1 |
/* Copyright (c) 1991 Regents of the University of California */ |
2 |
3 |
#ifndef lint |
4 |
static char SCCSid[] = "$SunId$ LBL"; |
5 |
#endif |
6 |
7 |
8 |
* func.c - interface to calcomp functions. |
9 |
10 |
* 4/7/86 |
11 |
12 |
13 |
#include "ray.h" |
14 |
15 |
#include "otypes.h" |
16 |
17 |
18 |
#define INITFILE "rayinit.cal" |
19 |
#define DEFVNAME "FILE_LOADED`" |
20 |
21 |
XF unitxf = { /* identity transform */ |
22 |
1.0, 0.0, 0.0, 0.0, |
23 |
0.0, 1.0, 0.0, 0.0, |
24 |
0.0, 0.0, 1.0, 0.0, |
25 |
0.0, 0.0, 0.0, 1.0, |
26 |
1.0 |
27 |
28 |
29 |
XF funcxf; /* current transformation */ |
30 |
static OBJREC *fobj = NULL; /* current function object */ |
31 |
static RAY *fray = NULL; /* current function ray */ |
32 |
33 |
34 |
setmap(m, r, bx) /* set channels for function call */ |
35 |
OBJREC *m; |
36 |
register RAY *r; |
37 |
XF *bx; |
38 |
39 |
extern long eclock; |
40 |
static long lastrno = -1; |
41 |
/* check to see if already set */ |
42 |
if (m == fobj && r->rno == lastrno) |
43 |
return(0); |
44 |
fobj = m; |
45 |
fray = r; |
46 |
if (r->rox != NULL) |
47 |
if (bx != &unitxf) { |
48 |
funcxf.sca = r->rox->b.sca * bx->sca; |
49 |
multmat4(funcxf.xfm, r->rox->b.xfm, bx->xfm); |
50 |
} else |
51 |
copystruct(&funcxf, &r->rox->b); |
52 |
else |
53 |
copystruct(&funcxf, bx); |
54 |
lastrno = r->rno; |
55 |
eclock++; /* notify expression evaluator */ |
56 |
return(1); |
57 |
58 |
59 |
60 |
setfunc(m, r) /* simplified interface to setmap */ |
61 |
register OBJREC *m; |
62 |
RAY *r; |
63 |
64 |
register XF *mxf; |
65 |
66 |
if ((mxf = (XF *)m->os) == NULL) { |
67 |
register int n; |
68 |
register char **sa; |
69 |
70 |
for (n = m->oargs.nsargs, sa = m->oargs.sarg; |
71 |
n > 0 && **sa != '-'; n--, sa++) |
72 |
73 |
if (n == 0) |
74 |
mxf = &unitxf; |
75 |
else { |
76 |
mxf = (XF *)malloc(sizeof(XF)); |
77 |
if (mxf == NULL) |
78 |
goto memerr; |
79 |
if (invxf(mxf, n, sa) != n) |
80 |
objerror(m, USER, "bad transform"); |
81 |
if (mxf->sca < 0.0) |
82 |
mxf->sca = -mxf->sca; |
83 |
84 |
m->os = (char *)mxf; |
85 |
86 |
return(setmap(m, r, mxf)); |
87 |
memerr: |
88 |
error(SYSTEM, "out of memory in setfunc"); |
89 |
90 |
91 |
92 |
loadfunc(fname) /* load definition file */ |
93 |
char *fname; |
94 |
95 |
extern char *libpath; /* library search path */ |
96 |
char *ffname; |
97 |
98 |
if ((ffname = getpath(fname, libpath, R_OK)) == NULL) { |
99 |
sprintf(errmsg, "cannot find function file \"%s\"", fname); |
100 |
error(USER, errmsg); |
101 |
102 |
fcompile(ffname); |
103 |
104 |
105 |
106 |
double |
107 |
l_arg() /* return nth real argument */ |
108 |
109 |
extern double argument(); |
110 |
register int n; |
111 |
112 |
n = argument(1) + .5; /* round to integer */ |
113 |
114 |
if (n < 1) |
115 |
return(fobj->oargs.nfargs); |
116 |
117 |
if (n > fobj->oargs.nfargs) { |
118 |
sprintf(errmsg, "missing real argument %d", n); |
119 |
objerror(fobj, USER, errmsg); |
120 |
121 |
return(fobj->oargs.farg[n-1]); |
122 |
123 |
124 |
125 |
double |
126 |
l_erf() /* error function */ |
127 |
128 |
extern double erf(); |
129 |
130 |
return(erf(argument(1))); |
131 |
132 |
133 |
134 |
double |
135 |
l_erfc() /* cumulative error function */ |
136 |
137 |
extern double erfc(); |
138 |
139 |
return(erfc(argument(1))); |
140 |
141 |
142 |
143 |
funcfile(fname) /* set context, load file if necessary */ |
144 |
char *fname; |
145 |
146 |
extern char *setcontext(); |
147 |
static char initfile[] = INITFILE; |
148 |
149 |
if (initfile[0]) { /* initialize on first call */ |
150 |
setcontext(""); |
151 |
scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0); |
152 |
scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0); |
153 |
scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0); |
154 |
scompile("T=$10;Rdot=$11;", NULL, 0); |
155 |
scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0); |
156 |
scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0); |
157 |
scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0); |
158 |
scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0); |
159 |
funset("arg", 1, '=', l_arg); |
160 |
funset("erf", 1, ':', l_erf); |
161 |
funset("erfc", 1, ':', l_erfc); |
162 |
setnoisefuncs(); |
163 |
loadfunc(initfile); |
164 |
initfile[0] = '\0'; |
165 |
166 |
setcontext(fname); |
167 |
if (!vardefined(DEFVNAME)) { |
168 |
loadfunc(fname); |
169 |
varset(DEFVNAME, ':', 1.0); |
170 |
171 |
172 |
173 |
174 |
double |
175 |
chanvalue(n) /* return channel n to calcomp */ |
176 |
register int n; |
177 |
178 |
double sum; |
179 |
register RAY *r; |
180 |
181 |
if (--n < 0) |
182 |
goto badchan; |
183 |
184 |
if (n < 3) /* ray direction */ |
185 |
186 |
return( ( fray->rdir[0]*funcxf.xfm[0][n] + |
187 |
fray->rdir[1]*funcxf.xfm[1][n] + |
188 |
fray->rdir[2]*funcxf.xfm[2][n] ) |
189 |
/ funcxf.sca ); |
190 |
191 |
if (n < 6) /* surface normal */ |
192 |
193 |
return( ( fray->ron[0]*funcxf.xfm[0][n-3] + |
194 |
fray->ron[1]*funcxf.xfm[1][n-3] + |
195 |
fray->ron[2]*funcxf.xfm[2][n-3] ) |
196 |
/ funcxf.sca ); |
197 |
198 |
if (n < 9) /* intersection */ |
199 |
200 |
return( fray->rop[0]*funcxf.xfm[0][n-6] + |
201 |
fray->rop[1]*funcxf.xfm[1][n-6] + |
202 |
fray->rop[2]*funcxf.xfm[2][n-6] + |
203 |
funcxf.xfm[3][n-6] ); |
204 |
205 |
if (n == 9) { /* distance */ |
206 |
207 |
sum = fray->rot; |
208 |
for (r = fray->parent; r != NULL; r = r->parent) |
209 |
sum += r->rot; |
210 |
return(sum * funcxf.sca); |
211 |
212 |
213 |
if (n == 10) /* dot product (range [-1,1]) */ |
214 |
return( fray->rod <= -1.0 ? -1.0 : |
215 |
fray->rod >= 1.0 ? 1.0 : |
216 |
fray->rod ); |
217 |
218 |
if (n == 11) /* scale */ |
219 |
return(funcxf.sca); |
220 |
221 |
if (n < 15) /* origin */ |
222 |
return(funcxf.xfm[3][n-12]); |
223 |
224 |
if (n < 18) /* i unit vector */ |
225 |
return(funcxf.xfm[0][n-15] / funcxf.sca); |
226 |
227 |
if (n < 21) /* j unit vector */ |
228 |
return(funcxf.xfm[1][n-15] / funcxf.sca); |
229 |
230 |
if (n < 24) /* k unit vector */ |
231 |
return(funcxf.xfm[2][n-21] / funcxf.sca); |
232 |
badchan: |
233 |
error(USER, "illegal channel number"); |
234 |
