root/Development/ray/src/rt/func.h
Revision: 2.8
Committed: Fri Feb 18 00:40:25 2011 UTC (14 years, 10 months ago) by greg
Changes since 2.7: +5 -8 lines
1 /* RCSid $Id: func.h,v 2.7 2004/03/30 16:13:01 schorsch Exp $ */
2 /*
3 * Header file for modifiers using function files.
4 *
5 * Include after ray.h
6 */
7 #ifndef _RAD_FUNC_H_
8 #define _RAD_FUNC_H_
9
10 #include "calcomp.h"
11
12 #ifdef __cplusplus
13 extern "C" {
14 #endif
15
16 #define MAXEXPR 9 /* maximum expressions in modifier */
17
18 typedef struct {
19 EPNODE *ep[MAXEXPR+1]; /* NULL-terminated expression list */
20 char *ctx; /* context (from file name) */
21 XF *f, *b; /* forward and backward transforms */
22 } MFUNC; /* material function */
23
24 extern XF unitxf; /* identity transform */
25 extern XF funcxf; /* current transform */
26
27
28 extern MFUNC *getfunc(OBJREC *m, int ff, unsigned int ef, int dofwd);
29 extern void freefunc(OBJREC *m);
30 extern int setfunc(OBJREC *m, RAY *r);
31 extern void loadfunc(char *fname);
32
33 /* defined in noise3.c */
34 extern void setnoisefuncs(void);
35
36 /* defined in fprism.c */
37 extern void setprismfuncs(void);
38
39
40 #ifdef __cplusplus
41 }
42 #endif
43 #endif /* _RAD_FUNC_H_ */
44
