| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: glass.c,v 2.25 2015/05/21 13:54:59 greg Exp $";
| 3 |
#endif
| 4 |
| 5 |
* glass.c - simpler shading function for thin glass surfaces.
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include "ray.h"
| 11 |
#include "otypes.h"
| 12 |
#include "rtotypes.h"
| 13 |
#include "pmapmat.h"
| 14 |
| 15 |
| 16 |
* This definition of glass provides for a quick calculation
| 17 |
* using a single surface where two closely spaced parallel
| 18 |
* dielectric surfaces would otherwise be used. The chief
| 19 |
* advantage to using this material is speed, since internal
| 20 |
* reflections are avoided.
| 21 |
| 22 |
* The specification for glass is as follows:
| 23 |
| 24 |
* modifier glass id
| 25 |
* 0
| 26 |
* 0
| 27 |
* 3+ red grn blu [refractive_index]
| 28 |
| 29 |
* The color is used for the transmission at normal incidence.
| 30 |
* To compute transmissivity (tn) from transmittance (Tn) use:
| 31 |
| 32 |
* tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn
| 33 |
| 34 |
* The transmissivity of standard 88% transmittance glass is 0.96.
| 35 |
* A refractive index other than the default can be used by giving
| 36 |
* it as the fourth real argument. The above formula no longer applies.
| 37 |
| 38 |
* If we appear to hit the back side of the surface, then we
| 39 |
* turn the normal around.
| 40 |
| 41 |
| 42 |
#define RINDEX 1.52 /* refractive index of glass */
| 43 |
| 44 |
| 45 |
int
| 46 |
m_glass( /* color a ray which hit a thin glass surface */
| 47 |
OBJREC *m,
| 48 |
RAY *r
| 49 |
| 50 |
| 51 |
COLOR mcolor;
| 52 |
double pdot;
| 53 |
FVECT pnorm;
| 54 |
double rindex=0, cos2;
| 55 |
COLOR trans, refl;
| 56 |
int hastexture, hastrans;
| 57 |
double d, r1e, r1m;
| 58 |
double transtest, transdist;
| 59 |
double mirtest, mirdist;
| 60 |
RAY p;
| 61 |
int i;
| 62 |
| 63 |
/* PMAP: skip refracted shadow or ambient ray if accounted for in
| 64 |
photon map */
| 65 |
if (shadowRayInPmap(r) || ambRayInPmap(r))
| 66 |
return(1);
| 67 |
/* check arguments */
| 68 |
if (m->oargs.nfargs == 3)
| 69 |
rindex = RINDEX; /* default value of n */
| 70 |
else if (m->oargs.nfargs == 4)
| 71 |
rindex = m->oargs.farg[3]; /* use their value */
| 72 |
else
| 73 |
objerror(m, USER, "bad arguments");
| 74 |
/* check back face visibility */
| 75 |
if (!backvis && r->rod <= 0.0) {
| 76 |
raytrans(r);
| 77 |
return(1);
| 78 |
| 79 |
/* check transmission */
| 80 |
setcolor(mcolor, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]);
| 81 |
if ((hastrans = (intens(mcolor) > 1e-15))) {
| 82 |
for (i = 0; i < 3; i++)
| 83 |
if (colval(mcolor,i) < 1e-15)
| 84 |
colval(mcolor,i) = 1e-15;
| 85 |
} else if (r->crtype & SHADOW)
| 86 |
return(1);
| 87 |
/* get modifiers */
| 88 |
raytexture(r, m->omod);
| 89 |
if (r->rod < 0.0) /* reorient if necessary */
| 90 |
flipsurface(r);
| 91 |
mirtest = transtest = 0;
| 92 |
mirdist = transdist = r->rot;
| 93 |
/* perturb normal */
| 94 |
if ( (hastexture = (DOT(r->pert,r->pert) > FTINY*FTINY)) ) {
| 95 |
pdot = raynormal(pnorm, r);
| 96 |
} else {
| 97 |
VCOPY(pnorm, r->ron);
| 98 |
pdot = r->rod;
| 99 |
| 100 |
/* angular transmission */
| 101 |
cos2 = sqrt( (1.0-1.0/(rindex*rindex)) +
| 102 |
pdot*pdot/(rindex*rindex) );
| 103 |
if (hastrans)
| 104 |
setcolor(mcolor, pow(colval(mcolor,RED), 1.0/cos2),
| 105 |
pow(colval(mcolor,GRN), 1.0/cos2),
| 106 |
pow(colval(mcolor,BLU), 1.0/cos2));
| 107 |
| 108 |
/* compute reflection */
| 109 |
r1e = (pdot - rindex*cos2) / (pdot + rindex*cos2);
| 110 |
r1e *= r1e;
| 111 |
r1m = (1.0/pdot - rindex/cos2) / (1.0/pdot + rindex/cos2);
| 112 |
r1m *= r1m;
| 113 |
/* compute transmission */
| 114 |
if (hastrans) {
| 115 |
for (i = 0; i < 3; i++) {
| 116 |
d = colval(mcolor, i);
| 117 |
colval(trans,i) = .5*(1.0-r1e)*(1.0-r1e)*d /
| 118 |
(1.0-r1e*r1e*d*d);
| 119 |
colval(trans,i) += .5*(1.0-r1m)*(1.0-r1m)*d /
| 120 |
(1.0-r1m*r1m*d*d);
| 121 |
| 122 |
multcolor(trans, r->pcol); /* modify by pattern */
| 123 |
/* transmitted ray */
| 124 |
if (rayorigin(&p, TRANS, r, trans) == 0) {
| 125 |
if (!(r->crtype & (SHADOW|AMBIENT)) && hastexture) {
| 126 |
VSUM(p.rdir, r->rdir, r->pert, 2.*(1.-rindex));
| 127 |
if (normalize(p.rdir) == 0.0) {
| 128 |
objerror(m, WARNING, "bad perturbation");
| 129 |
VCOPY(p.rdir, r->rdir);
| 130 |
| 131 |
} else {
| 132 |
| 133 |
transtest = 2;
| 134 |
| 135 |
rayvalue(&p);
| 136 |
multcolor(p.rcol, p.rcoef);
| 137 |
addcolor(r->rcol, p.rcol);
| 138 |
transtest *= bright(p.rcol);
| 139 |
transdist = r->rot + p.rt;
| 140 |
| 141 |
| 142 |
if (r->crtype & SHADOW) { /* skip reflected ray */
| 143 |
r->rt = transdist;
| 144 |
return(1);
| 145 |
| 146 |
/* compute reflectance */
| 147 |
| 148 |
| 149 |
d *= d;
| 150 |
colval(refl,i) = .5*r1e*(1.0+(1.0-2.0*r1e)*d)/(1.0-r1e*r1e*d);
| 151 |
colval(refl,i) += .5*r1m*(1.0+(1.0-2.0*r1m)*d)/(1.0-r1m*r1m*d);
| 152 |
| 153 |
/* reflected ray */
| 154 |
if (rayorigin(&p, REFLECTED, r, refl) == 0) {
| 155 |
VSUM(p.rdir, r->rdir, pnorm, 2.*pdot);
| 156 |
checknorm(p.rdir);
| 157 |
rayvalue(&p);
| 158 |
| 159 |
| 160 |
if (r->ro != NULL && isflat(r->ro->otype) &&
| 161 |
!hastexture | (r->crtype & AMBIENT)) {
| 162 |
mirtest = 2.0*bright(p.rcol);
| 163 |
mirdist = r->rot + p.rt;
| 164 |
| 165 |
| 166 |
/* check distance */
| 167 |
d = bright(r->rcol);
| 168 |
if (transtest > d)
| 169 |
r->rt = transdist;
| 170 |
else if (mirtest > d)
| 171 |
r->rt = mirdist;
| 172 |
return(1);
| 173 |
