root/radiance/ray/src/rt/func.c
Revision: 2.19
Committed: Mon Jul 21 22:30:19 2003 UTC (20 years, 10 months ago) by schorsch
2 static const char RCSid[] = "$Id: func.c,v 2.18 2003/05/13 17:58:33 greg Exp $";
5 * func.c - interface to calcomp functions.
6 */
7
8 #include "copyright.h"
9
10 #include "ray.h"
11
12 #include "otypes.h"
13
14 #include "func.h"
15
16
17 #define INITFILE "rayinit.cal"
18 #define CALSUF ".cal"
19 #define LCALSUF 4
20 char REFVNAME[] = "`FILE_REFCNT";
21
22 XF unitxf = { /* identity transform */
23 {{1.0, 0.0, 0.0, 0.0},
24 {0.0, 1.0, 0.0, 0.0},
25 {0.0, 0.0, 1.0, 0.0},
26 {0.0, 0.0, 0.0, 1.0}},
27 1.0
28 };
29
30 XF funcxf; /* current transformation */
31 static OBJREC *fobj = NULL; /* current function object */
32 static RAY *fray = NULL; /* current function ray */
33
34 static double l_erf(), l_erfc(), l_arg();
35
36
37 MFUNC *
38 getfunc(m, ff, ef, dofwd) /* get function for this modifier */
39 OBJREC *m;
40 int ff;
41 unsigned int ef;
42 int dofwd;
43 {
44 static char initfile[] = INITFILE;
45 char sbuf[MAXSTR];
46 register char **arg;
47 register MFUNC *f;
48 int ne, na;
49 register int i;
50 /* check to see if done already */
51 if ((f = (MFUNC *)m->os) != NULL)
52 return(f);
53 fobj = NULL; fray = NULL;
54 if (initfile[0]) { /* initialize on first call */
55 esupport |= E_VARIABLE|E_FUNCTION|E_INCHAN|E_RCONST|E_REDEFW;
56 esupport &= ~(E_OUTCHAN);
57 setcontext("");
58 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
59 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
60 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
61 scompile("T=$10;Ts=$25;Rdot=$11;", NULL, 0);
62 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
63 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
64 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
65 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
66 scompile("Lu=$26;Lv=$27;", NULL, 0);
67 funset("arg", 1, '=', l_arg);
68 funset("erf", 1, ':', l_erf);
69 funset("erfc", 1, ':', l_erfc);
70 setnoisefuncs();
71 setprismfuncs();
72 loadfunc(initfile);
73 initfile[0] = '\0';
74 }
75 if ((na = m->oargs.nsargs) <= ff)
76 goto toofew;
77 arg = m->oargs.sarg;
78 if ((f = (MFUNC *)calloc(1, sizeof(MFUNC))) == NULL)
79 goto memerr;
80 i = strlen(arg[ff]); /* set up context */
81 if (i == 1 && arg[ff][0] == '.')
82 setcontext(f->ctx = ""); /* "." means no file */
83 else {
84 strcpy(sbuf,arg[ff]); /* file name is context */
85 if (i > LCALSUF && !strcmp(sbuf+i-LCALSUF, CALSUF))
86 sbuf[i-LCALSUF] = '\0'; /* remove suffix */
87 setcontext(f->ctx = savestr(sbuf));
88 if (!vardefined(REFVNAME)) { /* file loaded? */
89 loadfunc(arg[ff]);
90 varset(REFVNAME, '=', 1.0);
91 } else /* reference_count++ */
92 varset(REFVNAME, '=', varvalue(REFVNAME)+1.0);
93 }
94 curfunc = NULL; /* parse expressions */
95 sprintf(sbuf, "%s \"%s\"", ofun[m->otype].funame, m->oname);
96 for (i=0, ne=0; ef && i < na; i++, ef>>=1)
97 if (ef & 1) { /* flagged as an expression? */
98 if (ne >= MAXEXPR)
99 objerror(m, INTERNAL, "too many expressions");
100 initstr(arg[i], sbuf, 0);
101 f->ep[ne++] = getE1();
102 if (nextc != EOF)
103 syntax("unexpected character");
104 }
105 if (ef)
106 goto toofew;
107 if (i <= ff) /* find transform args */
108 i = ff+1;
109 while (i < na && arg[i][0] != '-')
110 i++;
111 if (i == na) /* no transform */
112 f->f = f->b = &unitxf;
113 else { /* get transform */
114 if ((f->b = (XF *)malloc(sizeof(XF))) == NULL)
115 goto memerr;
116 if (invxf(f->b, na-i, arg+i) != na-i)
117 objerror(m, USER, "bad transform");
118 if (f->b->sca < 0.0)
119 f->b->sca = -f->b->sca;
120 if (dofwd) { /* do both transforms */
121 if ((f->f = (XF *)malloc(sizeof(XF))) == NULL)
122 goto memerr;
123 xf(f->f, na-i, arg+i);
124 if (f->f->sca < 0.0)
125 f->f->sca = -f->f->sca;
126 }
127 }
128 m->os = (char *)f;
129 return(f);
130 toofew:
131 objerror(m, USER, "too few string arguments");
132 memerr:
133 error(SYSTEM, "out of memory in getfunc");
134 }
135
136
137 void
138 freefunc(m) /* free memory associated with modifier */
139 OBJREC *m;
140 {
141 register MFUNC *f;
142 register int i;
143
144 if ((f = (MFUNC *)m->os) == NULL)
145 return;
146 for (i = 0; f->ep[i] != NULL; i++)
147 epfree(f->ep[i]);
148 if (f->ctx[0]) { /* done with definitions */
149 setcontext(f->ctx);
150 i = varvalue(REFVNAME)-.5; /* reference_count-- */
151 if (i > 0)
152 varset(REFVNAME, '=', (double)i);
153 else
154 dcleanup(2); /* remove definitions */
155 freestr(f->ctx);
156 }
157 if (f->b != &unitxf)
158 free((void *)f->b);
159 if (f->f != NULL && f->f != &unitxf)
160 free((void *)f->f);
161 free((void *)f);
162 m->os = NULL;
163 }
164
165
166 int
167 setfunc(m, r) /* set channels for function call */
168 OBJREC *m;
169 register RAY *r;
170 {
171 static unsigned long lastrno = ~0;
172 register MFUNC *f;
173 /* get function */
174 if ((f = (MFUNC *)m->os) == NULL)
175 objerror(m, CONSISTENCY, "setfunc called before getfunc");
176 /* set evaluator context */
177 setcontext(f->ctx);
178 /* check to see if matrix set */
179 if (m == fobj && r->rno == lastrno)
180 return(0);
181 fobj = m;
182 fray = r;
183 if (r->rox != NULL)
184 if (f->b != &unitxf) {
185 funcxf.sca = r->rox->b.sca * f->b->sca;
186 multmat4(funcxf.xfm, r->rox->b.xfm, f->b->xfm);
187 } else
188 funcxf = r->rox->b;
189 else
190 funcxf = *(f->b);
191 lastrno = r->rno;
192 eclock++; /* notify expression evaluator */
193 return(1);
194 }
195
196
197 void
198 loadfunc(fname) /* load definition file */
199 char *fname;
200 {
201 char *ffname;
202
203 if ((ffname = getpath(fname, getrlibpath(), R_OK)) == NULL) {
204 sprintf(errmsg, "cannot find function file \"%s\"", fname);
205 error(USER, errmsg);
206 }
207 fcompile(ffname);
208 }
209
210
211 static double
212 l_arg() /* return nth real argument */
213 {
214 register int n;
215
216 if (fobj == NULL)
217 syntax("arg(n) used in constant expression");
218
219 n = argument(1) + .5; /* round to integer */
220
221 if (n < 1)
222 return(fobj->oargs.nfargs);
223
224 if (n > fobj->oargs.nfargs) {
225 sprintf(errmsg, "missing real argument %d", n);
226 objerror(fobj, USER, errmsg);
227 }
228 return(fobj->oargs.farg[n-1]);
229 }
230
231
232 static double
233 l_erf() /* error function */
234 {
235 extern double erf();
236
237 return(erf(argument(1)));
238 }
239
240
241 static double
242 l_erfc() /* cumulative error function */
243 {
244 extern double erfc();
245
246 return(erfc(argument(1)));
247 }
248
249
250 double
251 chanvalue(n) /* return channel n to calcomp */
252 register int n;
253 {
254 if (fray == NULL)
255 syntax("ray parameter used in constant expression");
256
257 if (--n < 0)
258 goto badchan;
259
260 if (n <= 2) /* ray direction */
261
262 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
263 fray->rdir[1]*funcxf.xfm[1][n] +
264 fray->rdir[2]*funcxf.xfm[2][n] )
265 / funcxf.sca );
266
267 if (n <= 5) /* surface normal */
268
269 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
270 fray->ron[1]*funcxf.xfm[1][n-3] +
271 fray->ron[2]*funcxf.xfm[2][n-3] )
272 / funcxf.sca );
273
274 if (n <= 8) /* intersection */
275
276 return( fray->rop[0]*funcxf.xfm[0][n-6] +
277 fray->rop[1]*funcxf.xfm[1][n-6] +
278 fray->rop[2]*funcxf.xfm[2][n-6] +
279 funcxf.xfm[3][n-6] );
280
281 if (n == 9) /* total distance */
282 return(raydist(fray,PRIMARY) * funcxf.sca);
283
284 if (n == 10) /* dot product (range [-1,1]) */
285 return( fray->rod <= -1.0 ? -1.0 :
286 fray->rod >= 1.0 ? 1.0 :
287 fray->rod );
288
289 if (n == 11) /* scale */
290 return(funcxf.sca);
291
292 if (n <= 14) /* origin */
293 return(funcxf.xfm[3][n-12]);
294
295 if (n <= 17) /* i unit vector */
296 return(funcxf.xfm[0][n-15] / funcxf.sca);
297
298 if (n <= 20) /* j unit vector */
299 return(funcxf.xfm[1][n-18] / funcxf.sca);
300
301 if (n <= 23) /* k unit vector */
302 return(funcxf.xfm[2][n-21] / funcxf.sca);
303
304 if (n == 24) /* single ray (shadow) distance */
305 return((fray->rot+raydist(fray->parent,SHADOW)) * funcxf.sca);
306
307 if (n <= 26) /* local (u,v) coordinates */
308 return(fray->uv[n-25]);
309 badchan:
310 error(USER, "illegal channel number");
311 return(0.0);
312 }
