| 1 |
#ifndef lint
| 2 |
static const char RCSid[] = "$Id: func.c,v 2.19 2003/07/21 22:30:19 schorsch Exp $";
| 3 |
#endif
| 4 |
| 5 |
* func.c - interface to calcomp functions.
| 6 |
| 7 |
| 8 |
#include "copyright.h"
| 9 |
| 10 |
#include "ray.h"
| 11 |
| 12 |
#include "otypes.h"
| 13 |
| 14 |
#include "func.h"
| 15 |
| 16 |
| 17 |
#define INITFILE "rayinit.cal"
| 18 |
#define CALSUF ".cal"
| 19 |
#define LCALSUF 4
| 20 |
char REFVNAME[] = "`FILE_REFCNT";
| 21 |
| 22 |
XF unitxf = { /* identity transform */
| 23 |
{{1.0, 0.0, 0.0, 0.0},
| 24 |
{0.0, 1.0, 0.0, 0.0},
| 25 |
{0.0, 0.0, 1.0, 0.0},
| 26 |
{0.0, 0.0, 0.0, 1.0}},
| 27 |
1.0
| 28 |
| 29 |
| 30 |
XF funcxf; /* current transformation */
| 31 |
static OBJREC *fobj = NULL; /* current function object */
| 32 |
static RAY *fray = NULL; /* current function ray */
| 33 |
| 34 |
static double l_erf(char *), l_erfc(char *), l_arg(char *);
| 35 |
| 36 |
| 37 |
MFUNC *
| 38 |
getfunc(m, ff, ef, dofwd) /* get function for this modifier */
| 39 |
OBJREC *m;
| 40 |
int ff;
| 41 |
unsigned int ef;
| 42 |
int dofwd;
| 43 |
| 44 |
static char initfile[] = INITFILE;
| 45 |
char sbuf[MAXSTR];
| 46 |
register char **arg;
| 47 |
register MFUNC *f;
| 48 |
int ne, na;
| 49 |
register int i;
| 50 |
/* check to see if done already */
| 51 |
if ((f = (MFUNC *)m->os) != NULL)
| 52 |
return(f);
| 53 |
fobj = NULL; fray = NULL;
| 54 |
if (initfile[0]) { /* initialize on first call */
| 55 |
esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
| 56 |
esupport &= ~(E_OUTCHAN);
| 57 |
setcontext("");
| 58 |
scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
| 59 |
scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
| 60 |
scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
| 61 |
scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0);
| 62 |
scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
| 63 |
scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
| 64 |
scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
| 65 |
scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
| 66 |
scompile("Lu=$26;Lv=$27;", NULL, 0);
| 67 |
funset("arg", 1, '=', l_arg);
| 68 |
funset("erf", 1, ':', l_erf);
| 69 |
funset("erfc", 1, ':', l_erfc);
| 70 |
setnoisefuncs();
| 71 |
setprismfuncs();
| 72 |
loadfunc(initfile);
| 73 |
initfile[0] = '\0';
| 74 |
| 75 |
if ((na = m->oargs.nsargs) <= ff)
| 76 |
goto toofew;
| 77 |
arg = m->oargs.sarg;
| 78 |
if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
| 79 |
goto memerr;
| 80 |
i = strlen(arg[ff]); /* set up context */
| 81 |
if (i == 1 && arg[ff][0] == '.')
| 82 |
setcontext(f->ctx = ""); /* "." means no file */
| 83 |
else {
| 84 |
strcpy(sbuf,arg[ff]); /* file name is context */
| 85 |
if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
| 86 |
sbuf[i-LCALSUF] = '\0'; /* remove suffix */
| 87 |
setcontext(f->ctx = savestr(sbuf));
| 88 |
if (!vardefined(REFVNAME)) { /* file loaded? */
| 89 |
loadfunc(arg[ff]);
| 90 |
varset(REFVNAME, '=', 1.0);
| 91 |
} else /* reference_count++ */
| 92 |
varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
| 93 |
| 94 |
curfunc = NULL; /* parse expressions */
| 95 |
sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
| 96 |
for (i=0, ne=0; ef && i < na; i++, ef>>=1)
| 97 |
if (ef & 1) { /* flagged as an expression? */
| 98 |
if (ne >= MAXEXPR)
| 99 |
objerror(m, INTERNAL, "too many expressions");
| 100 |
initstr(arg[i], sbuf, 0);
| 101 |
f->ep[ne++] = getE1();
| 102 |
if (nextc != EOF)
| 103 |
syntax("unexpected character");
| 104 |
| 105 |
if (ef)
| 106 |
goto toofew;
| 107 |
if (i <= ff) /* find transform args */
| 108 |
i = ff+1;
| 109 |
while (i < na && arg[i][0] != '-')
| 110 |
i++;
| 111 |
if (i == na) /* no transform */
| 112 |
f->f = f->b = &unitxf;
| 113 |
else { /* get transform */
| 114 |
if ((f->b = (XF *)malloc(sizeof(XF))) == NULL)
| 115 |
goto memerr;
| 116 |
if (invxf(f->b, na-i, arg+i) != na-i)
| 117 |
objerror(m, USER, "bad transform");
| 118 |
if (f->b->sca < 0.0)
| 119 |
f->b->sca = -f->b->sca;
| 120 |
if (dofwd) { /* do both transforms */
| 121 |
if ((f->f = (XF *)malloc(sizeof(XF))) == NULL)
| 122 |
goto memerr;
| 123 |
xf(f->f, na-i, arg+i);
| 124 |
if (f->f->sca < 0.0)
| 125 |
f->f->sca = -f->f->sca;
| 126 |
| 127 |
| 128 |
m->os = (char *)f;
| 129 |
return(f);
| 130 |
toofew:
| 131 |
objerror(m, USER, "too few string arguments");
| 132 |
memerr:
| 133 |
error(SYSTEM, "out of memory in getfunc");
| 134 |
| 135 |
| 136 |
| 137 |
void
| 138 |
freefunc(m) /* free memory associated with modifier */
| 139 |
OBJREC *m;
| 140 |
| 141 |
register MFUNC *f;
| 142 |
register int i;
| 143 |
| 144 |
if ((f = (MFUNC *)m->os) == NULL)
| 145 |
return;
| 146 |
for (i = 0; f->ep[i] != NULL; i++)
| 147 |
epfree(f->ep[i]);
| 148 |
if (f->ctx[0]) { /* done with definitions */
| 149 |
setcontext(f->ctx);
| 150 |
i = varvalue(REFVNAME)-.5; /* reference_count-- */
| 151 |
if (i > 0)
| 152 |
varset(REFVNAME, '=', (double)i);
| 153 |
else
| 154 |
dcleanup(2); /* remove definitions */
| 155 |
freestr(f->ctx);
| 156 |
| 157 |
if (f->b != &unitxf)
| 158 |
free((void *)f->b);
| 159 |
if (f->f != NULL && f->f != &unitxf)
| 160 |
free((void *)f->f);
| 161 |
free((void *)f);
| 162 |
m->os = NULL;
| 163 |
| 164 |
| 165 |
| 166 |
int
| 167 |
setfunc(m, r) /* set channels for function call */
| 168 |
OBJREC *m;
| 169 |
register RAY *r;
| 170 |
| 171 |
static unsigned long lastrno = ~0;
| 172 |
register MFUNC *f;
| 173 |
/* get function */
| 174 |
| 175 |
objerror(m, CONSISTENCY, "setfunc called before getfunc");
| 176 |
/* set evaluator context */
| 177 |
setcontext(f->ctx);
| 178 |
/* check to see if matrix set */
| 179 |
if (m == fobj && r->rno == lastrno)
| 180 |
return(0);
| 181 |
fobj = m;
| 182 |
fray = r;
| 183 |
if (r->rox != NULL)
| 184 |
if (f->b != &unitxf) {
| 185 |
funcxf.sca = r->rox->b.sca * f->b->sca;
| 186 |
multmat4(funcxf.xfm, r->rox->b.xfm, f->b->xfm);
| 187 |
} else
| 188 |
funcxf = r->rox->b;
| 189 |
else
| 190 |
funcxf = *(f->b);
| 191 |
lastrno = r->rno;
| 192 |
eclock++; /* notify expression evaluator */
| 193 |
return(1);
| 194 |
| 195 |
| 196 |
| 197 |
void
| 198 |
loadfunc(fname) /* load definition file */
| 199 |
char *fname;
| 200 |
| 201 |
char *ffname;
| 202 |
| 203 |
if ((ffname = getpath(fname, getrlibpath(), R_OK)) == NULL) {
| 204 |
sprintf(errmsg, "cannot find function file \"%s\"", fname);
| 205 |
error(USER, errmsg);
| 206 |
| 207 |
fcompile(ffname);
| 208 |
| 209 |
| 210 |
| 211 |
static double
| 212 |
l_arg(char *nm) /* return nth real argument */
| 213 |
| 214 |
register int n;
| 215 |
| 216 |
if (fobj == NULL)
| 217 |
syntax("arg(n) used in constant expression");
| 218 |
| 219 |
n = argument(1) + .5; /* round to integer */
| 220 |
| 221 |
if (n < 1)
| 222 |
return(fobj->oargs.nfargs);
| 223 |
| 224 |
if (n > fobj->oargs.nfargs) {
| 225 |
sprintf(errmsg, "missing real argument %d", n);
| 226 |
objerror(fobj, USER, errmsg);
| 227 |
| 228 |
return(fobj->oargs.farg[n-1]);
| 229 |
| 230 |
| 231 |
| 232 |
static double
| 233 |
l_erf(char *nm) /* error function */
| 234 |
| 235 |
extern double erf();
| 236 |
| 237 |
return(erf(argument(1)));
| 238 |
| 239 |
| 240 |
| 241 |
static double
| 242 |
l_erfc(char *nm) /* cumulative error function */
| 243 |
| 244 |
extern double erfc();
| 245 |
| 246 |
return(erfc(argument(1)));
| 247 |
| 248 |
| 249 |
| 250 |
double
| 251 |
chanvalue(n) /* return channel n to calcomp */
| 252 |
register int n;
| 253 |
| 254 |
if (fray == NULL)
| 255 |
syntax("ray parameter used in constant expression");
| 256 |
| 257 |
if (--n < 0)
| 258 |
goto badchan;
| 259 |
| 260 |
if (n <= 2) /* ray direction */
| 261 |
| 262 |
return( ( fray->rdir[0]*funcxf.xfm[0][n] +
| 263 |
fray->rdir[1]*funcxf.xfm[1][n] +
| 264 |
fray->rdir[2]*funcxf.xfm[2][n] )
| 265 |
/ funcxf.sca );
| 266 |
| 267 |
if (n <= 5) /* surface normal */
| 268 |
| 269 |
return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
| 270 |
fray->ron[1]*funcxf.xfm[1][n-3] +
| 271 |
fray->ron[2]*funcxf.xfm[2][n-3] )
| 272 |
/ funcxf.sca );
| 273 |
| 274 |
if (n <= 8) /* intersection */
| 275 |
| 276 |
return( fray->rop[0]*funcxf.xfm[0][n-6] +
| 277 |
fray->rop[1]*funcxf.xfm[1][n-6] +
| 278 |
fray->rop[2]*funcxf.xfm[2][n-6] +
| 279 |
funcxf.xfm[3][n-6] );
| 280 |
| 281 |
if (n == 9) /* total distance */
| 282 |
return(raydist(fray,PRIMARY) * funcxf.sca);
| 283 |
| 284 |
if (n == 10) /* dot product (range [-1,1]) */
| 285 |
return( fray->rod <= -1.0 ? -1.0 :
| 286 |
fray->rod >= 1.0 ? 1.0 :
| 287 |
fray->rod );
| 288 |
| 289 |
if (n == 11) /* scale */
| 290 |
return(funcxf.sca);
| 291 |
| 292 |
if (n <= 14) /* origin */
| 293 |
return(funcxf.xfm[3][n-12]);
| 294 |
| 295 |
if (n <= 17) /* i unit vector */
| 296 |
return(funcxf.xfm[0][n-15] / funcxf.sca);
| 297 |
| 298 |
if (n <= 20) /* j unit vector */
| 299 |
return(funcxf.xfm[1][n-18] / funcxf.sca);
| 300 |
| 301 |
if (n <= 23) /* k unit vector */
| 302 |
return(funcxf.xfm[2][n-21] / funcxf.sca);
| 303 |
| 304 |
if (n == 24) /* single ray (shadow) distance */
| 305 |
return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca);
| 306 |
| 307 |
if (n <= 26) /* local (u,v) coordinates */
| 308 |
return(fray->uv[n-25]);
| 309 |
badchan:
| 310 |
error(USER, "illegal channel number");
| 311 |
return(0.0);
| 312 |
