--- ray/src/rt/func.c 2004/03/30 16:13:01 2.22 +++ ray/src/rt/func.c 2012/06/07 18:56:06 2.25 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: func.c,v 2.22 2004/03/30 16:13:01 schorsch Exp $"; +static const char RCSid[] = "$Id: func.c,v 2.25 2012/06/07 18:56:06 greg Exp $"; #endif /* * func.c - interface to calcomp functions. @@ -7,8 +7,6 @@ static const char RCSid[] = "$Id: func.c,v 2.22 2004/0 #include "copyright.h" -#include - #include "ray.h" #include "paths.h" #include "otypes.h" @@ -35,7 +33,7 @@ static RAY *fray = NULL; /* current function ray */ static double l_erf(char *), l_erfc(char *), l_arg(char *); -extern MFUNC * +MFUNC * getfunc( /* get function for this modifier */ OBJREC *m, int ff, @@ -45,10 +43,10 @@ getfunc( /* get function for this modifier */ { static char initfile[] = INITFILE; char sbuf[MAXSTR]; - register char **arg; - register MFUNC *f; + char **arg; + MFUNC *f; int ne, na; - register int i; + int i; /* check to see if done already */ if ((f = (MFUNC *)m->os) != NULL) return(f); @@ -137,13 +135,13 @@ memerr: } -extern void +void freefunc( /* free memory associated with modifier */ OBJREC *m ) { - register MFUNC *f; - register int i; + MFUNC *f; + int i; if ((f = (MFUNC *)m->os) == NULL) return; @@ -160,28 +158,30 @@ freefunc( /* free memory associated with modifier */ } if (f->b != &unitxf) free((void *)f->b); - if (f->f != NULL && f->f != &unitxf) + if ((f->f != NULL) & (f->f != &unitxf)) free((void *)f->f); free((void *)f); m->os = NULL; } -extern int +int setfunc( /* set channels for function call */ - OBJREC *m, - register RAY *r + OBJREC *m, /* can be NULL */ + RAY *r ) { - static unsigned long lastrno = ~0; - register MFUNC *f; - /* get function */ - if ((f = (MFUNC *)m->os) == NULL) - objerror(m, CONSISTENCY, "setfunc called before getfunc"); - /* set evaluator context */ - setcontext(f->ctx); + static RNUMBER lastrno = ~0; + MFUNC *f; + /* get function if any */ + if (m != NULL) { + if ((f = (MFUNC *)m->os) == NULL) + objerror(m, CONSISTENCY, "setfunc called before getfunc"); + setcontext(f->ctx); /* set evaluator context */ + } else + setcontext(""); /* check to see if matrix set */ - if (m == fobj && r->rno == lastrno) + if ((m == fobj) & (r->rno == lastrno)) return(0); fobj = m; fray = r; @@ -199,7 +199,7 @@ setfunc( /* set channels for function call */ } -extern void +void loadfunc( /* load definition file */ char *fname ) @@ -217,10 +217,10 @@ loadfunc( /* load definition file */ static double l_arg(char *nm) /* return nth real argument */ { - register int n; + int n; if (fobj == NULL) - syntax("arg(n) used in constant expression"); + error(USER, "arg(n) called without a context"); n = argument(1) + .5; /* round to integer */ @@ -249,9 +249,9 @@ l_erfc(char *nm) /* cumulative error function */ } -extern double +double chanvalue( /* return channel n to calcomp */ - register int n + int n ) { if (fray == NULL)
