--- ray/src/rt/func.c 1991/04/23 15:46:22 1.14 +++ ray/src/rt/func.c 1991/08/08 13:08:01 1.21 @@ -15,6 +15,9 @@ static char SCCSid[] = "$SunId$ LBL"; #include "otypes.h" +#define INITFILE "rayinit.cal" +#define DEFVNAME "FILE_LOADED`" + XF unitxf = { /* identity transform */ 1.0, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, 0.0, @@ -33,30 +36,11 @@ OBJREC *m; register RAY *r; XF *bx; { - extern double l_noise3(), l_noise3a(), l_noise3b(), l_noise3c(); - extern double l_hermite(), l_fnoise3(), l_arg(); extern long eclock; - static char *initfile = "rayinit.cal"; - /* initialize if first call */ - if (initfile != NULL) { - loadfunc(initfile); - scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0); - scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0); - scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0); - scompile("T=$10;Rdot=$11;", NULL, 0); - scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0); - scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0); - scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0); - scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0); - funset("arg", 1, '=', l_arg); - funset("noise3", 3, ':', l_noise3); - funset("noise3a", 3, ':', l_noise3a); - funset("noise3b", 3, ':', l_noise3b); - funset("noise3c", 3, ':', l_noise3c); - funset("hermite", 5, ':', l_hermite); - funset("fnoise3", 3, ':', l_fnoise3); - initfile = NULL; - } + static long lastrno = -1; + /* check to see if already set */ + if (m == fobj && r->rno == lastrno) + return(0); fobj = m; fray = r; if (r->rox != NULL) @@ -67,7 +51,9 @@ XF *bx; copystruct(&funcxf, &r->rox->b); else copystruct(&funcxf, bx); + lastrno = r->rno; eclock++; /* notify expression evaluator */ + return(1); } @@ -97,8 +83,7 @@ RAY *r; } m->os = (char *)mxf; } - setmap(m, r, mxf); - return; + return(setmap(m, r, mxf)); memerr: error(SYSTEM, "out of memory in setfunc"); } @@ -138,6 +123,55 @@ l_arg() /* return nth real argument */ double +l_erf() /* error function */ +{ + extern double erf(); + + return(erf(argument(1))); +} + + +double +l_erfc() /* cumulative error function */ +{ + extern double erfc(); + + return(erfc(argument(1))); +} + + +funcfile(fname) /* set context, load file if necessary */ +char *fname; +{ + extern char *setcontext(); + static char initfile[] = INITFILE; + + if (initfile[0]) { /* initialize on first call */ + setcontext(""); + scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0); + scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0); + scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0); + scompile("T=$10;Rdot=$11;", NULL, 0); + scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0); + scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0); + scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0); + scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0); + funset("arg", 1, '=', l_arg); + funset("erf", 1, ':', l_erf); + funset("erfc", 1, ':', l_erfc); + setnoisefuncs(); + loadfunc(initfile); + initfile[0] = '\0'; + } + setcontext(fname); + if (!vardefined(DEFVNAME)) { + loadfunc(fname); + varset(DEFVNAME, ':', 1.0); + } +} + + +double chanvalue(n) /* return channel n to calcomp */ register int n; { @@ -176,8 +210,10 @@ register int n; return(sum * funcxf.sca); } - if (n == 10) /* dot product */ - return(fray->rod); + if (n == 10) /* dot product (range [-1,1]) */ + return( fray->rod <= -1.0 ? -1.0 : + fray->rod >= 1.0 ? 1.0 : + fray->rod ); if (n == 11) /* scale */ return(funcxf.sca);
