.0/RINDEX/RINDEX) + - pdot*pdot/(RINDEX*RINDEX) ); - setcolor(mcolor, pow(colval(mcolor,RED), 1.0/cos2), - pow(colval(mcolor,GRN), 1.0/cos2), - pow(colval(mcolor,BLU), 1.0/cos2)); + cos2 = sqrt( (1.0-1.0/(rindex*rindex)) + + pdot*pdot/(rindex*rindex) ); + if (hastrans) + setcolor(mcolor, pow(colval(mcolor,RED), 1.0/cos2), + pow(colval(mcolor,GRN), 1.0/cos2), + pow(colval(mcolor,BLU), 1.0/cos2)); /* compute reflection */ - r1 = (pdot - RINDEX*cos2) / (pdot + RINDEX*cos2); - d = (1.0/pdot - RINDEX/cos2) / (1.0/pdot + RINDEX/cos2); - r1 = (r1*r1 + d*d) / 2.0; - /* compute transmittance */ - for (i = 0; i < 3; i++) { - d = colval(mcolor, i); - colval(trans,i) = (1.0-r1)*(1.0-r1)*d / (1.0 - r1*r1*d*d); - } + r1e = (pdot - rindex*cos2) / (pdot + rindex*cos2); + r1e *= r1e; + r1m = (1.0/pdot - rindex/cos2) / (1.0/pdot + rindex/cos2); + r1m *= r1m; + /* compute transmission */ + if (hastrans) { + for (i = 0; i < 3; i++) { + d = colval(mcolor, i); + colval(trans,i) = .5*(1.0-r1e)*(1.0-r1e)*d / + (1.0-r1e*r1e*d*d); + colval(trans,i) += .5*(1.0-r1m)*(1.0-r1m)*d / + (1.0-r1m*r1m*d*d); + } + multcolor(trans, r->pcol); /* modify by pattern */ /* transmitted ray */ - if (rayorigin(&p, r, TRANS, bright(trans)) == 0) { - if (DOT(r->pert,r->pert) > FTINY*FTINY) { - for (i = 0; i < 3; i++) /* perturb direction */ - p.rdir[i] = r->rdir[i] - r->pert[i]/RINDEX; - normalize(p.rdir); - } else - transtest = 2; - rayvalue(&p); - multcolor(p.rcol, r->pcol); /* modify */ - multcolor(p.rcol, trans); - addcolor(r->rcol, p.rcol); - transtest *= bright(p.rcol); - transdist = r->rot + p.rt; + if (rayorigin(&p, TRANS, r, trans) == 0) { + if (!(r->crtype & (SHADOW|AMBIENT)) && hastexture) { + VSUM(p.rdir, r->rdir, r->pert, 2.*(1.-rindex)); + if (normalize(p.rdir) == 0.0) { + objerror(m, WARNING, "bad perturbation"); + VCOPY(p.rdir, r->rdir); + } + } else { + VCOPY(p.rdir, r->rdir); + transtest = 2; + } + rayvalue(&p); + multcolor(p.rcol, p.rcoef); + addcolor(r->rcol, p.rcol); + transtest *= bright(p.rcol); + transdist = r->rot + p.rt; + } } - - if (r->crtype & SHADOW) /* skip reflected ray */ - return; + if (r->crtype & SHADOW) { /* skip reflected ray */ + r->rt = transdist; + return(1); + } /* compute reflectance */ for (i = 0; i < 3; i++) { d = colval(mcolor, i); d *= d; - colval(refl,i) = r1 * (1.0 + (1.0-2.0*r1)*d) / (1.0 - r1*r1*d); + colval(refl,i) = .5*r1e*(1.0+(1.0-2.0*r1e)*d)/(1.0-r1e*r1e*d); + colval(refl,i) += .5*r1m*(1.0+(1.0-2.0*r1m)*d)/(1.0-r1m*r1m*d); } /* reflected ray */ - if (rayorigin(&p, r, REFLECTED, bright(refl)) == 0) { - for (i = 0; i < 3; i++) - p.rdir[i] = r->rdir[i] + 2.0*pdot*pnorm[i]; + if (rayorigin(&p, REFLECTED, r, refl) == 0) { + VSUM(p.rdir, r->rdir, pnorm, 2.*pdot); + checknorm(p.rdir); rayvalue(&p); - multcolor(p.rcol, refl); + multcolor(p.rcol, p.rcoef); addcolor(r->rcol, p.rcol); + if (r->ro != NULL && isflat(r->ro->otype) && + !hastexture | (r->crtype & AMBIENT)) { + mirtest = 2.0*bright(p.rcol); + mirdist = r->rot + p.rt; + } } - if (transtest > bright(r->rcol)) + /* check distance */ + d = bright(r->rcol); + if (transtest > d) r->rt = transdist; + else if (mirtest > d) + r->rt = mirdist; + return(1); }
