--- ray/src/rt/func.h 2003/02/22 02:07:28 2.2 +++ ray/src/rt/func.h 2024/10/29 00:36:54 2.11 @@ -1,92 +1,46 @@ -/* RCSid: $Id: func.h,v 2.2 2003/02/22 02:07:28 greg Exp $ */ +/* RCSid $Id: func.h,v 2.11 2024/10/29 00:36:54 greg Exp $ */ /* * Header file for modifiers using function files. * * Include after ray.h */ +#ifndef _RAD_FUNC_H_ +#define _RAD_FUNC_H_ -/* ==================================================================== - * The Radiance Software License, Version 1.0 - * - * Copyright (c) 1990 - 2002 The Regents of the University of California, - * through Lawrence Berkeley National Laboratory. All rights reserved. - * - * Redistribution and use in source and binary forms, with or without - * modification, are permitted provided that the following conditions - * are met: - * - * 1. Redistributions of source code must retain the above copyright - * notice, this list of conditions and the following disclaimer. - * - * 2. Redistributions in binary form must reproduce the above copyright - * notice, this list of conditions and the following disclaimer in - * the documentation and/or other materials provided with the - * distribution. - * - * 3. The end-user documentation included with the redistribution, - * if any, must include the following acknowledgment: - * "This product includes Radiance software - * (http://radsite.lbl.gov/) - * developed by the Lawrence Berkeley National Laboratory - * (http://www.lbl.gov/)." - * Alternately, this acknowledgment may appear in the software itself, - * if and wherever such third-party acknowledgments normally appear. - * - * 4. The names "Radiance," "Lawrence Berkeley National Laboratory" - * and "The Regents of the University of California" must - * not be used to endorse or promote products derived from this - * software without prior written permission. For written - * permission, please contact radiance@radsite.lbl.gov. - * - * 5. Products derived from this software may not be called "Radiance", - * nor may "Radiance" appear in their name, without prior written - * permission of Lawrence Berkeley National Laboratory. - * - * THIS SOFTWARE IS PROVIDED ``AS IS'' AND ANY EXPRESSED OR IMPLIED - * WARRANTIES, INCLUDING, BUT NOT LIMITED TO, THE IMPLIED WARRANTIES - * OF MERCHANTABILITY AND FITNESS FOR A PARTICULAR PURPOSE ARE - * DISCLAIMED. IN NO EVENT SHALL Lawrence Berkeley National Laboratory OR - * ITS CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL, - * SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT - * LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF - * USE, DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND - * ON ANY THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, - * OR TORT (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT - * OF THE USE OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF - * SUCH DAMAGE. - * ==================================================================== - * - * This software consists of voluntary contributions made by many - * individuals on behalf of Lawrence Berkeley National Laboratory. For more - * information on Lawrence Berkeley National Laboratory, please see - * . - */ +#include "calcomp.h" -#include "calcomp.h" +#ifdef __cplusplus +extern "C" { +#endif #define MAXEXPR 9 /* maximum expressions in modifier */ typedef struct { EPNODE *ep[MAXEXPR+1]; /* NULL-terminated expression list */ char *ctx; /* context (from file name) */ - XF *f, *b; /* forward and backward transforms */ + XF *fxp, *bxp; /* forward and backward transforms */ } MFUNC; /* material function */ extern XF unitxf; /* identity transform */ extern XF funcxf; /* current transform */ -#ifdef NOPROTO - -extern MFUNC *getfunc(); -extern void freefunc(); -extern int setfunc(); -extern void loadfunc(); - -#else - +extern void initfunc(void); +extern void set_eparams(const char *prms); extern MFUNC *getfunc(OBJREC *m, int ff, unsigned int ef, int dofwd); extern void freefunc(OBJREC *m); extern int setfunc(OBJREC *m, RAY *r); +extern int worldfunc(const char *ctx, RAY *r); extern void loadfunc(char *fname); + /* defined in noise3.c */ +extern void setnoisefuncs(void); + + /* defined in fprism.c */ +extern void setprismfuncs(void); + + +#ifdef __cplusplus +} #endif +#endif /* _RAD_FUNC_H_ */ +
