--- ray/src/rt/func.c 1990/12/15 15:03:26 1.12 +++ ray/src/rt/func.c 1991/08/08 15:41:14 1.22 @@ -1,4 +1,4 @@ -/* Copyright (c) 1990 Regents of the University of California */ +/* Copyright (c) 1991 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -15,6 +15,17 @@ static char SCCSid[] = "$SunId$ LBL"; #include "otypes.h" +#define INITFILE "rayinit.cal" +#define DEFVNAME "FILE_LOADED`" + +XF unitxf = { /* identity transform */ + 1.0, 0.0, 0.0, 0.0, + 0.0, 1.0, 0.0, 0.0, + 0.0, 0.0, 1.0, 0.0, + 0.0, 0.0, 0.0, 1.0, + 1.0 +}; + XF funcxf; /* current transformation */ static OBJREC *fobj = NULL; /* current function object */ static RAY *fray = NULL; /* current function ray */ @@ -25,43 +36,24 @@ OBJREC *m; register RAY *r; XF *bx; { - extern double l_noise3(), l_noise3a(), l_noise3b(), l_noise3c(); - extern double l_hermite(), l_fnoise3(), l_arg(); extern long eclock; - static char *initfile = "rayinit.cal"; static long lastrno = -1; /* check to see if already set */ if (m == fobj && r->rno == lastrno) - return; - /* initialize if first call */ - if (initfile != NULL) { - loadfunc(initfile); - scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0); - scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0); - scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0); - scompile("T=$10;Rdot=$11;", NULL, 0); - scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0); - scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0); - scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0); - scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0); - funset("arg", 1, l_arg); - funset("noise3", 3, l_noise3); - funset("noise3a", 3, l_noise3a); - funset("noise3b", 3, l_noise3b); - funset("noise3c", 3, l_noise3c); - funset("hermite", 5, l_hermite); - funset("fnoise3", 3, l_fnoise3); - initfile = NULL; - } + return(0); fobj = m; fray = r; - lastrno = r->rno; - if (r->rox != NULL) { - funcxf.sca = r->rox->b.sca * bx->sca; - multmat4(funcxf.xfm, r->rox->b.xfm, bx->xfm); - } else + if (r->rox != NULL) + if (bx != &unitxf) { + funcxf.sca = r->rox->b.sca * bx->sca; + multmat4(funcxf.xfm, r->rox->b.xfm, bx->xfm); + } else + copystruct(&funcxf, &r->rox->b); + else copystruct(&funcxf, bx); + lastrno = r->rno; eclock++; /* notify expression evaluator */ + return(1); } @@ -78,17 +70,20 @@ RAY *r; for (n = m->oargs.nsargs, sa = m->oargs.sarg; n > 0 && **sa != '-'; n--, sa++) ; - mxf = (XF *)malloc(sizeof(XF)); - if (mxf == NULL) - goto memerr; - if (invxf(mxf, n, sa) != n) - objerror(m, USER, "bad transform"); - if (mxf->sca < 0.0) - mxf->sca = -mxf->sca; + if (n == 0) + mxf = &unitxf; + else { + mxf = (XF *)malloc(sizeof(XF)); + if (mxf == NULL) + goto memerr; + if (invxf(mxf, n, sa) != n) + objerror(m, USER, "bad transform"); + if (mxf->sca < 0.0) + mxf->sca = -mxf->sca; + } m->os = (char *)mxf; } - setmap(m, r, mxf); - return; + return(setmap(m, r, mxf)); memerr: error(SYSTEM, "out of memory in setfunc"); } @@ -128,6 +123,59 @@ l_arg() /* return nth real argument */ double +l_erf() /* error function */ +{ + extern double erf(); + + return(erf(argument(1))); +} + + +double +l_erfc() /* cumulative error function */ +{ + extern double erfc(); + + return(erfc(argument(1))); +} + + +funcfile(fname) /* set context, load file if necessary */ +register char *fname; +{ + extern char *setcontext(); + static char initfile[] = INITFILE; + + if (initfile[0]) { /* initialize on first call */ + setcontext(""); + scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0); + scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0); + scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0); + scompile("T=$10;Rdot=$11;", NULL, 0); + scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0); + scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0); + scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0); + scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0); + funset("arg", 1, '=', l_arg); + funset("erf", 1, ':', l_erf); + funset("erfc", 1, ':', l_erfc); + setnoisefuncs(); + loadfunc(initfile); + initfile[0] = '\0'; + } + if (fname[0] == '.' && fname[1] == '\0') + setcontext(""); /* "." means no file */ + else { + setcontext(fname); + if (!vardefined(DEFVNAME)) { + loadfunc(fname); + varset(DEFVNAME, ':', 1.0); + } + } +} + + +double chanvalue(n) /* return channel n to calcomp */ register int n; { @@ -166,8 +214,10 @@ register int n; return(sum * funcxf.sca); } - if (n == 10) /* dot product */ - return(fray->rod); + if (n == 10) /* dot product (range [-1,1]) */ + return( fray->rod <= -1.0 ? -1.0 : + fray->rod >= 1.0 ? 1.0 : + fray->rod ); if (n == 11) /* scale */ return(funcxf.sca);
