root/radiance/ray/src/rt/func.h
Wed May 20 12:58:31 2015 UTC (9 years, 9 months ago) by greg
CVS Tags: rad5R0, rad5R1, rad5R2, rad5R3, rad5R4
Added appropriate setting of ray parameters for bin rcontrib evaluation
Sat Jun 9 07:16:47 2012 UTC (12 years, 9 months ago) by greg
Changes since 2.8: +4 -3 lines
Fri Feb 18 00:40:25 2011 UTC (14 years ago) by greg
Changes since 2.7: +5 -8 lines
Tue Mar 30 16:13:01 2004 UTC (20 years, 11 months ago) by schorsch
Changes since 2.6: +11 -2 lines
Mon Jul 14 22:24:00 2003 UTC (21 years, 8 months ago) by schorsch
Changes since 2.5: +4 -3 lines
Fri Jun 27 06:53:22 2003 UTC (21 years, 8 months ago) by greg
Changes since 2.4: +1 -4 lines
Sat Jun 7 00:54:58 2003 UTC (21 years, 9 months ago) by schorsch
Changes since 2.3: +12 -9 lines
Removed NOPROTO sections.
Tue Feb 25 02:47:22 2003 UTC (22 years ago) by greg
Changes since 2.2: +2 -57 lines
Sat Feb 22 02:07:28 2003 UTC (22 years ago) by greg
Changes since 2.1: +75 -6 lines
Diff to previous 2.1
Mon Nov 25 09:49:47 1991 UTC (33 years, 3 months ago) by greg
