root/radiance/ray/src/rt/func.c
Revision: 2.10
Committed: Tue Aug 3 12:04:58 1993 UTC (30 years, 9 months ago) by greg
minor optimization in use of REFVNAME (macro -> char constant)
1 /* Copyright (c) 1992 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * func.c - interface to calcomp functions.
9 *
10 * 4/7/86
11 */
12
13 #include "ray.h"
14
15 #include "otypes.h"
16
17 #include "func.h"
18
19
20 #define INITFILE "rayinit.cal"
21 #define CALSUF ".cal"
22 #define LCALSUF 4
23 char REFVNAME[] = "`FILE_REFCNT";
24
25 XF unitxf = { /* identity transform */
26 {{1.0, 0.0, 0.0, 0.0},
27 {0.0, 1.0, 0.0, 0.0},
28 {0.0, 0.0, 1.0, 0.0},
29 {0.0, 0.0, 0.0, 1.0}},
30 1.0
31 };
32
33 XF funcxf; /* current transformation */
34 static OBJREC *fobj = NULL; /* current function object */
35 static RAY *fray = NULL; /* current function ray */
36
37 static double l_erf(), l_erfc(), l_arg();
38
39
40 MFUNC *
41 getfunc(m, ff, ef, dofwd) /* get function for this modifier */
42 OBJREC *m;
43 int ff;
44 unsigned ef;
45 int dofwd;
46 {
47 extern EPNODE *curfunc;
48 static char initfile[] = INITFILE;
49 char sbuf[MAXSTR];
50 register char **arg;
51 register MFUNC *f;
52 int ne, na;
53 register int i;
54 /* check to see if done already */
55 if ((f = (MFUNC *)m->os) != NULL)
56 return(f);
57 fobj = NULL; fray = NULL;
58 if (initfile[0]) { /* initialize on first call */
59 setcontext("");
60 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
61 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
62 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
63 scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0);
64 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
65 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
66 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
67 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
68 funset("arg", 1, '=', l_arg);
69 funset("erf", 1, ':', l_erf);
70 funset("erfc", 1, ':', l_erfc);
71 setnoisefuncs();
72 loadfunc(initfile);
73 initfile[0] = '\0';
74 }
75 if ((na = m->oargs.nsargs) <= ff)
76 goto toofew;
77 arg = m->oargs.sarg;
78 if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
79 goto memerr;
80 i = strlen(arg[ff]); /* set up context */
81 if (i == 1 && arg[ff][0] == '.')
82 setcontext(f->ctx = ""); /* "." means no file */
83 else {
84 strcpy(sbuf,arg[ff]); /* file name is context */
85 if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
86 sbuf[i-LCALSUF] = '\0'; /* remove suffix */
87 setcontext(f->ctx = savestr(sbuf));
88 if (!vardefined(REFVNAME)) { /* file loaded? */
89 loadfunc(arg[ff]);
90 varset(REFVNAME, '=', 1.0);
91 } else /* reference_count++ */
92 varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
93 }
94 curfunc = NULL; /* parse expressions */
95 sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
96 for (i=0, ne=0; ef && i < na; i++, ef>>=1)
97 if (ef & 1) { /* flagged as an expression? */
98 if (ne >= MAXEXPR)
99 objerror(m, INTERNAL, "too many expressions");
100 initstr(arg[i], sbuf, 0);
101 f->ep[ne++] = getE1();
102 if (nextc != EOF)
103 syntax("unexpected character");
104 }
105 if (ef)
106 goto toofew;
107 if (i <= ff) /* find transform args */
108 i = ff+1;
109 while (i < na && arg[i][0] != '-')
110 i++;
111 if (i == na) /* no transform */
112 f->f = f->b = &unitxf;
113 else { /* get transform */
114 if ((f->b = (XF *)malloc(sizeof(XF))) == NULL)
115 goto memerr;
116 if (invxf(f->b, na-i, arg+i) != na-i)
117 objerror(m, USER, "bad transform");
118 if (f->b->sca < 0.0)
119 f->b->sca = -f->b->sca;
120 if (dofwd) { /* do both transforms */
121 if ((f->f = (XF *)malloc(sizeof(XF))) == NULL)
122 goto memerr;
123 xf(f->f, na-i, arg+i);
124 if (f->f->sca < 0.0)
125 f->f->sca = -f->f->sca;
126 }
127 }
128 m->os = (char *)f;
129 return(f);
130 toofew:
131 objerror(m, USER, "too few string arguments");
132 memerr:
133 error(SYSTEM, "out of memory in getfunc");
134 }
135
136
137 freefunc(m) /* free memory associated with modifier */
138 OBJREC *m;
139 {
140 register MFUNC *f;
141 register int i;
142
143 if ((f = (MFUNC *)m->os) == NULL)
144 return;
145 for (i = 0; f->ep[i] != NULL; i++)
146 epfree(f->ep[i]);
147 if (f->ctx[0]) { /* done with definitions */
148 setcontext(f->ctx);
149 i = varvalue(REFVNAME)-.5; /* reference_count-- */
150 if (i > 0)
151 varset(REFVNAME, '=', (double)i);
152 else
153 dcleanup(2); /* remove definitions */
154 freestr(f->ctx);
155 }
156 if (f->b != &unitxf)
157 free((char *)f->b);
158 if (f->f != NULL && f->f != &unitxf)
159 free((char *)f->f);
160 free((char *)f);
161 m->os = NULL;
162 }
163
164
165 setfunc(m, r) /* set channels for function call */
166 OBJREC *m;
167 register RAY *r;
168 {
169 static unsigned long lastrno = ~0;
170 register MFUNC *f;
171 /* get function */
172 if ((f = (MFUNC *)m->os) == NULL)
173 error(m, CONSISTENCY, "setfunc called before getfunc");
174 /* set evaluator context */
175 setcontext(f->ctx);
176 /* check to see if matrix set */
177 if (m == fobj && r->rno == lastrno)
178 return(0);
179 fobj = m;
180 fray = r;
181 if (r->rox != NULL)
182 if (f->b != &unitxf) {
183 funcxf.sca = r->rox->b.sca * f->b->sca;
184 multmat4(funcxf.xfm, r->rox->b.xfm, f->b->xfm);
185 } else
186 copystruct(&funcxf, &r->rox->b);
187 else
188 copystruct(&funcxf, f->b);
189 lastrno = r->rno;
190 eclock++; /* notify expression evaluator */
191 return(1);
192 }
193
194
195 loadfunc(fname) /* load definition file */
196 char *fname;
197 {
198 extern char *libpath; /* library search path */
199 char *ffname;
200
201 if ((ffname = getpath(fname, libpath, R_OK)) == NULL) {
202 sprintf(errmsg, "cannot find function file \"%s\"", fname);
203 error(USER, errmsg);
204 }
205 fcompile(ffname);
206 }
207
208
209 static double
210 l_arg() /* return nth real argument */
211 {
212 extern double argument();
213 register int n;
214
215 if (fobj == NULL)
216 syntax("arg(n) used in constant expression");
217
218 n = argument(1) + .5; /* round to integer */
219
220 if (n < 1)
221 return(fobj->oargs.nfargs);
222
223 if (n > fobj->oargs.nfargs) {
224 sprintf(errmsg, "missing real argument %d", n);
225 objerror(fobj, USER, errmsg);
226 }
227 return(fobj->oargs.farg[n-1]);
228 }
229
230
231 static double
232 l_erf() /* error function */
233 {
234 extern double erf();
235
236 return(erf(argument(1)));
237 }
238
239
240 static double
241 l_erfc() /* cumulative error function */
242 {
243 extern double erfc();
244
245 return(erfc(argument(1)));
246 }
247
248
249 double
250 chanvalue(n) /* return channel n to calcomp */
251 register int n;
252 {
253 double sum;
254 register RAY *r;
255
256 if (fray == NULL)
257 syntax("ray parameter used in constant expression");
258
259 if (--n < 0)
260 goto badchan;
261
262 if (n < 3) /* ray direction */
263
264 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
265 fray->rdir[1]*funcxf.xfm[1][n] +
266 fray->rdir[2]*funcxf.xfm[2][n] )
267 / funcxf.sca );
268
269 if (n < 6) /* surface normal */
270
271 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
272 fray->ron[1]*funcxf.xfm[1][n-3] +
273 fray->ron[2]*funcxf.xfm[2][n-3] )
274 / funcxf.sca );
275
276 if (n < 9) /* intersection */
277
278 return( fray->rop[0]*funcxf.xfm[0][n-6] +
279 fray->rop[1]*funcxf.xfm[1][n-6] +
280 fray->rop[2]*funcxf.xfm[2][n-6] +
281 funcxf.xfm[3][n-6] );
282
283 if (n == 9) { /* total distance */
284 sum = fray->rot;
285 for (r = fray->parent; r != NULL; r = r->parent)
286 sum += r->rot;
287 return(sum * funcxf.sca);
288
289 }
290
291 if (n == 10) /* dot product (range [-1,1]) */
292 return( fray->rod <= -1.0 ? -1.0 :
293 fray->rod >= 1.0 ? 1.0 :
294 fray->rod );
295
296 if (n == 11) /* scale */
297 return(funcxf.sca);
298
299 if (n < 15) /* origin */
300 return(funcxf.xfm[3][n-12]);
301
302 if (n < 18) /* i unit vector */
303 return(funcxf.xfm[0][n-15] / funcxf.sca);
304
305 if (n < 21) /* j unit vector */
306 return(funcxf.xfm[1][n-15] / funcxf.sca);
307
308 if (n < 24) /* k unit vector */
309 return(funcxf.xfm[2][n-21] / funcxf.sca);
310
311 if (n == 24) { /* single ray (shadow) distance */
312 sum = fray->rot;
313 for (r = fray->parent; r != NULL && r->crtype&SHADOW;
314 r = r->parent)
315 sum += r->rot;
316 return(sum * funcxf.sca);
317 }
318 badchan:
319 error(USER, "illegal channel number");
320 }
