root/Development/ray/src/rt/func.c
Revision: 2.21
Committed: Thu Feb 12 18:55:50 2004 UTC (21 years, 10 months ago) by greg
Changes since 2.20: +3 -1 lines
2 static const char RCSid[] = "$Id: func.c,v 2.20 2003/08/04 22:37:53 greg Exp $";
5 * func.c - interface to calcomp functions.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11
12 #include "paths.h"
13
14 #include "otypes.h"
15
16 #include "func.h"
17
18
19 #define INITFILE "rayinit.cal"
20 #define CALSUF ".cal"
21 #define LCALSUF 4
22 char REFVNAME[] = "`FILE_REFCNT";
23
24 XF unitxf = { /* identity transform */
25 {{1.0, 0.0, 0.0, 0.0},
26 {0.0, 1.0, 0.0, 0.0},
27 {0.0, 0.0, 1.0, 0.0},
28 {0.0, 0.0, 0.0, 1.0}},
29 1.0
30 };
31
32 XF funcxf; /* current transformation */
33 static OBJREC *fobj = NULL; /* current function object */
34 static RAY *fray = NULL; /* current function ray */
35
36 static double l_erf(char *), l_erfc(char *), l_arg(char *);
37
38
39 MFUNC *
40 getfunc(m, ff, ef, dofwd) /* get function for this modifier */
41 OBJREC *m;
42 int ff;
43 unsigned int ef;
44 int dofwd;
45 {
46 static char initfile[] = INITFILE;
47 char sbuf[MAXSTR];
48 register char **arg;
49 register MFUNC *f;
50 int ne, na;
51 register int i;
52 /* check to see if done already */
53 if ((f = (MFUNC *)m->os) != NULL)
54 return(f);
55 fobj = NULL; fray = NULL;
56 if (initfile[0]) { /* initialize on first call */
57 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
58 esupport &= ~(E_OUTCHAN);
59 setcontext("");
60 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
61 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
62 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
63 scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0);
64 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
65 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
66 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
67 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
68 scompile("Lu=$26;Lv=$27;", NULL, 0);
69 funset("arg", 1, '=', l_arg);
70 funset("erf", 1, ':', l_erf);
71 funset("erfc", 1, ':', l_erfc);
72 setnoisefuncs();
73 setprismfuncs();
74 loadfunc(initfile);
75 initfile[0] = '\0';
76 }
77 if ((na = m->oargs.nsargs) <= ff)
78 goto toofew;
79 arg = m->oargs.sarg;
80 if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
81 goto memerr;
82 i = strlen(arg[ff]); /* set up context */
83 if (i == 1 && arg[ff][0] == '.')
84 setcontext(f->ctx = ""); /* "." means no file */
85 else {
86 strcpy(sbuf,arg[ff]); /* file name is context */
87 if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
88 sbuf[i-LCALSUF] = '\0'; /* remove suffix */
89 setcontext(f->ctx = savestr(sbuf));
90 if (!vardefined(REFVNAME)) { /* file loaded? */
91 loadfunc(arg[ff]);
92 varset(REFVNAME, '=', 1.0);
93 } else /* reference_count++ */
94 varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
95 }
96 curfunc = NULL; /* parse expressions */
97 sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
98 for (i=0, ne=0; ef && i < na; i++, ef>>=1)
99 if (ef & 1) { /* flagged as an expression? */
100 if (ne >= MAXEXPR)
101 objerror(m, INTERNAL, "too many expressions");
102 initstr(arg[i], sbuf, 0);
103 f->ep[ne++] = getE1();
104 if (nextc != EOF)
105 syntax("unexpected character");
106 }
107 if (ef)
108 goto toofew;
109 if (i <= ff) /* find transform args */
110 i = ff+1;
111 while (i < na && arg[i][0] != '-')
112 i++;
113 if (i == na) /* no transform */
114 f->f = f->b = &unitxf;
115 else { /* get transform */
116 if ((f->b = (XF *)malloc(sizeof(XF))) == NULL)
117 goto memerr;
118 if (invxf(f->b, na-i, arg+i) != na-i)
119 objerror(m, USER, "bad transform");
120 if (f->b->sca < 0.0)
121 f->b->sca = -f->b->sca;
122 if (dofwd) { /* do both transforms */
123 if ((f->f = (XF *)malloc(sizeof(XF))) == NULL)
124 goto memerr;
125 xf(f->f, na-i, arg+i);
126 if (f->f->sca < 0.0)
127 f->f->sca = -f->f->sca;
128 }
129 }
130 m->os = (char *)f;
131 return(f);
132 toofew:
133 objerror(m, USER, "too few string arguments");
134 memerr:
135 error(SYSTEM, "out of memory in getfunc");
136 }
137
138
139 void
140 freefunc(m) /* free memory associated with modifier */
141 OBJREC *m;
142 {
143 register MFUNC *f;
144 register int i;
145
146 if ((f = (MFUNC *)m->os) == NULL)
147 return;
148 for (i = 0; f->ep[i] != NULL; i++)
149 epfree(f->ep[i]);
150 if (f->ctx[0]) { /* done with definitions */
151 setcontext(f->ctx);
152 i = varvalue(REFVNAME)-.5; /* reference_count-- */
153 if (i > 0)
154 varset(REFVNAME, '=', (double)i);
155 else
156 dcleanup(2); /* remove definitions */
157 freestr(f->ctx);
158 }
159 if (f->b != &unitxf)
160 free((void *)f->b);
161 if (f->f != NULL && f->f != &unitxf)
162 free((void *)f->f);
163 free((void *)f);
164 m->os = NULL;
165 }
166
167
168 int
169 setfunc(m, r) /* set channels for function call */
170 OBJREC *m;
171 register RAY *r;
172 {
173 static unsigned long lastrno = ~0;
174 register MFUNC *f;
175 /* get function */
176 if ((f = (MFUNC *)m->os) == NULL)
177 objerror(m, CONSISTENCY, "setfunc called before getfunc");
178 /* set evaluator context */
179 setcontext(f->ctx);
180 /* check to see if matrix set */
181 if (m == fobj && r->rno == lastrno)
182 return(0);
183 fobj = m;
184 fray = r;
185 if (r->rox != NULL)
186 if (f->b != &unitxf) {
187 funcxf.sca = r->rox->b.sca * f->b->sca;
188 multmat4(funcxf.xfm, r->rox->b.xfm, f->b->xfm);
189 } else
190 funcxf = r->rox->b;
191 else
192 funcxf = *(f->b);
193 lastrno = r->rno;
194 eclock++; /* notify expression evaluator */
195 return(1);
196 }
197
198
199 void
200 loadfunc(fname) /* load definition file */
201 char *fname;
202 {
203 char *ffname;
204
205 if ((ffname = getpath(fname, getrlibpath(), R_OK)) == NULL) {
206 sprintf(errmsg, "cannot find function file \"%s\"", fname);
207 error(USER, errmsg);
208 }
209 fcompile(ffname);
210 }
211
212
213 static double
214 l_arg(char *nm) /* return nth real argument */
215 {
216 register int n;
217
218 if (fobj == NULL)
219 syntax("arg(n) used in constant expression");
220
221 n = argument(1) + .5; /* round to integer */
222
223 if (n < 1)
224 return(fobj->oargs.nfargs);
225
226 if (n > fobj->oargs.nfargs) {
227 sprintf(errmsg, "missing real argument %d", n);
228 objerror(fobj, USER, errmsg);
229 }
230 return(fobj->oargs.farg[n-1]);
231 }
232
233
234 static double
235 l_erf(char *nm) /* error function */
236 {
237 extern double erf();
238
239 return(erf(argument(1)));
240 }
241
242
243 static double
244 l_erfc(char *nm) /* cumulative error function */
245 {
246 extern double erfc();
247
248 return(erfc(argument(1)));
249 }
250
251
252 double
253 chanvalue(n) /* return channel n to calcomp */
254 register int n;
255 {
256 if (fray == NULL)
257 syntax("ray parameter used in constant expression");
258
259 if (--n < 0)
260 goto badchan;
261
262 if (n <= 2) /* ray direction */
263
264 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
265 fray->rdir[1]*funcxf.xfm[1][n] +
266 fray->rdir[2]*funcxf.xfm[2][n] )
267 / funcxf.sca );
268
269 if (n <= 5) /* surface normal */
270
271 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
272 fray->ron[1]*funcxf.xfm[1][n-3] +
273 fray->ron[2]*funcxf.xfm[2][n-3] )
274 / funcxf.sca );
275
276 if (n <= 8) /* intersection */
277
278 return( fray->rop[0]*funcxf.xfm[0][n-6] +
279 fray->rop[1]*funcxf.xfm[1][n-6] +
280 fray->rop[2]*funcxf.xfm[2][n-6] +
281 funcxf.xfm[3][n-6] );
282
283 if (n == 9) /* total distance */
284 return(raydist(fray,PRIMARY) * funcxf.sca);
285
286 if (n == 10) /* dot product (range [-1,1]) */
287 return( fray->rod <= -1.0 ? -1.0 :
288 fray->rod >= 1.0 ? 1.0 :
289 fray->rod );
290
291 if (n == 11) /* scale */
292 return(funcxf.sca);
293
294 if (n <= 14) /* origin */
295 return(funcxf.xfm[3][n-12]);
296
297 if (n <= 17) /* i unit vector */
298 return(funcxf.xfm[0][n-15] / funcxf.sca);
299
300 if (n <= 20) /* j unit vector */
301 return(funcxf.xfm[1][n-18] / funcxf.sca);
302
303 if (n <= 23) /* k unit vector */
304 return(funcxf.xfm[2][n-21] / funcxf.sca);
305
306 if (n == 24) /* single ray (shadow) distance */
307 return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca);
308
309 if (n <= 26) /* local (u,v) coordinates */
310 return(fray->uv[n-25]);
311 badchan:
312 error(USER, "illegal channel number");
313 return(0.0);
314 }
