root/radiance/ray/src/rt/func.c
Revision: 1.15
Committed: Fri May 24 13:52:10 1991 UTC (33 years, 1 month ago) by greg
Changes since 1.14: +2 -8 lines
changed initialization for noise functions
1 /* Copyright (c) 1991 Regents of the University of California */
2
3 #ifndef lint
5 #endif
6
7 /*
8 * func.c - interface to calcomp functions.
9 *
10 * 4/7/86
11 */
12
13 #include "ray.h"
14
15 #include "otypes.h"
16
17
18 XF unitxf = { /* identity transform */
19 1.0, 0.0, 0.0, 0.0,
20 0.0, 1.0, 0.0, 0.0,
21 0.0, 0.0, 1.0, 0.0,
22 0.0, 0.0, 0.0, 1.0,
23 1.0
24 };
25
26 XF funcxf; /* current transformation */
27 static OBJREC *fobj = NULL; /* current function object */
28 static RAY *fray = NULL; /* current function ray */
29
30
31 setmap(m, r, bx) /* set channels for function call */
32 OBJREC *m;
33 register RAY *r;
34 XF *bx;
35 {
36 extern double l_arg();
37 extern long eclock;
38 static char *initfile = "rayinit.cal";
39 /* initialize if first call */
40 if (initfile != NULL) {
41 loadfunc(initfile);
42 scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0);
43 scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0);
44 scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0);
45 scompile("T=$10;Rdot=$11;", NULL, 0);
46 scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0);
47 scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0);
48 scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0);
49 scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0);
50 funset("arg", 1, '=', l_arg);
51 setnoisefuncs();
52 initfile = NULL;
53 }
54 fobj = m;
55 fray = r;
56 if (r->rox != NULL)
57 if (bx != &unitxf) {
58 funcxf.sca = r->rox->b.sca * bx->sca;
59 multmat4(funcxf.xfm, r->rox->b.xfm, bx->xfm);
60 } else
61 copystruct(&funcxf, &r->rox->b);
62 else
63 copystruct(&funcxf, bx);
64 eclock++; /* notify expression evaluator */
65 }
66
67
68 setfunc(m, r) /* simplified interface to setmap */
69 register OBJREC *m;
70 RAY *r;
71 {
72 register XF *mxf;
73
74 if ((mxf = (XF *)m->os) == NULL) {
75 register int n;
76 register char **sa;
77
78 for (n = m->oargs.nsargs, sa = m->oargs.sarg;
79 n > 0 && **sa != '-'; n--, sa++)
80 ;
81 if (n == 0)
82 mxf = &unitxf;
83 else {
84 mxf = (XF *)malloc(sizeof(XF));
85 if (mxf == NULL)
86 goto memerr;
87 if (invxf(mxf, n, sa) != n)
88 objerror(m, USER, "bad transform");
89 if (mxf->sca < 0.0)
90 mxf->sca = -mxf->sca;
91 }
92 m->os = (char *)mxf;
93 }
94 setmap(m, r, mxf);
95 return;
96 memerr:
97 error(SYSTEM, "out of memory in setfunc");
98 }
99
100
101 loadfunc(fname) /* load definition file */
102 char *fname;
103 {
104 extern char *libpath; /* library search path */
105 char *ffname;
106
107 if ((ffname = getpath(fname, libpath, R_OK)) == NULL) {
108 sprintf(errmsg, "cannot find function file \"%s\"", fname);
109 error(USER, errmsg);
110 }
111 fcompile(ffname);
112 }
113
114
115 double
116 l_arg() /* return nth real argument */
117 {
118 extern double argument();
119 register int n;
120
121 n = argument(1) + .5; /* round to integer */
122
123 if (n < 1)
124 return(fobj->oargs.nfargs);
125
126 if (n > fobj->oargs.nfargs) {
127 sprintf(errmsg, "missing real argument %d", n);
128 objerror(fobj, USER, errmsg);
129 }
130 return(fobj->oargs.farg[n-1]);
131 }
132
133
134 double
135 chanvalue(n) /* return channel n to calcomp */
136 register int n;
137 {
138 double sum;
139 register RAY *r;
140
141 if (--n < 0)
142 goto badchan;
143
144 if (n < 3) /* ray direction */
145
146 return( ( fray->rdir[0]*funcxf.xfm[0][n] +
147 fray->rdir[1]*funcxf.xfm[1][n] +
148 fray->rdir[2]*funcxf.xfm[2][n] )
149 / funcxf.sca );
150
151 if (n < 6) /* surface normal */
152
153 return( ( fray->ron[0]*funcxf.xfm[0][n-3] +
154 fray->ron[1]*funcxf.xfm[1][n-3] +
155 fray->ron[2]*funcxf.xfm[2][n-3] )
156 / funcxf.sca );
157
158 if (n < 9) /* intersection */
159
160 return( fray->rop[0]*funcxf.xfm[0][n-6] +
161 fray->rop[1]*funcxf.xfm[1][n-6] +
162 fray->rop[2]*funcxf.xfm[2][n-6] +
163 funcxf.xfm[3][n-6] );
164
165 if (n == 9) { /* distance */
166
167 sum = fray->rot;
168 for (r = fray->parent; r != NULL; r = r->parent)
169 sum += r->rot;
170 return(sum * funcxf.sca);
171
172 }
173 if (n == 10) /* dot product */
174 return(fray->rod);
175
176 if (n == 11) /* scale */
177 return(funcxf.sca);
178
179 if (n < 15) /* origin */
180 return(funcxf.xfm[3][n-12]);
181
182 if (n < 18) /* i unit vector */
183 return(funcxf.xfm[0][n-15] / funcxf.sca);
184
185 if (n < 21) /* j unit vector */
186 return(funcxf.xfm[1][n-15] / funcxf.sca);
187
188 if (n < 24) /* k unit vector */
189 return(funcxf.xfm[2][n-21] / funcxf.sca);
190 badchan:
191 error(USER, "illegal channel number");
192 }
