--- ray/src/rt/func.c 1989/04/11 13:30:29 1.4 +++ ray/src/rt/func.c 1990/07/19 11:17:12 1.9 @@ -38,10 +38,14 @@ double sca; if (initfile != NULL) { loadfunc(initfile); - scompile(NULL, "Dx=$1;Dy=$2;Dz=$3;"); - scompile(NULL, "Nx=$4;Ny=$5;Nz=$6;"); - scompile(NULL, "Px=$7;Py=$8;Pz=$9;"); - scompile(NULL, "T=$10;Rdot=$11;"); + scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0); + scompile("Nx=$4;Ny=$5;Nz=$6;", NULL, 0); + scompile("Px=$7;Py=$8;Pz=$9;", NULL, 0); + scompile("T=$10;Rdot=$11;", NULL, 0); + scompile("S=$12;Tx=$13;Ty=$14;Tz=$15;", NULL, 0); + scompile("Ix=$16;Iy=$17;Iz=$18;", NULL, 0); + scompile("Jx=$19;Jy=$20;Jz=$21;", NULL, 0); + scompile("Kx=$22;Ky=$23;Kz=$24;", NULL, 0); funset("arg", 1, l_arg); funset("noise3", 3, l_noise3); funset("noise3a", 3, l_noise3a); @@ -66,18 +70,15 @@ RAY *r; register XF *mxf; if ((mxf = (XF *)m->os) == NULL) { - register int n = m->oargs.nsargs; - register char **sa = m->oargs.sarg; + register int n; + register char **sa; - while (n > 0 && **sa != '-') { - n--; - sa++; - } + for (n = m->oargs.nsargs, sa = m->oargs.sarg; + n > 0 && **sa != '-'; n--, sa++) + ; mxf = (XF *)malloc(sizeof(XF)); if (mxf == NULL) goto memerr; - mxf->sca = 1.0; - setident4(mxf->xfm); if (invxf(mxf->xfm, &mxf->sca, n, sa) != n) objerror(m, USER, "bad transform"); if (mxf->sca < 0.0) @@ -98,7 +99,7 @@ char *fname; extern char *libpath; /* library search path */ char *ffname; - if ((ffname = getpath(fname, libpath)) == NULL) { + if ((ffname = getpath(fname, libpath, R_OK)) == NULL) { sprintf(errmsg, "cannot find function file \"%s\"", fname); error(USER, errmsg); } @@ -129,41 +130,58 @@ double chanvalue(n) /* return channel n to calcomp */ register int n; { - double res; + double sum; register RAY *r; - n--; /* for convenience */ + n--; /* for convenience */ - if (n < 0 || n > 10) + if (n < 0 || n > 23) error(USER, "illegal channel number"); - if (n == 9) { /* distance */ + if (n == 9) { /* distance */ - res = fray->rot; + sum = fray->rot; for (r = fray->parent; r != NULL; r = r->parent) - res += r->rot; - res *= fxf.sca; + sum += r->rot; + return(sum * fxf.sca); - } else if (n == 10) { /* dot product */ + } + if (n == 10) /* dot product */ + return(fray->rod); - res = fray->rod; + if (n < 3) /* ray direction */ - } else if (n < 3) { /* ray direction */ - res = ( fray->rdir[0]*fxf.xfm[0][n] + - fray->rdir[1]*fxf.xfm[1][n] + - fray->rdir[2]*fxf.xfm[2][n] ) - / fxf.sca ; - } else if (n < 6) { /* surface normal */ - res = ( fray->ron[0]*fxf.xfm[0][n-3] + - fray->ron[1]*fxf.xfm[1][n-3] + - fray->ron[2]*fxf.xfm[2][n-3] ) - / fxf.sca ; - } else { /* intersection */ - res = fray->rop[0]*fxf.xfm[0][n-6] + - fray->rop[1]*fxf.xfm[1][n-6] + - fray->rop[2]*fxf.xfm[2][n-6] + - fxf.xfm[3][n-6] ; - } + return( ( fray->rdir[0]*fxf.xfm[0][n] + + fray->rdir[1]*fxf.xfm[1][n] + + fray->rdir[2]*fxf.xfm[2][n] ) + / fxf.sca ); - return(res); + if (n < 6) /* surface normal */ + + return( ( fray->ron[0]*fxf.xfm[0][n-3] + + fray->ron[1]*fxf.xfm[1][n-3] + + fray->ron[2]*fxf.xfm[2][n-3] ) + / fxf.sca ); + + if (n < 9) /* intersection */ + + return( fray->rop[0]*fxf.xfm[0][n-6] + + fray->rop[1]*fxf.xfm[1][n-6] + + fray->rop[2]*fxf.xfm[2][n-6] + + fxf.xfm[3][n-6] ); + + if (n == 11) /* scale */ + return(fxf.sca); + + if (n < 15) /* origin */ + return(fxf.xfm[3][n-12]); + + if (n < 18) /* i unit vector */ + return(fxf.xfm[0][n-15] / fxf.sca); + + if (n < 21) /* j unit vector */ + return(fxf.xfm[1][n-15] / fxf.sca); + + if (n < 24) /* k unit vector */ + return(fxf.xfm[2][n-21] / fxf.sca); }
