root/radiance/ray/src/rt/func.h
Revision: 2.9
Committed: Sat Jun 9 07:16:47 2012 UTC (13 years, 1 month ago) by greg
Changes since 2.8: +4 -3 lines
1 /* RCSid $Id: func.h,v 2.8 2011/02/18 00:40:25 greg Exp $ */
2 /*
3 * Header file for modifiers using function files.
4 *
5 * Include after ray.h
6 */
7 #ifndef _RAD_FUNC_H_
8 #define _RAD_FUNC_H_
9
10 #include "calcomp.h"
11
12 #ifdef __cplusplus
13 extern "C" {
14 #endif
15
16 #define MAXEXPR 9 /* maximum expressions in modifier */
17
18 typedef struct {
19 EPNODE *ep[MAXEXPR+1]; /* NULL-terminated expression list */
20 char *ctx; /* context (from file name) */
21 XF *fxp, *bxp; /* forward and backward transforms */
22 } MFUNC; /* material function */
23
24 extern XF unitxf; /* identity transform */
25 extern XF funcxf; /* current transform */
26
27 extern void initfunc(void);
28 extern MFUNC *getfunc(OBJREC *m, int ff, unsigned int ef, int dofwd);
29 extern void freefunc(OBJREC *m);
30 extern int setfunc(OBJREC *m, RAY *r);
31 extern int worldfunc(char *ctx, RAY *r);
32 extern void loadfunc(char *fname);
33
34 /* defined in noise3.c */
35 extern void setnoisefuncs(void);
36
37 /* defined in fprism.c */
38 extern void setprismfuncs(void);
39
40
41 #ifdef __cplusplus
42 }
43 #endif
44 #endif /* _RAD_FUNC_H_ */
45
