1 |
/* Copyright (c) 1991 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* glass.c - simpler shading function for thin glass surfaces. |
9 |
10 |
* 11/14/86 |
11 |
12 |
13 |
#include "ray.h" |
14 |
15 |
16 |
* This definition of glass provides for a quick calculation |
17 |
* using a single surface where two closely spaced parallel |
18 |
* dielectric surfaces would otherwise be used. The chief |
19 |
* advantage to using this material is speed, since internal |
20 |
* reflections are avoided. |
21 |
22 |
* The specification for glass is as follows: |
23 |
24 |
* modifier glass id |
25 |
* 0 |
26 |
* 0 |
27 |
* 3 red grn blu |
28 |
29 |
* The color is used for the transmission at normal incidence. |
30 |
* To compute transmission (tn) from transmissivity (Tn) use: |
31 |
32 |
* tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn |
33 |
34 |
* The transmission of standard 88% transmissivity glass is 0.96. |
35 |
* A refractive index other than the default can be used by giving |
36 |
* it as the fourth real argument. The above formula no longer applies. |
37 |
38 |
* If we appear to hit the back side of the surface, then we |
39 |
* turn the normal around. |
40 |
41 |
42 |
#define RINDEX 1.52 /* refractive index of glass */ |
43 |
44 |
45 |
m_glass(m, r) /* color a ray which hit a thin glass surface */ |
46 |
OBJREC *m; |
47 |
register RAY *r; |
48 |
49 |
double sqrt(), pow(); |
50 |
COLOR mcolor; |
51 |
double pdot; |
52 |
FVECT pnorm; |
53 |
double rindex, cos2; |
54 |
COLOR trans, refl; |
55 |
double d, r1e, r1m; |
56 |
double transtest, transdist; |
57 |
RAY p; |
58 |
register int i; |
59 |
/* check arguments */ |
60 |
if (m->oargs.nfargs == 3) |
61 |
rindex = RINDEX; /* default value of n */ |
62 |
else if (m->oargs.nfargs == 4) |
63 |
rindex = m->oargs.farg[3]; /* use their value */ |
64 |
else |
65 |
objerror(m, USER, "bad arguments"); |
66 |
67 |
setcolor(mcolor, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]); |
68 |
69 |
if (r->rod < 0.0) /* reorient if necessary */ |
70 |
flipsurface(r); |
71 |
transtest = 0; |
72 |
/* get modifiers */ |
73 |
raytexture(r, m->omod); |
74 |
pdot = raynormal(pnorm, r); |
75 |
/* angular transmission */ |
76 |
cos2 = sqrt( (1.0-1.0/(rindex*rindex)) + |
77 |
pdot*pdot/(rindex*rindex) ); |
78 |
setcolor(mcolor, pow(colval(mcolor,RED), 1.0/cos2), |
79 |
pow(colval(mcolor,GRN), 1.0/cos2), |
80 |
pow(colval(mcolor,BLU), 1.0/cos2)); |
81 |
82 |
/* compute reflection */ |
83 |
r1e = (pdot - rindex*cos2) / (pdot + rindex*cos2); |
84 |
r1e *= r1e; |
85 |
r1m = (1.0/pdot - rindex/cos2) / (1.0/pdot + rindex/cos2); |
86 |
r1m *= r1m; |
87 |
/* compute transmittance */ |
88 |
for (i = 0; i < 3; i++) { |
89 |
d = colval(mcolor, i); |
90 |
colval(trans,i) = .5*(1.0-r1e)*(1.0-r1e)*d/(1.0-r1e*r1e*d*d); |
91 |
colval(trans,i) += .5*(1.0-r1m)*(1.0-r1m)*d/(1.0-r1m*r1m*d*d); |
92 |
93 |
/* transmitted ray */ |
94 |
if (rayorigin(&p, r, TRANS, bright(trans)) == 0) { |
95 |
if (!(r->crtype & SHADOW) && |
96 |
DOT(r->pert,r->pert) > FTINY*FTINY) { |
97 |
for (i = 0; i < 3; i++) /* perturb direction */ |
98 |
p.rdir[i] = r->rdir[i] + |
99 |
2.*(1.-rindex)*r->pert[i]; |
100 |
normalize(p.rdir); |
101 |
} else { |
102 |
VCOPY(p.rdir, r->rdir); |
103 |
transtest = 2; |
104 |
105 |
rayvalue(&p); |
106 |
multcolor(p.rcol, r->pcol); /* modify */ |
107 |
multcolor(p.rcol, trans); |
108 |
addcolor(r->rcol, p.rcol); |
109 |
transtest *= bright(p.rcol); |
110 |
transdist = r->rot + p.rt; |
111 |
112 |
113 |
if (r->crtype & SHADOW) /* skip reflected ray */ |
114 |
return; |
115 |
/* compute reflectance */ |
116 |
117 |
118 |
d *= d; |
119 |
colval(refl,i) = .5*r1e*(1.0+(1.0-2.0*r1e)*d)/(1.0-r1e*r1e*d); |
120 |
colval(refl,i) += .5*r1m*(1.0+(1.0-2.0*r1m)*d)/(1.0-r1m*r1m*d); |
121 |
122 |
/* reflected ray */ |
123 |
if (rayorigin(&p, r, REFLECTED, bright(refl)) == 0) { |
124 |
for (i = 0; i < 3; i++) |
125 |
p.rdir[i] = r->rdir[i] + 2.0*pdot*pnorm[i]; |
126 |
rayvalue(&p); |
127 |
multcolor(p.rcol, refl); |
128 |
129 |
130 |
if (transtest > bright(r->rcol)) |
131 |
r->rt = transdist; |
132 |
