root/radiance/ray/src/rt/func.c
Revision: 1.8
Committed: Sat Apr 7 16:12:56 1990 UTC (35 years, 1 month ago) by greg
Changes since 1.7: +47 -26 lines
added direct access to coordinate transformation
1 /* Copyright (c) 1986 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * func.c - interface to calcomp functions.
9 *
10 * 4/7/86
11 */
12
13 #include "ray.h"
14
15 #include "otypes.h"
16
17
18 typedef struct {
19 double xfm[4][4]; /* transform matrix */
20 double sca; /* scalefactor */
21 } XF;
22
23 static OBJREC *fobj; /* current function object */
24 static RAY *fray; /* current function ray */
25 static XF fxf; /* current transformation */
26
27
28 setmap(m, r, xfm, sca) /* set channels for function call */
29 OBJREC *m;
30 register RAY *r;
31 double xfm[4][4];
32 double sca;
33 {
34 extern double l_noise3(), l_noise3a(), l_noise3b(), l_noise3c();
35 extern double l_hermite(), l_fnoise3(), l_arg();
36 extern long eclock;
37 static char *initfile = "rayinit.cal";
38
39 if (initfile != NULL) {
40 loadfunc(initfile);
41 scompile(NULL, "Dx=$1;Dy=$2;Dz=$3;");
42 scompile(NULL, "Nx=$4;Ny=$5;Nz=$6;");
43 scompile(NULL, "Px=$7;Py=$8;Pz=$9;");
44 scompile(NULL, "T=$10;Rdot=$11;");
45 scompile(NULL, "S=$12;Tx=$13;Ty=$14;Tz=$15;");
46 scompile(NULL, "Ix=$16;Iy=$17;Iz=$18;");
47 scompile(NULL, "Jx=$19;Jy=$20;Jz=$21;");
48 scompile(NULL, "Kx=$22;Ky=$23;Kz=$24;");
49 funset("arg", 1, l_arg);
50 funset("noise3", 3, l_noise3);
51 funset("noise3a", 3, l_noise3a);
52 funset("noise3b", 3, l_noise3b);
53 funset("noise3c", 3, l_noise3c);
54 funset("hermite", 5, l_hermite);
55 funset("fnoise3", 3, l_fnoise3);
56 initfile = NULL;
57 }
58 fobj = m;
59 fray = r;
60 fxf.sca = r->robs * sca;
61 multmat4(fxf.xfm, r->robx, xfm);
62 eclock++; /* notify expression evaluator */
63 }
64
65
66 setfunc(m, r) /* simplified interface to setmap */
67 register OBJREC *m;
68 RAY *r;
69 {
70 register XF *mxf;
71
72 if ((mxf = (XF *)m->os) == NULL) {
73 register int n;
74 register char **sa;
75
76 for (n = m->oargs.nsargs, sa = m->oargs.sarg;
77 n > 0 && **sa != '-'; n--, sa++)
78 ;
79 mxf = (XF *)malloc(sizeof(XF));
80 if (mxf == NULL)
81 goto memerr;
82 if (invxf(mxf->xfm, &mxf->sca, n, sa) != n)
83 objerror(m, USER, "bad transform");
84 if (mxf->sca < 0.0)
85 mxf->sca = -mxf->sca;
86 m->os = (char *)mxf;
87 }
88 setmap(m, r, mxf->xfm, mxf->sca);
89 return;
90 memerr:
91 error(SYSTEM, "out of memory in setfunc");
92 #undef mxf
93 }
94
95
96 loadfunc(fname) /* load definition file */
97 char *fname;
98 {
99 extern char *libpath; /* library search path */
100 char *ffname;
101
102 if ((ffname = getpath(fname, libpath, R_OK)) == NULL) {
103 sprintf(errmsg, "cannot find function file \"%s\"", fname);
104 error(USER, errmsg);
105 }
106 fcompile(ffname);
107 }
108
109
110 double
111 l_arg() /* return nth real argument */
112 {
113 extern double argument();
114 register int n;
115
116 n = argument(1) + .5; /* round to integer */
117
118 if (n < 1)
119 return(fobj->oargs.nfargs);
120
121 if (n > fobj->oargs.nfargs) {
122 sprintf(errmsg, "missing real argument %d", n);
123 objerror(fobj, USER, errmsg);
124 }
125 return(fobj->oargs.farg[n-1]);
126 }
127
128
129 double
130 chanvalue(n) /* return channel n to calcomp */
131 register int n;
132 {
133 double sum;
134 register RAY *r;
135
136 n--; /* for convenience */
137
138 if (n < 0 || n > 23)
139 error(USER, "illegal channel number");
140
141 if (n == 9) { /* distance */
142
143 sum = fray->rot;
144 for (r = fray->parent; r != NULL; r = r->parent)
145 sum += r->rot;
146 return(sum * fxf.sca);
147
148 }
149 if (n == 10) /* dot product */
150 return(fray->rod);
151
152 if (n < 3) /* ray direction */
153
154 return( ( fray->rdir[0]*fxf.xfm[0][n] +
155 fray->rdir[1]*fxf.xfm[1][n] +
156 fray->rdir[2]*fxf.xfm[2][n] )
157 / fxf.sca );
158
159 if (n < 6) /* surface normal */
160
161 return( ( fray->ron[0]*fxf.xfm[0][n-3] +
162 fray->ron[1]*fxf.xfm[1][n-3] +
163 fray->ron[2]*fxf.xfm[2][n-3] )
164 / fxf.sca );
165
166 if (n < 9) /* intersection */
167
168 return( fray->rop[0]*fxf.xfm[0][n-6] +
169 fray->rop[1]*fxf.xfm[1][n-6] +
170 fray->rop[2]*fxf.xfm[2][n-6] +
171 fxf.xfm[3][n-6] );
172
173 if (n == 11) /* scale */
174 return(fxf.sca);
175
176 if (n < 15) /* origin */
177 return(fxf.xfm[3][n-12]);
178
179 if (n < 18) /* i unit vector */
180 return(fxf.xfm[0][n-15] / fxf.sca);
181
182 if (n < 21) /* j unit vector */
183 return(fxf.xfm[1][n-15] / fxf.sca);
184
185 if (n < 24) /* k unit vector */
186 return(fxf.xfm[2][n-21] / fxf.sca);
187 }
