--- ray/src/rt/func.c 2003/08/04 22:37:53 2.20 +++ ray/src/rt/func.c 2004/03/30 16:13:01 2.22 @@ -1,5 +1,5 @@ #ifndef lint -static const char RCSid[] = "$Id: func.c,v 2.20 2003/08/04 22:37:53 greg Exp $"; +static const char RCSid[] = "$Id: func.c,v 2.22 2004/03/30 16:13:01 schorsch Exp $"; #endif /* * func.c - interface to calcomp functions. @@ -7,10 +7,11 @@ static const char RCSid[] = "$Id: func.c,v 2.20 2003/0 #include "copyright.h" -#include "ray.h" +#include +#include "ray.h" +#include "paths.h" #include "otypes.h" - #include "func.h" @@ -34,12 +35,13 @@ static RAY *fray = NULL; /* current function ray */ static double l_erf(char *), l_erfc(char *), l_arg(char *); -MFUNC * -getfunc(m, ff, ef, dofwd) /* get function for this modifier */ -OBJREC *m; -int ff; -unsigned int ef; -int dofwd; +extern MFUNC * +getfunc( /* get function for this modifier */ + OBJREC *m, + int ff, + unsigned int ef, + int dofwd +) { static char initfile[] = INITFILE; char sbuf[MAXSTR]; @@ -131,12 +133,14 @@ toofew: objerror(m, USER, "too few string arguments"); memerr: error(SYSTEM, "out of memory in getfunc"); + return NULL; /* pro forma return */ } -void -freefunc(m) /* free memory associated with modifier */ -OBJREC *m; +extern void +freefunc( /* free memory associated with modifier */ + OBJREC *m +) { register MFUNC *f; register int i; @@ -163,10 +167,11 @@ OBJREC *m; } -int -setfunc(m, r) /* set channels for function call */ -OBJREC *m; -register RAY *r; +extern int +setfunc( /* set channels for function call */ + OBJREC *m, + register RAY *r +) { static unsigned long lastrno = ~0; register MFUNC *f; @@ -194,9 +199,10 @@ register RAY *r; } -void -loadfunc(fname) /* load definition file */ -char *fname; +extern void +loadfunc( /* load definition file */ + char *fname +) { char *ffname; @@ -232,8 +238,6 @@ l_arg(char *nm) /* return nth real argument */ static double l_erf(char *nm) /* error function */ { - extern double erf(); - return(erf(argument(1))); } @@ -241,15 +245,14 @@ l_erf(char *nm) /* error function */ static double l_erfc(char *nm) /* cumulative error function */ { - extern double erfc(); - return(erfc(argument(1))); } -double -chanvalue(n) /* return channel n to calcomp */ -register int n; +extern double +chanvalue( /* return channel n to calcomp */ + register int n +) { if (fray == NULL) syntax("ray parameter used in constant expression");
