root/Development/ray/src/rt/func.c
Revision: 1.22
Committed: Thu Aug 8 15:41:14 1991 UTC (34 years, 5 months ago) by greg
Changes since 1.21: +9 -5 lines
added special case for "." meaning no function file
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * func.c - interface to calcomp functions.
9 *
10 * 4/7/86
11 */
12
13 #include "ray.h"
14
15 #include "otypes.h"
16
17
18 #define INITFILE "rayinit.cal"
19 #define DEFVNAME "FILE_LOADED`"
20
21 XF unitxf = { /* identity transform */
22 1.0, 0.0, 0.0, 0.0,
23 0.0, 1.0, 0.0, 0.0,
24 0.0, 0.0, 1.0, 0.0,
25 0.0, 0.0, 0.0, 1.0,
26 1.0
27 };
28
29 XF funcxf; /* current transformation */
30 static OBJREC *fobj = NULL; /* current function object */
31 static RAY *fray = NULL; /* current function ray */
32
33
34 setmap(m, r, bx) /* set channels for function call */
35 OBJREC *m;
36 register RAY *r;
37 XF *bx;
38 {
39 extern long eclock;
40 static long lastrno = -1;
41 /* check to see if already set */
42 if (m == fobj && r->rno == lastrno)
43 return(0);
44 fobj = m;
45 fray = r;
46 if (r->rox != NULL)
47 if (bx != &unitxf) {
48 funcxf.sca = r->rox->b.sca * bx->sca;
49 multmat4(funcxf.xfm, r->rox->b.xfm, bx->xfm);
50 } else
51 copystruct(&funcxf, &r->rox->b);
52 else
53 copystruct(&funcxf, bx);
54 lastrno = r->rno;
55 eclock++; /* notify expression evaluator */
56 return(1);
57 }
58
59
60 setfunc(m, r) /* simplified interface to setmap */
61 register OBJREC *m;
62 RAY *r;
63 {
64 register XF *mxf;
65
66 if ((mxf = (XF *)m->os) == NULL) {
67 register int n;
68 register char **sa;
69
70 for (n = m->oargs.nsargs, sa = m->oargs.sarg;
71 n > 0 && **sa != '-'; n--, sa++)
72 ;
73 if (n == 0)
74 mxf = &unitxf;
75 else {
76 mxf = (XF *)malloc(sizeof(XF));
77 if (mxf == NULL)
78 goto memerr;
79 if (invxf(mxf, n, sa) != n)
80 objerror(m, USER, "bad transform");
81 if (mxf->sca < 0.0)
82 mxf->sca = -mxf->sca;
83 }
84 m->os = (char *)mxf;
85 }
86 return(setmap(m, r, mxf));
87 memerr:
88 error(SYSTEM, "out of memory in setfunc");
89 }
90
91
92 loadfunc(fname) /* load definition file */
93 char *fname;
94 {
95 extern char *libpath; /* library search path */
96 char *ffname;
97
98 if ((ffname = getpath(fname, libpath, R_OK)) == NULL) {
99 sprintf(errmsg, "cannot find function file \"%s\"", fname);
100 error(USER, errmsg);
101 }
102 fcompile(ffname);
103 }
104
105
106 double
107 l_arg() /* return nth real argument */
108 {
109 extern double argument();
110 register int n;
111
112 n = argument(1) + .5; /* round to integer */
113
114 if (n < 1)
115 return(fobj->oargs.nfargs);
116
117 if (n > fobj->oargs.nfargs) {
118 sprintf(errmsg, "missing real argument %d", n);
119 objerror(fobj, USER, errmsg);
120 }
121 return(fobj->oargs.farg[n-1]);
122 }
123
124
125 double
126 l_erf() /* error function */
127 {
128 extern double erf();
129
130 return(erf(argument(1)));
131 }
132
133
134 double
135 l_erfc() /* cumulative error function */
136 {
137 extern double erfc();
138
139 return(erfc(argument(1)));
140 }
141
142
143 funcfile(fname) /* set context, load file if necessary */
144 register char *fname;
145 {
146 extern char *setcontext();
147 static char initfile[] = INITFILE;
148
149 if (initfile[0]) { /* initialize on first call */
150 setcontext("");
151 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
152 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
153 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
154 scompile("T=$10;Rdot=$11;", NULL, 0);
155 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
156 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
157 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
158 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
159 funset("arg", 1, '=', l_arg);
160 funset("erf", 1, ':', l_erf);
161 funset("erfc", 1, ':', l_erfc);
162 setnoisefuncs();
163 loadfunc(initfile);
164 initfile[0] = '\0';
165 }
166 if (fname[0] == '.' && fname[1] == '\0')
167 setcontext(""); /* "." means no file */
168 else {
169 setcontext(fname);
170 if (!vardefined(DEFVNAME)) {
171 loadfunc(fname);
172 varset(DEFVNAME, ':', 1.0);
173 }
174 }
175 }
176
177
178 double
179 chanvalue(n) /* return channel n to calcomp */
180 register int n;
181 {
182 double sum;
183 register RAY *r;
184
185 if (--n < 0)
186 goto badchan;
187
188 if (n < 3) /* ray direction */
189
190 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
191 fray->rdir[1]*funcxf.xfm[1][n] +
192 fray->rdir[2]*funcxf.xfm[2][n] )
193 / funcxf.sca );
194
195 if (n < 6) /* surface normal */
196
197 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
198 fray->ron[1]*funcxf.xfm[1][n-3] +
199 fray->ron[2]*funcxf.xfm[2][n-3] )
200 / funcxf.sca );
201
202 if (n < 9) /* intersection */
203
204 return( fray->rop[0]*funcxf.xfm[0][n-6] +
205 fray->rop[1]*funcxf.xfm[1][n-6] +
206 fray->rop[2]*funcxf.xfm[2][n-6] +
207 funcxf.xfm[3][n-6] );
208
209 if (n == 9) { /* distance */
210
211 sum = fray->rot;
212 for (r = fray->parent; r != NULL; r = r->parent)
213 sum += r->rot;
214 return(sum * funcxf.sca);
215
216 }
217 if (n == 10) /* dot product (range [-1,1]) */
218 return( fray->rod <= -1.0 ? -1.0 :
219 fray->rod >= 1.0 ? 1.0 :
220 fray->rod );
221
222 if (n == 11) /* scale */
223 return(funcxf.sca);
224
225 if (n < 15) /* origin */
226 return(funcxf.xfm[3][n-12]);
227
228 if (n < 18) /* i unit vector */
229 return(funcxf.xfm[0][n-15] / funcxf.sca);
230
231 if (n < 21) /* j unit vector */
232 return(funcxf.xfm[1][n-15] / funcxf.sca);
233
234 if (n < 24) /* k unit vector */
235 return(funcxf.xfm[2][n-21] / funcxf.sca);
236 badchan:
237 error(USER, "illegal channel number");
238 }
