1 |
/* Copyright (c) 1986 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* glass.c - simpler shading function for thin glass surfaces. |
9 |
10 |
* 11/14/86 |
11 |
12 |
13 |
#include "ray.h" |
14 |
15 |
16 |
* This definition of glass provides for a quick calculation |
17 |
* using a single surface where two closely spaced parallel |
18 |
* dielectric surfaces would otherwise be used. The chief |
19 |
* advantage to using this material is speed, since internal |
20 |
* reflections are avoided. |
21 |
22 |
* The specification for glass is as follows: |
23 |
24 |
* modifier glass id |
25 |
* 0 |
26 |
* 0 |
27 |
* 3 red grn blu |
28 |
29 |
* The color is used for the transmission at normal incidence. |
30 |
* To compute transmission (tn) from transmissivity (Tn) use: |
31 |
32 |
* tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn |
33 |
34 |
* The transmission of standard 88% transmissivity glass is 0.96. |
35 |
* If we appear to hit the back side of the surface, then we |
36 |
* turn the normal around. |
37 |
38 |
39 |
#define RINDEX 1.52 /* refractive index of glass */ |
40 |
41 |
42 |
m_glass(m, r) /* color a ray which hit a thin glass surface */ |
43 |
OBJREC *m; |
44 |
register RAY *r; |
45 |
46 |
double sqrt(), pow(); |
47 |
COLOR mcolor; |
48 |
double pdot; |
49 |
FVECT pnorm; |
50 |
double cos2; |
51 |
COLOR trans, refl; |
52 |
double d, r1; |
53 |
RAY p; |
54 |
register int i; |
55 |
56 |
if (m->oargs.nfargs != 3) |
57 |
objerror(m, USER, "bad arguments"); |
58 |
59 |
setcolor(mcolor, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]); |
60 |
61 |
if (r->rod < 0.0) /* reorient if necessary */ |
62 |
flipsurface(r); |
63 |
/* get modifiers */ |
64 |
raytexture(r, m->omod); |
65 |
pdot = raynormal(pnorm, r); |
66 |
/* angular transmission */ |
67 |
cos2 = sqrt( (1.0-1.0/RINDEX/RINDEX) + |
68 |
pdot*pdot/(RINDEX*RINDEX) ); |
69 |
setcolor(mcolor, pow(colval(mcolor,RED), 1.0/cos2), |
70 |
pow(colval(mcolor,GRN), 1.0/cos2), |
71 |
pow(colval(mcolor,BLU), 1.0/cos2)); |
72 |
73 |
/* compute reflection */ |
74 |
r1 = (pdot - RINDEX*cos2) / (pdot + RINDEX*cos2); |
75 |
d = (1.0/pdot - RINDEX/cos2) / (1.0/pdot + RINDEX/cos2); |
76 |
r1 = (r1*r1 + d*d) / 2.0; |
77 |
/* compute transmittance */ |
78 |
for (i = 0; i < 3; i++) { |
79 |
d = colval(mcolor, i); |
80 |
colval(trans,i) = (1.0-r1)*(1.0-r1)*d / (1.0 - r1*r1*d*d); |
81 |
82 |
/* transmitted ray */ |
83 |
if (rayorigin(&p, r, TRANS, bright(trans)) == 0) { |
84 |
VCOPY(p.rdir, r->rdir); |
85 |
rayvalue(&p); |
86 |
multcolor(p.rcol, r->pcol); /* modify */ |
87 |
multcolor(p.rcol, trans); |
88 |
addcolor(r->rcol, p.rcol); |
89 |
90 |
if (r->crtype & SHADOW) /* skip reflected ray */ |
91 |
return; |
92 |
/* compute reflectance */ |
93 |
94 |
95 |
d *= d; |
96 |
colval(refl,i) = r1 * (1.0 + (1.0-2.0*r1)*d) / (1.0 - r1*r1*d); |
97 |
98 |
/* reflected ray */ |
99 |
if (rayorigin(&p, r, REFLECTED, bright(refl)) == 0) { |
100 |
for (i = 0; i < 3; i++) |
101 |
p.rdir[i] = r->rdir[i] + 2.0*pdot*pnorm[i]; |
102 |
rayvalue(&p); |
103 |
multcolor(p.rcol, refl); |
104 |
105 |
106 |
