Changed call order for proper function of two-sided, textured surfaces
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
minor fix in comment
added better computation of apparent distance for bright reflections
added missing material function return values
fixed potential use of unassigned transdist when bright(r->rcol)<0
fixed comment terminology
added test for illegal perturbation
fixed perturbation of transmitted ray to consider both sides
added option for fourth argument -- refractive index
improved accuracy through separate treatment of polarizations
fixed source tracing
fixed bug introduced by better trans distance comp.
fixed code for determining when to use trans distance
changed trans types to modify transmitted color and added perturbation to transmitted ray direction
improved setting of rt RAY parameter
improved computation of r->rt using brightness comparison
