root/Development/ray/src/rt/func.c
Revision: 2.33
Committed: Sat May 13 00:09:53 2017 UTC (8 years, 7 months ago) by greg
Changes since 2.32: +1 -3 lines
Removed unnecessary test
2 static const char RCSid[] = "$Id: func.c,v 2.32 2016/04/27 21:11:32 greg Exp $";
5 * func.c - interface to calcomp functions.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "paths.h"
12 #include "otypes.h"
13 #include "func.h"
14 #include <ctype.h>
15
16
17 #define INITFILE "rayinit.cal"
18 #define CALSUF ".cal"
19 #define LCALSUF 4
20 char REFVNAME[] = "`FILE_REFCNT";
21
22 XF unitxf = { /* identity transform */
23 {{1.0, 0.0, 0.0, 0.0},
24 {0.0, 1.0, 0.0, 0.0},
25 {0.0, 0.0, 1.0, 0.0},
26 {0.0, 0.0, 0.0, 1.0}},
27 1.0
28 };
29
30 XF funcxf; /* current transformation */
31 static OBJREC *fobj = NULL; /* current function object */
32 static RAY *fray = NULL; /* current function ray */
33
34 static char rayinitcal[] = INITFILE;
35
36 static double l_erf(char *), l_erfc(char *), l_arg(char *);
37
38
39 void
40 initfunc(void) /* initialize function evaluation */
41 {
42 if (!rayinitcal[0]) /* already done? */
43 return;
44 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
45 esupport &= ~(E_OUTCHAN);
46 setcontext("");
47 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
48 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
49 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
50 scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0);
51 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
52 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
53 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
54 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
55 scompile("Lu=$26;Lv=$27;", NULL, 0);
56 funset("arg", 1, '=', l_arg);
57 funset("erf", 1, ':', l_erf);
58 funset("erfc", 1, ':', l_erfc);
59 setnoisefuncs();
60 setprismfuncs();
61 loadfunc(rayinitcal);
62 rayinitcal[0] = '\0';
63 }
64
65
66 /* Set parameters for current evaluation */
67 void
68 set_eparams(char *prms)
69 {
70 static char *last_params;
71 static int lplen = 0;
72 int len;
73 char vname[RMAXWORD];
74 double value;
75 char *cpd;
76 /* check if already set */
77 if (prms == NULL || !*prms)
78 return;
79 if (lplen && !strcmp(prms, last_params))
80 return;
81 len = strlen(prms); /* record new settings */
82 if ((lplen != 0) & (lplen <= len)) {
83 free(last_params);
84 lplen = 0;
85 }
86 if (!lplen) {
87 lplen = len + 100;
88 last_params = (char *)malloc(lplen);
89 if (last_params == NULL)
90 error(SYSTEM, "out of memory in set_eparams()");
91 }
92 strcpy(last_params, prms);
93 /* assign each variable */
94 while (*prms) {
95 if (isspace(*prms)) {
96 ++prms; continue;
97 }
98 if (!isalpha(*prms))
99 goto bad_params;
100 cpd = vname;
101 while (*prms && (*prms != '=') & !isspace(*prms)) {
102 if (!isid(*prms) | (cpd-vname >= RMAXWORD-1))
103 goto bad_params;
104 *cpd++ = *prms++;
105 }
106 *cpd = '\0';
107 while (isspace(*prms)) prms++;
108 if (*prms++ != '=')
109 goto bad_params;
110 value = atof(prms);
111 if ((prms = fskip(prms)) == NULL)
112 goto bad_params;
113 while (isspace(*prms)) prms++;
114 prms += (*prms == ',') | (*prms == ';');
115 varset(vname, '=', value);
116 }
117 return;
118 bad_params:
119 sprintf(errmsg, "bad parameter list '%s'", last_params);
120 error(USER, errmsg);
121 }
122
123
124 MFUNC *
125 getfunc( /* get function for this modifier */
126 OBJREC *m,
127 int ff,
128 unsigned int ef,
129 int dofwd
130 )
131 {
132 char sbuf[MAXSTR];
133 char **arg;
134 MFUNC *f;
135 int ne, na;
136 int i;
137 /* check to see if done already */
138 if ((f = (MFUNC *)m->os) != NULL)
139 return(f);
140 fobj = NULL; fray = NULL;
141 if (rayinitcal[0]) /* initialize on first call */
142 initfunc();
143 if ((na = m->oargs.nsargs) <= ff)
144 goto toofew;
145 arg = m->oargs.sarg;
146 if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
147 goto memerr;
148 i = strlen(arg[ff]); /* set up context */
149 if (i == 1 && arg[ff][0] == '.') {
150 setcontext(f->ctx = ""); /* "." means no file */
151 } else {
152 strcpy(sbuf,arg[ff]); /* file name is context */
153 if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
154 sbuf[i-LCALSUF] = '\0'; /* remove suffix */
155 setcontext(f->ctx = savestr(sbuf));
156 if (!vardefined(REFVNAME)) { /* file loaded? */
157 loadfunc(arg[ff]);
158 varset(REFVNAME, '=', 1.0);
159 } else /* reference_count++ */
160 varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
161 }
162 curfunc = NULL; /* parse expressions */
163 sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
164 for (i=0, ne=0; ef && i < na; i++, ef>>=1)
165 if (ef & 1) { /* flagged as an expression? */
166 if (ne >= MAXEXPR)
167 objerror(m, INTERNAL, "too many expressions");
168 initstr(arg[i], sbuf, 0);
169 f->ep[ne++] = getE1();
170 if (nextc != EOF)
171 syntax("unexpected character");
172 }
173 if (ef)
174 goto toofew;
175 if (i <= ff) /* find transform args */
176 i = ff+1;
177 while (i < na && arg[i][0] != '-')
178 i++;
179 if (i == na) { /* no transform */
180 f->fxp = f->bxp = &unitxf;
181 } else { /* get transform */
182 if ((f->bxp = (XF *)malloc(sizeof(XF))) == NULL)
183 goto memerr;
184 if (invxf(f->bxp, na-i, arg+i) != na-i)
185 objerror(m, USER, "bad transform");
186 if (f->bxp->sca < 0.0)
187 f->bxp->sca = -f->bxp->sca;
188 if (dofwd) { /* do both transforms */
189 if ((f->fxp = (XF *)malloc(sizeof(XF))) == NULL)
190 goto memerr;
191 xf(f->fxp, na-i, arg+i);
192 if (f->fxp->sca < 0.0)
193 f->fxp->sca = -f->fxp->sca;
194 }
195 }
196 m->os = (char *)f;
197 return(f);
198 toofew:
199 objerror(m, USER, "too few string arguments");
200 memerr:
201 error(SYSTEM, "out of memory in getfunc");
202 return NULL; /* pro forma return */
203 }
204
205
206 void
207 freefunc( /* free memory associated with modifier */
208 OBJREC *m
209 )
210 {
211 MFUNC *f;
212 int i;
213
214 if ((f = (MFUNC *)m->os) == NULL)
215 return;
216 for (i = 0; f->ep[i] != NULL; i++)
217 epfree(f->ep[i]);
218 if (f->ctx[0]) { /* done with definitions */
219 setcontext(f->ctx);
220 i = varvalue(REFVNAME)-.5; /* reference_count-- */
221 if (i > 0)
222 varset(REFVNAME, '=', (double)i);
223 else
224 dcleanup(2); /* remove definitions */
225 freestr(f->ctx);
226 }
227 if (f->bxp != &unitxf)
228 free((void *)f->bxp);
229 if ((f->fxp != NULL) & (f->fxp != &unitxf))
230 free((void *)f->fxp);
231 free((void *)f);
232 m->os = NULL;
233 }
234
235
236 int
237 setfunc( /* set channels for function call */
238 OBJREC *m,
239 RAY *r
240 )
241 {
242 static RNUMBER lastrno = ~0;
243 MFUNC *f;
244 /* get function if any */
245 if ((f = (MFUNC *)m->os) == NULL)
246 objerror(m, CONSISTENCY, "setfunc called before getfunc");
247
248 setcontext(f->ctx); /* set evaluator context */
249 /* check to see if matrix set */
250 if ((m == fobj) & (r->rno == lastrno))
251 return(0);
252 fobj = m;
253 fray = r;
254 if (r->rox != NULL) {
255 if (f->bxp != &unitxf) {
256 funcxf.sca = r->rox->b.sca * f->bxp->sca;
257 multmat4(funcxf.xfm, r->rox->b.xfm, f->bxp->xfm);
258 } else
259 funcxf = r->rox->b;
260 } else
261 funcxf = *f->bxp;
262 lastrno = r->rno;
263 eclock++; /* notify expression evaluator */
264 return(1);
265 }
266
267
268 int
269 worldfunc( /* special function context sans object */
270 char *ctx,
271 RAY *r
272 )
273 {
274 static RNUMBER lastrno = ~0;
275
276 if (rayinitcal[0]) /* initialize on first call */
277 initfunc();
278 /* set evaluator context */
279 setcontext(ctx);
280 /* check if ray already set */
281 if ((fobj == NULL) & (r->rno == lastrno))
282 return(0);
283 fobj = NULL;
284 fray = r;
285 funcxf = unitxf;
286 lastrno = r->rno;
287 eclock++; /* notify expression evaluator */
288 return(1);
289 }
290
291
292 void
293 loadfunc( /* load definition file */
294 char *fname
295 )
296 {
297 char *ffname;
298
299 if ((ffname = getpath(fname, getrlibpath(), R_OK)) == NULL) {
300 sprintf(errmsg, "cannot find function file \"%s\"", fname);
301 error(SYSTEM, errmsg);
302 }
303 fcompile(ffname);
304 }
305
306
307 static double
308 l_arg(char *nm) /* return nth real argument */
309 {
310 int n;
311
312 if (fobj == NULL)
313 error(INTERNAL, "arg(n) called without a modifier context");
314
315 n = argument(1) + .5; /* round to integer */
316
317 if (n < 1)
318 return(fobj->oargs.nfargs);
319
320 if (n > fobj->oargs.nfargs) {
321 sprintf(errmsg, "missing real argument %d", n);
322 objerror(fobj, USER, errmsg);
323 }
324 return(fobj->oargs.farg[n-1]);
325 }
326
327
328 static double
329 l_erf(char *nm) /* error function */
330 {
331 return(erf(argument(1)));
332 }
333
334
335 static double
336 l_erfc(char *nm) /* cumulative error function */
337 {
338 return(erfc(argument(1)));
339 }
340
341
342 double
343 chanvalue( /* return channel n to calcomp */
344 int n
345 )
346 {
347 if (fray == NULL)
348 syntax("ray parameter used in constant expression");
349
350 if (--n < 0)
351 goto badchan;
352
353 if (n <= 2) /* ray direction */
354
355 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
356 fray->rdir[1]*funcxf.xfm[1][n] +
357 fray->rdir[2]*funcxf.xfm[2][n] )
358 / funcxf.sca );
359
360 if (n <= 5) /* surface normal */
361
362 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
363 fray->ron[1]*funcxf.xfm[1][n-3] +
364 fray->ron[2]*funcxf.xfm[2][n-3] )
365 / funcxf.sca );
366
367 if (n <= 8) { /* intersection point */
368 if (fray->rot >= FHUGE)
369 return(0.0); /* XXX should be runtime error? */
370
371 return( fray->rop[0]*funcxf.xfm[0][n-6] +
372 fray->rop[1]*funcxf.xfm[1][n-6] +
373 fray->rop[2]*funcxf.xfm[2][n-6] +
374 funcxf.xfm[3][n-6] );
375 }
376
377 if (n == 9) /* total distance */
378 return(raydist(fray,PRIMARY) * funcxf.sca);
379
380 if (n == 10) /* dot product (range [-1,1]) */
381 return( fray->rod <= -1.0 ? -1.0 :
382 fray->rod >= 1.0 ? 1.0 :
383 fray->rod );
384
385 if (n == 11) /* scale */
386 return(funcxf.sca);
387
388 if (n <= 14) /* origin */
389 return(funcxf.xfm[3][n-12]);
390
391 if (n <= 17) /* i unit vector */
392 return(funcxf.xfm[0][n-15] / funcxf.sca);
393
394 if (n <= 20) /* j unit vector */
395 return(funcxf.xfm[1][n-18] / funcxf.sca);
396
397 if (n <= 23) /* k unit vector */
398 return(funcxf.xfm[2][n-21] / funcxf.sca);
399
400 if (n == 24) /* single ray (shadow) distance */
401 return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca);
402
403 if (n <= 26) /* local (u,v) coordinates */
404 return(fray->uv[n-25]);
405 badchan:
406 error(USER, "illegal channel number");
407 return(0.0);
408 }
