root/Development/ray/src/rt/glass.c
Revision: 2.22
Committed: Sat May 10 17:43:01 2014 UTC (11 years, 6 months ago) by greg
CVS Tags: rad4R2P2, rad4R2P1, rad4R2
Changes since 2.21: +7 -6 lines
Fixed virtual distance so as not to undermine ambient calculation
# User Rev Content
1 greg 1.1 #ifndef lint
2 greg 2.22 static const char RCSid[] = "$Id: glass.c,v 2.21 2014/01/25 18:27:39 greg Exp $";
3 greg 1.1 #endif
4     /*
5     * glass.c - simpler shading function for thin glass surfaces.
6 greg 2.10 */
7
8 greg 2.11 #include "copyright.h"
9 greg 1.1
10     #include "ray.h"
11 greg 2.8 #include "otypes.h"
12 schorsch 2.15 #include "rtotypes.h"
13 greg 2.8
14 greg 1.1 /*
15     * This definition of glass provides for a quick calculation
16     * using a single surface where two closely spaced parallel
17     * dielectric surfaces would otherwise be used. The chief
18     * advantage to using this material is speed, since internal
19     * reflections are avoided.
20     *
21     * The specification for glass is as follows:
22     *
23     * modifier glass id
24     * 0
25     * 0
26 greg 2.9 * 3+ red grn blu [refractive_index]
27 greg 1.1 *
28     * The color is used for the transmission at normal incidence.
29 greg 2.5 * To compute transmissivity (tn) from transmittance (Tn) use:
30 greg 1.1 *
31     * tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn
32     *
33 greg 2.5 * The transmissivity of standard 88% transmittance glass is 0.96.
34 greg 1.12 * A refractive index other than the default can be used by giving
35     * it as the fourth real argument. The above formula no longer applies.
36     *
37 greg 1.1 * If we appear to hit the back side of the surface, then we
38     * turn the normal around.
39     */
40
41     #define RINDEX 1.52 /* refractive index of glass */
42
43
44 greg 2.22 int
45 schorsch 2.15 m_glass( /* color a ray which hit a thin glass surface */
46     OBJREC *m,
47 greg 2.22 RAY *r
48 schorsch 2.15 )
49 greg 1.1 {
50     COLOR mcolor;
51     double pdot;
52     FVECT pnorm;
53 greg 2.20 double rindex=0, cos2;
54 greg 1.1 COLOR trans, refl;
55 greg 2.17 int hastexture, hastrans;
56 greg 1.11 double d, r1e, r1m;
57 greg 1.7 double transtest, transdist;
58 greg 2.8 double mirtest, mirdist;
59 greg 1.1 RAY p;
60 greg 2.22 int i;
61 greg 1.12 /* check arguments */
62     if (m->oargs.nfargs == 3)
63     rindex = RINDEX; /* default value of n */
64     else if (m->oargs.nfargs == 4)
65     rindex = m->oargs.farg[3]; /* use their value */
66     else
67 greg 1.1 objerror(m, USER, "bad arguments");
68 greg 2.21 /* check back face visibility */
69     if (!backvis && r->rod <= 0.0) {
70     raytrans(r);
71     return(1);
72     }
73 greg 2.17 /* check transmission */
74 greg 1.1 setcolor(mcolor, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]);
75 greg 2.17 if ((hastrans = (intens(mcolor) > 1e-15))) {
76     for (i = 0; i < 3; i++)
77     if (colval(mcolor,i) < 1e-15)
78     colval(mcolor,i) = 1e-15;
79     } else if (r->crtype & SHADOW)
80     return(1);
81 greg 2.12 /* get modifiers */
82     raytexture(r, m->omod);
83 greg 1.1 if (r->rod < 0.0) /* reorient if necessary */
84     flipsurface(r);
85 greg 2.8 mirtest = transtest = 0;
86     mirdist = transdist = r->rot;
87 greg 2.12 /* perturb normal */
88 schorsch 2.14 if ( (hastexture = (DOT(r->pert,r->pert) > FTINY*FTINY)) ) {
89 greg 2.8 pdot = raynormal(pnorm, r);
90 greg 2.13 } else {
91 greg 2.8 VCOPY(pnorm, r->ron);
92     pdot = r->rod;
93     }
94 greg 1.1 /* angular transmission */
95 greg 1.12 cos2 = sqrt( (1.0-1.0/(rindex*rindex)) +
96     pdot*pdot/(rindex*rindex) );
97 greg 2.17 if (hastrans)
98     setcolor(mcolor, pow(colval(mcolor,RED), 1.0/cos2),
99     pow(colval(mcolor,GRN), 1.0/cos2),
100     pow(colval(mcolor,BLU), 1.0/cos2));
101 greg 1.1
102     /* compute reflection */
103 greg 1.12 r1e = (pdot - rindex*cos2) / (pdot + rindex*cos2);
104 greg 1.11 r1e *= r1e;
105 greg 1.12 r1m = (1.0/pdot - rindex/cos2) / (1.0/pdot + rindex/cos2);
106 greg 1.11 r1m *= r1m;
107 greg 2.17 /* compute transmission */
108     if (hastrans) {
109     for (i = 0; i < 3; i++) {
110     d = colval(mcolor, i);
111     colval(trans,i) = .5*(1.0-r1e)*(1.0-r1e)*d /
112     (1.0-r1e*r1e*d*d);
113     colval(trans,i) += .5*(1.0-r1m)*(1.0-r1m)*d /
114     (1.0-r1m*r1m*d*d);
115     }
116     multcolor(trans, r->pcol); /* modify by pattern */
117 greg 1.1 /* transmitted ray */
118 greg 2.17 if (rayorigin(&p, TRANS, r, trans) == 0) {
119 greg 2.22 if (!(r->crtype & (SHADOW|AMBIENT)) && hastexture) {
120 greg 2.19 VSUM(p.rdir, r->rdir, r->pert, 2.*(1.-rindex));
121 greg 2.17 if (normalize(p.rdir) == 0.0) {
122     objerror(m, WARNING, "bad perturbation");
123     VCOPY(p.rdir, r->rdir);
124     }
125     } else {
126 greg 2.4 VCOPY(p.rdir, r->rdir);
127 greg 2.17 transtest = 2;
128 greg 2.4 }
129 greg 2.17 rayvalue(&p);
130     multcolor(p.rcol, p.rcoef);
131     addcolor(r->rcol, p.rcol);
132     transtest *= bright(p.rcol);
133     transdist = r->rot + p.rt;
134 greg 1.8 }
135 greg 1.1 }
136 greg 2.8 if (r->crtype & SHADOW) { /* skip reflected ray */
137     r->rt = transdist;
138 greg 2.7 return(1);
139 greg 2.8 }
140 greg 1.1 /* compute reflectance */
141     for (i = 0; i < 3; i++) {
142     d = colval(mcolor, i);
143     d *= d;
144 greg 1.11 colval(refl,i) = .5*r1e*(1.0+(1.0-2.0*r1e)*d)/(1.0-r1e*r1e*d);
145     colval(refl,i) += .5*r1m*(1.0+(1.0-2.0*r1m)*d)/(1.0-r1m*r1m*d);
146 greg 1.1 }
147     /* reflected ray */
148 greg 2.16 if (rayorigin(&p, REFLECTED, r, refl) == 0) {
149 greg 2.19 VSUM(p.rdir, r->rdir, pnorm, 2.*pdot);
150 greg 2.18 checknorm(p.rdir);
151 greg 1.1 rayvalue(&p);
152 greg 2.16 multcolor(p.rcol, p.rcoef);
153 greg 1.1 addcolor(r->rcol, p.rcol);
154 greg 2.22 if (r->ro != NULL && isflat(r->ro->otype) &&
155     !hastexture | (r->crtype & AMBIENT)) {
156 greg 2.8 mirtest = 2.0*bright(p.rcol);
157     mirdist = r->rot + p.rt;
158     }
159 greg 1.1 }
160 greg 2.8 /* check distance */
161     d = bright(r->rcol);
162     if (transtest > d)
163 greg 1.7 r->rt = transdist;
164 greg 2.8 else if (mirtest > d)
165     r->rt = mirdist;
166 greg 2.7 return(1);
167 greg 1.1 }
