root/radiance/ray/src/rt/func.c
Revision: 2.29
Committed: Wed May 20 12:58:30 2015 UTC (10 years, 1 month ago) by greg
Changes since 2.28: +47 -1 lines
Added appropriate setting of ray parameters for bin rcontrib evaluation
2 static const char RCSid[] = "$Id: func.c,v 2.28 2015/05/19 11:49:05 greg Exp $";
5 * func.c - interface to calcomp functions.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11 #include "paths.h"
12 #include "otypes.h"
13 #include "func.h"
14
15
16 #define INITFILE "rayinit.cal"
17 #define CALSUF ".cal"
18 #define LCALSUF 4
19 char REFVNAME[] = "`FILE_REFCNT";
20
21 XF unitxf = { /* identity transform */
22 {{1.0, 0.0, 0.0, 0.0},
23 {0.0, 1.0, 0.0, 0.0},
24 {0.0, 0.0, 1.0, 0.0},
25 {0.0, 0.0, 0.0, 1.0}},
26 1.0
27 };
28
29 XF funcxf; /* current transformation */
30 static OBJREC *fobj = NULL; /* current function object */
31 static RAY *fray = NULL; /* current function ray */
32
33 static char rayinitcal[] = INITFILE;
34
35 static double l_erf(char *), l_erfc(char *), l_arg(char *);
36
37
38 void
39 initfunc() /* initialize function evaluation */
40 {
41 if (!rayinitcal[0]) /* already done? */
42 return;
43 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
44 esupport &= ~(E_OUTCHAN);
45 setcontext("");
46 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
47 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
48 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
49 scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0);
50 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
51 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
52 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
53 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
54 scompile("Lu=$26;Lv=$27;", NULL, 0);
55 funset("arg", 1, '=', l_arg);
56 funset("erf", 1, ':', l_erf);
57 funset("erfc", 1, ':', l_erfc);
58 setnoisefuncs();
59 setprismfuncs();
60 loadfunc(rayinitcal);
61 rayinitcal[0] = '\0';
62 }
63
64
65 /* Set parameters for current evaluation */
66 void
67 set_eparams(char *prms)
68 {
69 static char *last_params = NULL;
70 char vname[RMAXWORD];
71 double value;
72 char *cpd;
73 /* check if already set */
74 if ((prms == NULL) | (prms == last_params))
75 return;
76 if (last_params != NULL && !strcmp(prms, last_params))
77 return;
78 last_params = prms; /* assign each variable */
79 while (*prms) {
80 if (isspace(*prms)) {
81 ++prms; continue;
82 }
83 if (!isalpha(*prms))
84 goto bad_params;
85 cpd = vname;
86 while (*prms && (*prms != '=') & !isspace(*prms)) {
87 if (!isid(*prms))
88 goto bad_params;
89 *cpd++ = *prms++;
90 }
91 if (cpd == vname)
92 goto bad_params;
93 *cpd = '\0';
94 while (isspace(*prms)) prms++;
95 if (*prms++ != '=')
96 goto bad_params;
97 value = atof(prms);
98 if ((prms = fskip(prms)) == NULL)
99 goto bad_params;
100 while (isspace(*prms)) prms++;
101 prms += (*prms == ',') | (*prms == ';');
102 varset(vname, '=', value);
103 }
104 return;
105 bad_params:
106 sprintf(errmsg, "bad parameter list '%s'", last_params);
107 error(USER, errmsg);
108 }
109
110
111 MFUNC *
112 getfunc( /* get function for this modifier */
113 OBJREC *m,
114 int ff,
115 unsigned int ef,
116 int dofwd
117 )
118 {
119 char sbuf[MAXSTR];
120 char **arg;
121 MFUNC *f;
122 int ne, na;
123 int i;
124 /* check to see if done already */
125 if ((f = (MFUNC *)m->os) != NULL)
126 return(f);
127 fobj = NULL; fray = NULL;
128 if (rayinitcal[0]) /* initialize on first call */
129 initfunc();
130 if ((na = m->oargs.nsargs) <= ff)
131 goto toofew;
132 arg = m->oargs.sarg;
133 if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
134 goto memerr;
135 i = strlen(arg[ff]); /* set up context */
136 if (i == 1 && arg[ff][0] == '.') {
137 setcontext(f->ctx = ""); /* "." means no file */
138 } else {
139 strcpy(sbuf,arg[ff]); /* file name is context */
140 if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
141 sbuf[i-LCALSUF] = '\0'; /* remove suffix */
142 setcontext(f->ctx = savestr(sbuf));
143 if (!vardefined(REFVNAME)) { /* file loaded? */
144 loadfunc(arg[ff]);
145 varset(REFVNAME, '=', 1.0);
146 } else /* reference_count++ */
147 varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
148 }
149 curfunc = NULL; /* parse expressions */
150 sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
151 for (i=0, ne=0; ef && i < na; i++, ef>>=1)
152 if (ef & 1) { /* flagged as an expression? */
153 if (ne >= MAXEXPR)
154 objerror(m, INTERNAL, "too many expressions");
155 initstr(arg[i], sbuf, 0);
156 f->ep[ne++] = getE1();
157 if (nextc != EOF)
158 syntax("unexpected character");
159 }
160 if (ef)
161 goto toofew;
162 if (i <= ff) /* find transform args */
163 i = ff+1;
164 while (i < na && arg[i][0] != '-')
165 i++;
166 if (i == na) { /* no transform */
167 f->fxp = f->bxp = &unitxf;
168 } else { /* get transform */
169 if ((f->bxp = (XF *)malloc(sizeof(XF))) == NULL)
170 goto memerr;
171 if (invxf(f->bxp, na-i, arg+i) != na-i)
172 objerror(m, USER, "bad transform");
173 if (f->bxp->sca < 0.0)
174 f->bxp->sca = -f->bxp->sca;
175 if (dofwd) { /* do both transforms */
176 if ((f->fxp = (XF *)malloc(sizeof(XF))) == NULL)
177 goto memerr;
178 xf(f->fxp, na-i, arg+i);
179 if (f->fxp->sca < 0.0)
180 f->fxp->sca = -f->fxp->sca;
181 }
182 }
183 m->os = (char *)f;
184 return(f);
185 toofew:
186 objerror(m, USER, "too few string arguments");
187 memerr:
188 error(SYSTEM, "out of memory in getfunc");
189 return NULL; /* pro forma return */
190 }
191
192
193 void
194 freefunc( /* free memory associated with modifier */
195 OBJREC *m
196 )
197 {
198 MFUNC *f;
199 int i;
200
201 if ((f = (MFUNC *)m->os) == NULL)
202 return;
203 for (i = 0; f->ep[i] != NULL; i++)
204 epfree(f->ep[i]);
205 if (f->ctx[0]) { /* done with definitions */
206 setcontext(f->ctx);
207 i = varvalue(REFVNAME)-.5; /* reference_count-- */
208 if (i > 0)
209 varset(REFVNAME, '=', (double)i);
210 else
211 dcleanup(2); /* remove definitions */
212 freestr(f->ctx);
213 }
214 if (f->bxp != &unitxf)
215 free((void *)f->bxp);
216 if ((f->fxp != NULL) & (f->fxp != &unitxf))
217 free((void *)f->fxp);
218 free((void *)f);
219 m->os = NULL;
220 }
221
222
223 int
224 setfunc( /* set channels for function call */
225 OBJREC *m,
226 RAY *r
227 )
228 {
229 static RNUMBER lastrno = ~0;
230 MFUNC *f;
231 /* get function if any */
232 if ((f = (MFUNC *)m->os) == NULL)
233 objerror(m, CONSISTENCY, "setfunc called before getfunc");
234
235 setcontext(f->ctx); /* set evaluator context */
236 /* check to see if matrix set */
237 if ((m == fobj) & (r->rno == lastrno))
238 return(0);
239 fobj = m;
240 fray = r;
241 if (r->rox != NULL) {
242 if (f->bxp != &unitxf) {
243 funcxf.sca = r->rox->b.sca * f->bxp->sca;
244 multmat4(funcxf.xfm, r->rox->b.xfm, f->bxp->xfm);
245 } else
246 funcxf = r->rox->b;
247 } else
248 funcxf = *f->bxp;
249 lastrno = r->rno;
250 eclock++; /* notify expression evaluator */
251 return(1);
252 }
253
254
255 int
256 worldfunc( /* special function context sans object */
257 char *ctx,
258 RAY *r
259 )
260 {
261 static RNUMBER lastrno = ~0;
262
263 if (rayinitcal[0]) /* initialize on first call */
264 initfunc();
265 /* set evaluator context */
266 setcontext(ctx);
267 /* check if ray already set */
268 if ((fobj == NULL) & (r->rno == lastrno))
269 return(0);
270 fobj = NULL;
271 fray = r;
272 funcxf = unitxf;
273 lastrno = r->rno;
274 eclock++; /* notify expression evaluator */
275 return(1);
276 }
277
278
279 void
280 loadfunc( /* load definition file */
281 char *fname
282 )
283 {
284 char *ffname;
285
286 if ((ffname = getpath(fname, getrlibpath(), R_OK)) == NULL) {
287 sprintf(errmsg, "cannot find function file \"%s\"", fname);
288 error(USER, errmsg);
289 }
290 fcompile(ffname);
291 }
292
293
294 static double
295 l_arg(char *nm) /* return nth real argument */
296 {
297 int n;
298
299 if (fobj == NULL)
300 error(USER, "arg(n) called without a context");
301
302 n = argument(1) + .5; /* round to integer */
303
304 if (n < 1)
305 return(fobj->oargs.nfargs);
306
307 if (n > fobj->oargs.nfargs) {
308 sprintf(errmsg, "missing real argument %d", n);
309 objerror(fobj, USER, errmsg);
310 }
311 return(fobj->oargs.farg[n-1]);
312 }
313
314
315 static double
316 l_erf(char *nm) /* error function */
317 {
318 return(erf(argument(1)));
319 }
320
321
322 static double
323 l_erfc(char *nm) /* cumulative error function */
324 {
325 return(erfc(argument(1)));
326 }
327
328
329 double
330 chanvalue( /* return channel n to calcomp */
331 int n
332 )
333 {
334 if (fray == NULL)
335 syntax("ray parameter used in constant expression");
336
337 if (--n < 0)
338 goto badchan;
339
340 if (n <= 2) /* ray direction */
341
342 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
343 fray->rdir[1]*funcxf.xfm[1][n] +
344 fray->rdir[2]*funcxf.xfm[2][n] )
345 / funcxf.sca );
346
347 if (n <= 5) /* surface normal */
348
349 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
350 fray->ron[1]*funcxf.xfm[1][n-3] +
351 fray->ron[2]*funcxf.xfm[2][n-3] )
352 / funcxf.sca );
353
354 if (n <= 8) { /* intersection point */
355 if (fray->rot >= FHUGE)
356 return(0.0); /* XXX should be runtime error? */
357
358 return( fray->rop[0]*funcxf.xfm[0][n-6] +
359 fray->rop[1]*funcxf.xfm[1][n-6] +
360 fray->rop[2]*funcxf.xfm[2][n-6] +
361 funcxf.xfm[3][n-6] );
362 }
363
364 if (n == 9) /* total distance */
365 return(raydist(fray,PRIMARY) * funcxf.sca);
366
367 if (n == 10) /* dot product (range [-1,1]) */
368 return( fray->rod <= -1.0 ? -1.0 :
369 fray->rod >= 1.0 ? 1.0 :
370 fray->rod );
371
372 if (n == 11) /* scale */
373 return(funcxf.sca);
374
375 if (n <= 14) /* origin */
376 return(funcxf.xfm[3][n-12]);
377
378 if (n <= 17) /* i unit vector */
379 return(funcxf.xfm[0][n-15] / funcxf.sca);
380
381 if (n <= 20) /* j unit vector */
382 return(funcxf.xfm[1][n-18] / funcxf.sca);
383
384 if (n <= 23) /* k unit vector */
385 return(funcxf.xfm[2][n-21] / funcxf.sca);
386
387 if (n == 24) /* single ray (shadow) distance */
388 return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca);
389
390 if (n <= 26) /* local (u,v) coordinates */
391 return(fray->uv[n-25]);
392 badchan:
393 error(USER, "illegal channel number");
394 return(0.0);
395 }
