root/radiance/ray/src/rt/func.c
Revision: 2.2
Committed: Mon Nov 25 09:51:00 1991 UTC (33 years, 6 months ago) by greg
Changes since 2.1: +146 -79 lines
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * func.c - interface to calcomp functions.
9 *
10 * 4/7/86
11 */
12
13 #include "ray.h"
14
15 #include "otypes.h"
16
17 #include "func.h"
18
19
20 #define INITFILE "rayinit.cal"
21 #define REFVNAME "`FILE_REFCNT"
22 #define CALSUF ".cal"
23 #define LCALSUF 4
24
25 XF unitxf = { /* identity transform */
26 1.0, 0.0, 0.0, 0.0,
27 0.0, 1.0, 0.0, 0.0,
28 0.0, 0.0, 1.0, 0.0,
29 0.0, 0.0, 0.0, 1.0,
30 1.0
31 };
32
33 XF funcxf; /* current transformation */
34 static OBJREC *fobj = NULL; /* current function object */
35 static RAY *fray = NULL; /* current function ray */
36
37 static double l_erf(), l_erfc(), l_arg();
38
39
40 MFUNC *
41 getfunc(m, ff, ef, dofwd) /* get function for this modifier */
42 OBJREC *m;
43 int ff;
44 unsigned ef;
45 int dofwd;
46 {
47 extern EPNODE *curfunc;
48 static char initfile[] = INITFILE;
49 char sbuf[MAXSTR];
50 register char **arg;
51 register MFUNC *f;
52 int ne, na;
53 register int i;
54 /* check to see if done already */
55 if ((f = (MFUNC *)m->os) != NULL)
56 return(f);
57 if (initfile[0]) { /* initialize on first call */
58 setcontext("");
59 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
60 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
61 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
62 scompile("T=$10;Rdot=$11;", NULL, 0);
63 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
64 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
65 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
66 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
67 funset("arg", 1, '=', l_arg);
68 funset("erf", 1, ':', l_erf);
69 funset("erfc", 1, ':', l_erfc);
70 setnoisefuncs();
71 loadfunc(initfile);
72 initfile[0] = '\0';
73 }
74 if ((na = m->oargs.nsargs) <= ff)
75 goto toofew;
76 arg = m->oargs.sarg;
77 if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
78 goto memerr;
79 i = strlen(arg[ff]); /* set up context */
80 if (i == 1 && arg[ff][0] == '.')
81 setcontext(f->ctx = ""); /* "." means no file */
82 else {
83 strcpy(sbuf,m->oargs.sarg[ff]); /* file name is context */
84 if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
85 sbuf[i-LCALSUF] = '\0'; /* remove suffix */
86 setcontext(f->ctx = savestr(sbuf));
87 if (!vardefined(REFVNAME)) { /* file loaded? */
88 loadfunc(m->oargs.sarg[ff]);
89 varset(REFVNAME, '=', 1.0);
90 } else /* reference_count++ */
91 varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
92 }
93 curfunc = NULL; /* parse expressions */
94 sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
95 for (i=0, ne=0; ef && i < na; i++, ef>>=1)
96 if (ef & 1) { /* flagged as an expression? */
97 if (ne >= MAXEXPR)
98 objerror(m, INTERNAL, "too many expressions");
99 initstr(arg[i], sbuf, 0);
100 f->ep[ne++] = getE1();
101 if (nextc != EOF)
102 syntax("unexpected character");
103 }
104 if (ef)
105 goto toofew;
106 if (i <= ff) /* find transform args */
107 i = ff+1;
108 while (i < na && arg[i][0] != '-')
109 i++;
110 if (i == na) /* no transform */
111 f->f = f->b = &unitxf;
112 else { /* get transform */
113 if ((f->b = (XF *)malloc(sizeof(XF))) == NULL)
114 goto memerr;;
115 if (invxf(f->b, na-i, arg+i) != na-i)
116 objerror(m, USER, "bad transform");
117 if (f->b->sca < 0.0)
118 f->b->sca = -f->b->sca;
119 if (dofwd) { /* do both transforms */
120 if ((f->f = (XF *)malloc(sizeof(XF))) == NULL)
121 goto memerr;;
122 xf(f->f, na-i, arg+i);
123 if (f->f->sca < 0.0)
124 f->f->sca = -f->f->sca;
125 }
126 }
127 m->os = (char *)f;
128 return(f);
129 toofew:
130 objerror(m, USER, "too few arguments");
131 memerr:
132 error(SYSTEM, "out of memory in getfunc");
133 }
134
135
136 freefunc(m) /* free memory associated with modifier */
137 OBJREC *m;
138 {
139 register MFUNC *f;
140 register int i;
141
142 if ((f = (MFUNC *)m->os) == NULL)
143 return;
144 for (i = 0; f->ep[i] != NULL; i++)
145 epfree(f->ep[i]);
146 if (f->ctx[0]) { /* done with definitions */
147 setcontext(f->ctx);
148 i = varvalue(REFVNAME)-.5; /* reference_count-- */
149 if (i > 0)
150 varset(REFVNAME, '=', (double)i);
151 else
152 dcleanup(2); /* remove definitions */
153 freestr(f->ctx);
154 }
155 if (f->b != &unitxf)
156 free((char *)f->b);
157 if (f->f != NULL && f->f != &unitxf)
158 free((char *)f->f);
159 free((char *)f);
160 m->os = NULL;
161 }
162
163
164 setfunc(m, r) /* set channels for function call */
165 OBJREC *m;
166 register RAY *r;
167 {
168 static long lastrno = -1;
169 register MFUNC *f;
170 /* get function */
171 if ((f = (MFUNC *)m->os) == NULL)
172 error(m, CONSISTENCY, "setfunc called before getfunc");
173 /* set evaluator context */
174 setcontext(f->ctx);
175 /* check to see if matrix set */
176 if (m == fobj && r->rno == lastrno)
177 return(0);
178 fobj = m;
179 fray = r;
180 if (r->rox != NULL)
181 if (f->b != &unitxf) {
182 funcxf.sca = r->rox->b.sca * f->b->sca;
183 multmat4(funcxf.xfm, r->rox->b.xfm, f->b->xfm);
184 } else
185 copystruct(&funcxf, &r->rox->b);
186 else
187 copystruct(&funcxf, f->b);
188 lastrno = r->rno;
189 eclock++; /* notify expression evaluator */
190 return(1);
191 }
192
193
194 loadfunc(fname) /* load definition file */
195 char *fname;
196 {
197 extern char *libpath; /* library search path */
198 char *ffname;
199
200 if ((ffname = getpath(fname, libpath, R_OK)) == NULL) {
201 sprintf(errmsg, "cannot find function file \"%s\"", fname);
202 error(USER, errmsg);
203 }
204 fcompile(ffname);
205 }
206
207
208 static double
209 l_arg() /* return nth real argument */
210 {
211 extern double argument();
212 register int n;
213
214 n = argument(1) + .5; /* round to integer */
215
216 if (n < 1)
217 return(fobj->oargs.nfargs);
218
219 if (n > fobj->oargs.nfargs) {
220 sprintf(errmsg, "missing real argument %d", n);
221 objerror(fobj, USER, errmsg);
222 }
223 return(fobj->oargs.farg[n-1]);
224 }
225
226
227 static double
228 l_erf() /* error function */
229 {
230 extern double erf();
231
232 return(erf(argument(1)));
233 }
234
235
236 static double
237 l_erfc() /* cumulative error function */
238 {
239 extern double erfc();
240
241 return(erfc(argument(1)));
242 }
243
244
245 double
246 chanvalue(n) /* return channel n to calcomp */
247 register int n;
248 {
249 double sum;
250 register RAY *r;
251
252 if (--n < 0)
253 goto badchan;
254
255 if (n < 3) /* ray direction */
256
257 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
258 fray->rdir[1]*funcxf.xfm[1][n] +
259 fray->rdir[2]*funcxf.xfm[2][n] )
260 / funcxf.sca );
261
262 if (n < 6) /* surface normal */
263
264 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
265 fray->ron[1]*funcxf.xfm[1][n-3] +
266 fray->ron[2]*funcxf.xfm[2][n-3] )
267 / funcxf.sca );
268
269 if (n < 9) /* intersection */
270
271 return( fray->rop[0]*funcxf.xfm[0][n-6] +
272 fray->rop[1]*funcxf.xfm[1][n-6] +
273 fray->rop[2]*funcxf.xfm[2][n-6] +
274 funcxf.xfm[3][n-6] );
275
276 if (n == 9) { /* distance */
277
278 sum = fray->rot;
279 for (r = fray->parent; r != NULL; r = r->parent)
280 sum += r->rot;
281 return(sum * funcxf.sca);
282
283 }
284 if (n == 10) /* dot product (range [-1,1]) */
285 return( fray->rod <= -1.0 ? -1.0 :
286 fray->rod >= 1.0 ? 1.0 :
287 fray->rod );
288
289 if (n == 11) /* scale */
290 return(funcxf.sca);
291
292 if (n < 15) /* origin */
293 return(funcxf.xfm[3][n-12]);
294
295 if (n < 18) /* i unit vector */
296 return(funcxf.xfm[0][n-15] / funcxf.sca);
297
298 if (n < 21) /* j unit vector */
299 return(funcxf.xfm[1][n-15] / funcxf.sca);
300
301 if (n < 24) /* k unit vector */
302 return(funcxf.xfm[2][n-21] / funcxf.sca);
303 badchan:
304 error(USER, "illegal channel number");
305 }
