root/radiance/ray/src/rt/func.c
Revision: 1.20
Committed: Wed Jul 17 10:09:24 1991 UTC (33 years, 10 months ago) by greg
changed position of initfile loading to catch conflicts
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * func.c - interface to calcomp functions.
9 *
10 * 4/7/86
11 */
12
13 #include "ray.h"
14
15 #include "otypes.h"
16
17
18 XF unitxf = { /* identity transform */
19 1.0, 0.0, 0.0, 0.0,
20 0.0, 1.0, 0.0, 0.0,
21 0.0, 0.0, 1.0, 0.0,
22 0.0, 0.0, 0.0, 1.0,
23 1.0
24 };
25
26 XF funcxf; /* current transformation */
27 static OBJREC *fobj = NULL; /* current function object */
28 static RAY *fray = NULL; /* current function ray */
29
30
31 setmap(m, r, bx) /* set channels for function call */
32 OBJREC *m;
33 register RAY *r;
34 XF *bx;
35 {
36 extern double l_arg(), l_erf(), l_erfc();
37 extern long eclock;
38 static char *initfile = "rayinit.cal";
39 static long lastrno = -1;
40 /* check to see if already set */
41 if (m == fobj && r->rno == lastrno)
42 return(0);
43 /* initialize if first call */
44 if (initfile != NULL) {
45 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
46 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
47 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
48 scompile("T=$10;Rdot=$11;", NULL, 0);
49 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
50 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
51 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
52 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
53 funset("arg", 1, '=', l_arg);
54 funset("erf", 1, ':', l_erf);
55 funset("erfc", 1, ':', l_erfc);
56 setnoisefuncs();
57 loadfunc(initfile);
58 initfile = NULL;
59 }
60 fobj = m;
61 fray = r;
62 if (r->rox != NULL)
63 if (bx != &unitxf) {
64 funcxf.sca = r->rox->b.sca * bx->sca;
65 multmat4(funcxf.xfm, r->rox->b.xfm, bx->xfm);
66 } else
67 copystruct(&funcxf, &r->rox->b);
68 else
69 copystruct(&funcxf, bx);
70 lastrno = r->rno;
71 eclock++; /* notify expression evaluator */
72 return(1);
73 }
74
75
76 setfunc(m, r) /* simplified interface to setmap */
77 register OBJREC *m;
78 RAY *r;
79 {
80 register XF *mxf;
81
82 if ((mxf = (XF *)m->os) == NULL) {
83 register int n;
84 register char **sa;
85
86 for (n = m->oargs.nsargs, sa = m->oargs.sarg;
87 n > 0 && **sa != '-'; n--, sa++)
88 ;
89 if (n == 0)
90 mxf = &unitxf;
91 else {
92 mxf = (XF *)malloc(sizeof(XF));
93 if (mxf == NULL)
94 goto memerr;
95 if (invxf(mxf, n, sa) != n)
96 objerror(m, USER, "bad transform");
97 if (mxf->sca < 0.0)
98 mxf->sca = -mxf->sca;
99 }
100 m->os = (char *)mxf;
101 }
102 return(setmap(m, r, mxf));
103 memerr:
104 error(SYSTEM, "out of memory in setfunc");
105 }
106
107
108 loadfunc(fname) /* load definition file */
109 char *fname;
110 {
111 extern char *libpath; /* library search path */
112 char *ffname;
113
114 if ((ffname = getpath(fname, libpath, R_OK)) == NULL) {
115 sprintf(errmsg, "cannot find function file \"%s\"", fname);
116 error(USER, errmsg);
117 }
118 fcompile(ffname);
119 }
120
121
122 double
123 l_arg() /* return nth real argument */
124 {
125 extern double argument();
126 register int n;
127
128 n = argument(1) + .5; /* round to integer */
129
130 if (n < 1)
131 return(fobj->oargs.nfargs);
132
133 if (n > fobj->oargs.nfargs) {
134 sprintf(errmsg, "missing real argument %d", n);
135 objerror(fobj, USER, errmsg);
136 }
137 return(fobj->oargs.farg[n-1]);
138 }
139
140
141 double
142 l_erf() /* error function */
143 {
144 extern double erf();
145
146 return(erf(argument(1)));
147 }
148
149
150 double
151 l_erfc() /* cumulative error function */
152 {
153 extern double erfc();
154
155 return(erfc(argument(1)));
156 }
157
158
159 double
160 chanvalue(n) /* return channel n to calcomp */
161 register int n;
162 {
163 double sum;
164 register RAY *r;
165
166 if (--n < 0)
167 goto badchan;
168
169 if (n < 3) /* ray direction */
170
171 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
172 fray->rdir[1]*funcxf.xfm[1][n] +
173 fray->rdir[2]*funcxf.xfm[2][n] )
174 / funcxf.sca );
175
176 if (n < 6) /* surface normal */
177
178 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
179 fray->ron[1]*funcxf.xfm[1][n-3] +
180 fray->ron[2]*funcxf.xfm[2][n-3] )
181 / funcxf.sca );
182
183 if (n < 9) /* intersection */
184
185 return( fray->rop[0]*funcxf.xfm[0][n-6] +
186 fray->rop[1]*funcxf.xfm[1][n-6] +
187 fray->rop[2]*funcxf.xfm[2][n-6] +
188 funcxf.xfm[3][n-6] );
189
190 if (n == 9) { /* distance */
191
192 sum = fray->rot;
193 for (r = fray->parent; r != NULL; r = r->parent)
194 sum += r->rot;
195 return(sum * funcxf.sca);
196
197 }
198 if (n == 10) /* dot product (range [-1,1]) */
199 return( fray->rod <= -1.0 ? -1.0 :
200 fray->rod >= 1.0 ? 1.0 :
201 fray->rod );
202
203 if (n == 11) /* scale */
204 return(funcxf.sca);
205
206 if (n < 15) /* origin */
207 return(funcxf.xfm[3][n-12]);
208
209 if (n < 18) /* i unit vector */
210 return(funcxf.xfm[0][n-15] / funcxf.sca);
211
212 if (n < 21) /* j unit vector */
213 return(funcxf.xfm[1][n-15] / funcxf.sca);
214
215 if (n < 24) /* k unit vector */
216 return(funcxf.xfm[2][n-21] / funcxf.sca);
217 badchan:
218 error(USER, "illegal channel number");
219 }
