--- ray/src/rt/func.h 2003/02/25 02:47:22 2.3 +++ ray/src/rt/func.h 2004/03/30 16:13:01 2.7 @@ -1,14 +1,20 @@ -/* RCSid $Id: func.h,v 2.3 2003/02/25 02:47:22 greg Exp $ */ +/* RCSid $Id: func.h,v 2.7 2004/03/30 16:13:01 schorsch Exp $ */ /* * Header file for modifiers using function files. * * Include after ray.h */ +#ifndef _RAD_FUNC_H_ +#define _RAD_FUNC_H_ -#include "copyright.h" - +#include "ray.h" +#include "object.h" #include "calcomp.h" +#ifdef __cplusplus +extern "C" { +#endif + #define MAXEXPR 9 /* maximum expressions in modifier */ typedef struct { @@ -20,18 +26,22 @@ typedef struct { extern XF unitxf; /* identity transform */ extern XF funcxf; /* current transform */ -#ifdef NOPROTO -extern MFUNC *getfunc(); -extern void freefunc(); -extern int setfunc(); -extern void loadfunc(); - -#else - -extern MFUNC *getfunc(OBJREC *m, int ff, unsigned int ef, int dofwd); +extern MFUNC *getfunc(OBJREC *m, int ff, unsigned int ef, int dofwd); extern void freefunc(OBJREC *m); extern int setfunc(OBJREC *m, RAY *r); extern void loadfunc(char *fname); + /* defined in noise3.c */ +extern void setnoisefuncs(void); + + /* defined in fprism.c */ +extern void setprismfuncs(void); + + + +#ifdef __cplusplus +} #endif +#endif /* _RAD_FUNC_H_ */ +
