1 |
#ifndef lint |
2 |
static const char RCSid[] = "$Id$"; |
3 |
#endif |
4 |
5 |
* func.c - interface to calcomp functions. |
6 |
7 |
8 |
#include "copyright.h" |
9 |
10 |
#include "ray.h" |
11 |
12 |
#include "otypes.h" |
13 |
14 |
#include "func.h" |
15 |
16 |
17 |
#define INITFILE "rayinit.cal" |
18 |
#define CALSUF ".cal" |
19 |
#define LCALSUF 4 |
20 |
char REFVNAME[] = "`FILE_REFCNT"; |
21 |
22 |
XF unitxf = { /* identity transform */ |
23 |
{{1.0, 0.0, 0.0, 0.0}, |
24 |
{0.0, 1.0, 0.0, 0.0}, |
25 |
{0.0, 0.0, 1.0, 0.0}, |
26 |
{0.0, 0.0, 0.0, 1.0}}, |
27 |
1.0 |
28 |
29 |
30 |
XF funcxf; /* current transformation */ |
31 |
static OBJREC *fobj = NULL; /* current function object */ |
32 |
static RAY *fray = NULL; /* current function ray */ |
33 |
34 |
static double l_erf(), l_erfc(), l_arg(); |
35 |
36 |
37 |
MFUNC * |
38 |
getfunc(m, ff, ef, dofwd) /* get function for this modifier */ |
39 |
OBJREC *m; |
40 |
int ff; |
41 |
unsigned int ef; |
42 |
int dofwd; |
43 |
44 |
static char initfile[] = INITFILE; |
45 |
char sbuf[MAXSTR]; |
46 |
register char **arg; |
47 |
register MFUNC *f; |
48 |
int ne, na; |
49 |
register int i; |
50 |
/* check to see if done already */ |
51 |
if ((f = (MFUNC *)m->os) != NULL) |
52 |
return(f); |
53 |
fobj = NULL; fray = NULL; |
54 |
if (initfile[0]) { /* initialize on first call */ |
55 |
esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW; |
56 |
esupport &= ~(E_OUTCHAN); |
57 |
setcontext(""); |
58 |
scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0); |
59 |
scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0); |
60 |
scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0); |
61 |
scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0); |
62 |
scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0); |
63 |
scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0); |
64 |
scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0); |
65 |
scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0); |
66 |
scompile("Lu=$26;Lv=$27;", NULL, 0); |
67 |
funset("arg", 1, '=', l_arg); |
68 |
funset("erf", 1, ':', l_erf); |
69 |
funset("erfc", 1, ':', l_erfc); |
70 |
setnoisefuncs(); |
71 |
setprismfuncs(); |
72 |
loadfunc(initfile); |
73 |
initfile[0] = '\0'; |
74 |
75 |
if ((na = m->oargs.nsargs) <= ff) |
76 |
goto toofew; |
77 |
arg = m->oargs.sarg; |
78 |
if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL) |
79 |
goto memerr; |
80 |
i = strlen(arg[ff]); /* set up context */ |
81 |
if (i == 1 && arg[ff][0] == '.') |
82 |
setcontext(f->ctx = ""); /* "." means no file */ |
83 |
else { |
84 |
strcpy(sbuf,arg[ff]); /* file name is context */ |
85 |
if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF)) |
86 |
sbuf[i-LCALSUF] = '\0'; /* remove suffix */ |
87 |
setcontext(f->ctx = savestr(sbuf)); |
88 |
if (!vardefined(REFVNAME)) { /* file loaded? */ |
89 |
loadfunc(arg[ff]); |
90 |
varset(REFVNAME, '=', 1.0); |
91 |
} else /* reference_count++ */ |
92 |
varset(REFVNAME, '=', varvalue(REFVNAME)+1.0); |
93 |
94 |
curfunc = NULL; /* parse expressions */ |
95 |
sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname); |
96 |
for (i=0, ne=0; ef && i < na; i++, ef>>=1) |
97 |
if (ef & 1) { /* flagged as an expression? */ |
98 |
if (ne >= MAXEXPR) |
99 |
objerror(m, INTERNAL, "too many expressions"); |
100 |
initstr(arg[i], sbuf, 0); |
101 |
f->ep[ne++] = getE1(); |
102 |
if (nextc != EOF) |
103 |
syntax("unexpected character"); |
104 |
105 |
if (ef) |
106 |
goto toofew; |
107 |
if (i <= ff) /* find transform args */ |
108 |
i = ff+1; |
109 |
while (i < na && arg[i][0] != '-') |
110 |
i++; |
111 |
if (i == na) /* no transform */ |
112 |
f->f = f->b = &unitxf; |
113 |
else { /* get transform */ |
114 |
if ((f->b = (XF *)malloc(sizeof(XF))) == NULL) |
115 |
goto memerr; |
116 |
if (invxf(f->b, na-i, arg+i) != na-i) |
117 |
objerror(m, USER, "bad transform"); |
118 |
if (f->b->sca < 0.0) |
119 |
f->b->sca = -f->b->sca; |
120 |
if (dofwd) { /* do both transforms */ |
121 |
if ((f->f = (XF *)malloc(sizeof(XF))) == NULL) |
122 |
goto memerr; |
123 |
xf(f->f, na-i, arg+i); |
124 |
if (f->f->sca < 0.0) |
125 |
f->f->sca = -f->f->sca; |
126 |
127 |
128 |
m->os = (char *)f; |
129 |
return(f); |
130 |
toofew: |
131 |
objerror(m, USER, "too few string arguments"); |
132 |
memerr: |
133 |
error(SYSTEM, "out of memory in getfunc"); |
134 |
135 |
136 |
137 |
void |
138 |
freefunc(m) /* free memory associated with modifier */ |
139 |
OBJREC *m; |
140 |
141 |
142 |
register int i; |
143 |
144 |
if ((f = (MFUNC *)m->os) == NULL) |
145 |
return; |
146 |
for (i = 0; f->ep[i] != NULL; i++) |
147 |
epfree(f->ep[i]); |
148 |
if (f->ctx[0]) { /* done with definitions */ |
149 |
setcontext(f->ctx); |
150 |
i = varvalue(REFVNAME)-.5; /* reference_count-- */ |
151 |
if (i > 0) |
152 |
varset(REFVNAME, '=', (double)i); |
153 |
else |
154 |
dcleanup(2); /* remove definitions */ |
155 |
freestr(f->ctx); |
156 |
157 |
if (f->b != &unitxf) |
158 |
free((void *)f->b); |
159 |
if (f->f != NULL && f->f != &unitxf) |
160 |
free((void *)f->f); |
161 |
free((void *)f); |
162 |
m->os = NULL; |
163 |
164 |
165 |
166 |
int |
167 |
setfunc(m, r) /* set channels for function call */ |
168 |
OBJREC *m; |
169 |
register RAY *r; |
170 |
171 |
static unsigned long lastrno = ~0; |
172 |
173 |
/* get function */ |
174 |
175 |
objerror(m, CONSISTENCY, "setfunc called before getfunc"); |
176 |
/* set evaluator context */ |
177 |
178 |
/* check to see if matrix set */ |
179 |
if (m == fobj && r->rno == lastrno) |
180 |
return(0); |
181 |
fobj = m; |
182 |
fray = r; |
183 |
if (r->rox != NULL) |
184 |
if (f->b != &unitxf) { |
185 |
funcxf.sca = r->rox->b.sca * f->b->sca; |
186 |
multmat4(funcxf.xfm, r->rox->b.xfm, f->b->xfm); |
187 |
} else |
188 |
copystruct(&funcxf, &r->rox->b); |
189 |
else |
190 |
copystruct(&funcxf, f->b); |
191 |
lastrno = r->rno; |
192 |
eclock++; /* notify expression evaluator */ |
193 |
return(1); |
194 |
195 |
196 |
197 |
void |
198 |
loadfunc(fname) /* load definition file */ |
199 |
char *fname; |
200 |
201 |
char *ffname; |
202 |
203 |
if ((ffname = getpath(fname, getrlibpath(), R_OK)) == NULL) { |
204 |
sprintf(errmsg, "cannot find function file \"%s\"", fname); |
205 |
error(USER, errmsg); |
206 |
207 |
fcompile(ffname); |
208 |
209 |
210 |
211 |
static double |
212 |
l_arg() /* return nth real argument */ |
213 |
214 |
register int n; |
215 |
216 |
if (fobj == NULL) |
217 |
syntax("arg(n) used in constant expression"); |
218 |
219 |
n = argument(1) + .5; /* round to integer */ |
220 |
221 |
if (n < 1) |
222 |
return(fobj->oargs.nfargs); |
223 |
224 |
if (n > fobj->oargs.nfargs) { |
225 |
sprintf(errmsg, "missing real argument %d", n); |
226 |
objerror(fobj, USER, errmsg); |
227 |
228 |
return(fobj->oargs.farg[n-1]); |
229 |
230 |
231 |
232 |
static double |
233 |
l_erf() /* error function */ |
234 |
235 |
extern double erf(); |
236 |
237 |
return(erf(argument(1))); |
238 |
239 |
240 |
241 |
static double |
242 |
l_erfc() /* cumulative error function */ |
243 |
244 |
extern double erfc(); |
245 |
246 |
return(erfc(argument(1))); |
247 |
248 |
249 |
250 |
double |
251 |
chanvalue(n) /* return channel n to calcomp */ |
252 |
register int n; |
253 |
254 |
if (fray == NULL) |
255 |
syntax("ray parameter used in constant expression"); |
256 |
257 |
if (--n < 0) |
258 |
goto badchan; |
259 |
260 |
if (n <= 2) /* ray direction */ |
261 |
262 |
return( ( fray->rdir[0]*funcxf.xfm[0][n] + |
263 |
fray->rdir[1]*funcxf.xfm[1][n] + |
264 |
fray->rdir[2]*funcxf.xfm[2][n] ) |
265 |
/ funcxf.sca ); |
266 |
267 |
if (n <= 5) /* surface normal */ |
268 |
269 |
return( ( fray->ron[0]*funcxf.xfm[0][n-3] + |
270 |
fray->ron[1]*funcxf.xfm[1][n-3] + |
271 |
fray->ron[2]*funcxf.xfm[2][n-3] ) |
272 |
/ funcxf.sca ); |
273 |
274 |
if (n <= 8) /* intersection */ |
275 |
276 |
return( fray->rop[0]*funcxf.xfm[0][n-6] + |
277 |
fray->rop[1]*funcxf.xfm[1][n-6] + |
278 |
fray->rop[2]*funcxf.xfm[2][n-6] + |
279 |
funcxf.xfm[3][n-6] ); |
280 |
281 |
if (n == 9) /* total distance */ |
282 |
return(raydist(fray,PRIMARY) * funcxf.sca); |
283 |
284 |
if (n == 10) /* dot product (range [-1,1]) */ |
285 |
return( fray->rod <= -1.0 ? -1.0 : |
286 |
fray->rod >= 1.0 ? 1.0 : |
287 |
fray->rod ); |
288 |
289 |
if (n == 11) /* scale */ |
290 |
return(funcxf.sca); |
291 |
292 |
if (n <= 14) /* origin */ |
293 |
return(funcxf.xfm[3][n-12]); |
294 |
295 |
if (n <= 17) /* i unit vector */ |
296 |
return(funcxf.xfm[0][n-15] / funcxf.sca); |
297 |
298 |
if (n <= 20) /* j unit vector */ |
299 |
return(funcxf.xfm[1][n-18] / funcxf.sca); |
300 |
301 |
if (n <= 23) /* k unit vector */ |
302 |
return(funcxf.xfm[2][n-21] / funcxf.sca); |
303 |
304 |
if (n == 24) /* single ray (shadow) distance */ |
305 |
return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca); |
306 |
307 |
if (n <= 26) /* local (u,v) coordinates */ |
308 |
return(fray->uv[n-25]); |
309 |
badchan: |
310 |
error(USER, "illegal channel number"); |
311 |
return(0.0); |
312 |
