--- ray/src/rt/func.c 1990/07/19 11:17:12 1.9 +++ ray/src/rt/func.c 1990/12/15 15:03:26 1.12 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1990 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -15,27 +15,25 @@ static char SCCSid[] = "$SunId$ LBL"; #include "otypes.h" -typedef struct { - double xfm[4][4]; /* transform matrix */ - double sca; /* scalefactor */ -} XF; +XF funcxf; /* current transformation */ +static OBJREC *fobj = NULL; /* current function object */ +static RAY *fray = NULL; /* current function ray */ -static OBJREC *fobj; /* current function object */ -static RAY *fray; /* current function ray */ -static XF fxf; /* current transformation */ - -setmap(m, r, xfm, sca) /* set channels for function call */ +setmap(m, r, bx) /* set channels for function call */ OBJREC *m; register RAY *r; -double xfm[4][4]; -double sca; +XF *bx; { extern double l_noise3(), l_noise3a(), l_noise3b(), l_noise3c(); extern double l_hermite(), l_fnoise3(), l_arg(); extern long eclock; static char *initfile = "rayinit.cal"; - + static long lastrno = -1; + /* check to see if already set */ + if (m == fobj && r->rno == lastrno) + return; + /* initialize if first call */ if (initfile != NULL) { loadfunc(initfile); scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0); @@ -57,8 +55,12 @@ double sca; } fobj = m; fray = r; - fxf.sca = r->robs * sca; - multmat4(fxf.xfm, r->robx, xfm); + lastrno = r->rno; + if (r->rox != NULL) { + funcxf.sca = r->rox->b.sca * bx->sca; + multmat4(funcxf.xfm, r->rox->b.xfm, bx->xfm); + } else + copystruct(&funcxf, bx); eclock++; /* notify expression evaluator */ } @@ -79,17 +81,16 @@ RAY *r; mxf = (XF *)malloc(sizeof(XF)); if (mxf == NULL) goto memerr; - if (invxf(mxf->xfm, &mxf->sca, n, sa) != n) + if (invxf(mxf, n, sa) != n) objerror(m, USER, "bad transform"); if (mxf->sca < 0.0) mxf->sca = -mxf->sca; m->os = (char *)mxf; } - setmap(m, r, mxf->xfm, mxf->sca); + setmap(m, r, mxf); return; memerr: error(SYSTEM, "out of memory in setfunc"); -#undef mxf } @@ -133,55 +134,55 @@ register int n; double sum; register RAY *r; - n--; /* for convenience */ + if (--n < 0) + goto badchan; - if (n < 0 || n > 23) - error(USER, "illegal channel number"); + if (n < 3) /* ray direction */ + return( ( fray->rdir[0]*funcxf.xfm[0][n] + + fray->rdir[1]*funcxf.xfm[1][n] + + fray->rdir[2]*funcxf.xfm[2][n] ) + / funcxf.sca ); + + if (n < 6) /* surface normal */ + + return( ( fray->ron[0]*funcxf.xfm[0][n-3] + + fray->ron[1]*funcxf.xfm[1][n-3] + + fray->ron[2]*funcxf.xfm[2][n-3] ) + / funcxf.sca ); + + if (n < 9) /* intersection */ + + return( fray->rop[0]*funcxf.xfm[0][n-6] + + fray->rop[1]*funcxf.xfm[1][n-6] + + fray->rop[2]*funcxf.xfm[2][n-6] + + funcxf.xfm[3][n-6] ); + if (n == 9) { /* distance */ sum = fray->rot; for (r = fray->parent; r != NULL; r = r->parent) sum += r->rot; - return(sum * fxf.sca); + return(sum * funcxf.sca); } if (n == 10) /* dot product */ return(fray->rod); - if (n < 3) /* ray direction */ - - return( ( fray->rdir[0]*fxf.xfm[0][n] + - fray->rdir[1]*fxf.xfm[1][n] + - fray->rdir[2]*fxf.xfm[2][n] ) - / fxf.sca ); - - if (n < 6) /* surface normal */ - - return( ( fray->ron[0]*fxf.xfm[0][n-3] + - fray->ron[1]*fxf.xfm[1][n-3] + - fray->ron[2]*fxf.xfm[2][n-3] ) - / fxf.sca ); - - if (n < 9) /* intersection */ - - return( fray->rop[0]*fxf.xfm[0][n-6] + - fray->rop[1]*fxf.xfm[1][n-6] + - fray->rop[2]*fxf.xfm[2][n-6] + - fxf.xfm[3][n-6] ); - if (n == 11) /* scale */ - return(fxf.sca); + return(funcxf.sca); if (n < 15) /* origin */ - return(fxf.xfm[3][n-12]); + return(funcxf.xfm[3][n-12]); if (n < 18) /* i unit vector */ - return(fxf.xfm[0][n-15] / fxf.sca); + return(funcxf.xfm[0][n-15] / funcxf.sca); if (n < 21) /* j unit vector */ - return(fxf.xfm[1][n-15] / fxf.sca); + return(funcxf.xfm[1][n-15] / funcxf.sca); if (n < 24) /* k unit vector */ - return(fxf.xfm[2][n-21] / fxf.sca); + return(funcxf.xfm[2][n-21] / funcxf.sca); +badchan: + error(USER, "illegal channel number"); }
