--- ray/src/rt/glass.c 1991/05/08 08:27:46 1.7 +++ ray/src/rt/glass.c 1991/11/12 17:09:32 2.1 @@ -32,6 +32,9 @@ static char SCCSid[] = "$SunId$ LBL"; * tn = (sqrt(.8402528435+.0072522239*Tn*Tn)-.9166530661)/.0036261119/Tn * * The transmission of standard 88% transmissivity glass is 0.96. + * A refractive index other than the default can be used by giving + * it as the fourth real argument. The above formula no longer applies. + * * If we appear to hit the back side of the surface, then we * turn the normal around. */ @@ -47,49 +50,57 @@ register RAY *r; COLOR mcolor; double pdot; FVECT pnorm; - double cos2; + double rindex, cos2; COLOR trans, refl; - double d, r1; + double d, r1e, r1m; double transtest, transdist; RAY p; register int i; - - if (m->oargs.nfargs != 3) + /* check arguments */ + if (m->oargs.nfargs == 3) + rindex = RINDEX; /* default value of n */ + else if (m->oargs.nfargs == 4) + rindex = m->oargs.farg[3]; /* use their value */ + else objerror(m, USER, "bad arguments"); setcolor(mcolor, m->oargs.farg[0], m->oargs.farg[1], m->oargs.farg[2]); if (r->rod < 0.0) /* reorient if necessary */ flipsurface(r); - r->rt = r->rot; /* default ray length */ transtest = 0; /* get modifiers */ raytexture(r, m->omod); pdot = raynormal(pnorm, r); /* angular transmission */ - cos2 = sqrt( (1.0-1.0/RINDEX/RINDEX) + - pdot*pdot/(RINDEX*RINDEX) ); + cos2 = sqrt( (1.0-1.0/(rindex*rindex)) + + pdot*pdot/(rindex*rindex) ); setcolor(mcolor, pow(colval(mcolor,RED), 1.0/cos2), pow(colval(mcolor,GRN), 1.0/cos2), pow(colval(mcolor,BLU), 1.0/cos2)); /* compute reflection */ - r1 = (pdot - RINDEX*cos2) / (pdot + RINDEX*cos2); - d = (1.0/pdot - RINDEX/cos2) / (1.0/pdot + RINDEX/cos2); - r1 = (r1*r1 + d*d) / 2.0; + r1e = (pdot - rindex*cos2) / (pdot + rindex*cos2); + r1e *= r1e; + r1m = (1.0/pdot - rindex/cos2) / (1.0/pdot + rindex/cos2); + r1m *= r1m; /* compute transmittance */ for (i = 0; i < 3; i++) { d = colval(mcolor, i); - colval(trans,i) = (1.0-r1)*(1.0-r1)*d / (1.0 - r1*r1*d*d); + colval(trans,i) = .5*(1.0-r1e)*(1.0-r1e)*d/(1.0-r1e*r1e*d*d); + colval(trans,i) += .5*(1.0-r1m)*(1.0-r1m)*d/(1.0-r1m*r1m*d*d); } /* transmitted ray */ if (rayorigin(&p, r, TRANS, bright(trans)) == 0) { - if (DOT(r->pert,r->pert) > FTINY*FTINY) { + if (!(r->crtype & SHADOW) && + DOT(r->pert,r->pert) > FTINY*FTINY) { for (i = 0; i < 3; i++) /* perturb direction */ - p.rdir[i] = r->rdir[i] - r->pert[i]/RINDEX; + p.rdir[i] = r->rdir[i] - r->pert[i]/rindex; normalize(p.rdir); - } else + } else { + VCOPY(p.rdir, r->rdir); transtest = 2; + } rayvalue(&p); multcolor(p.rcol, r->pcol); /* modify */ multcolor(p.rcol, trans); @@ -104,7 +115,8 @@ register RAY *r; for (i = 0; i < 3; i++) { d = colval(mcolor, i); d *= d; - colval(refl,i) = r1 * (1.0 + (1.0-2.0*r1)*d) / (1.0 - r1*r1*d); + colval(refl,i) = .5*r1e*(1.0+(1.0-2.0*r1e)*d)/(1.0-r1e*r1e*d); + colval(refl,i) += .5*r1m*(1.0+(1.0-2.0*r1m)*d)/(1.0-r1m*r1m*d); } /* reflected ray */ if (rayorigin(&p, r, REFLECTED, bright(refl)) == 0) {
