--- ray/src/rt/func.c 1990/12/12 21:57:50 1.11 +++ ray/src/rt/func.c 1991/01/12 18:01:19 1.13 @@ -1,4 +1,4 @@ -/* Copyright (c) 1986 Regents of the University of California */ +/* Copyright (c) 1991 Regents of the University of California */ #ifndef lint static char SCCSid[] = "$SunId$ LBL"; @@ -15,27 +15,29 @@ static char SCCSid[] = "$SunId$ LBL"; #include "otypes.h" -typedef struct { - double xfm[4][4]; /* transform matrix */ - double sca; /* scalefactor */ -} XF; +XF unitxf = { /* identity transform */ + 1.0, 0.0, 0.0, 0.0, + 0.0, 1.0, 0.0, 0.0, + 0.0, 0.0, 1.0, 0.0, + 0.0, 0.0, 0.0, 1.0, + 1.0 +}; -static OBJREC *fobj; /* current function object */ -static RAY *fray; /* current function ray */ -static XF fxf; /* current transformation */ +XF funcxf; /* current transformation */ +static OBJREC *fobj = NULL; /* current function object */ +static RAY *fray = NULL; /* current function ray */ -setmap(m, r, xfm, sca) /* set channels for function call */ +setmap(m, r, bx) /* set channels for function call */ OBJREC *m; register RAY *r; -double xfm[4][4]; -double sca; +XF *bx; { extern double l_noise3(), l_noise3a(), l_noise3b(), l_noise3c(); extern double l_hermite(), l_fnoise3(), l_arg(); extern long eclock; static char *initfile = "rayinit.cal"; - + /* initialize if first call */ if (initfile != NULL) { loadfunc(initfile); scompile("Dx=$1;Dy=$2;Dz=$3;", NULL, 0); @@ -57,8 +59,14 @@ double sca; } fobj = m; fray = r; - fxf.sca = r->robs * sca; - multmat4(fxf.xfm, r->robx, xfm); + if (r->rox != NULL) + if (bx != &unitxf) { + funcxf.sca = r->rox->b.sca * bx->sca; + multmat4(funcxf.xfm, r->rox->b.xfm, bx->xfm); + } else + copystruct(&funcxf, &r->rox->b); + else + copystruct(&funcxf, bx); eclock++; /* notify expression evaluator */ } @@ -76,16 +84,20 @@ RAY *r; for (n = m->oargs.nsargs, sa = m->oargs.sarg; n > 0 && **sa != '-'; n--, sa++) ; - mxf = (XF *)malloc(sizeof(XF)); - if (mxf == NULL) - goto memerr; - if (invxf(mxf->xfm, &mxf->sca, n, sa) != n) - objerror(m, USER, "bad transform"); - if (mxf->sca < 0.0) - mxf->sca = -mxf->sca; + if (n == 0) + mxf = &unitxf; + else { + mxf = (XF *)malloc(sizeof(XF)); + if (mxf == NULL) + goto memerr; + if (invxf(mxf, n, sa) != n) + objerror(m, USER, "bad transform"); + if (mxf->sca < 0.0) + mxf->sca = -mxf->sca; + } m->os = (char *)mxf; } - setmap(m, r, mxf->xfm, mxf->sca); + setmap(m, r, mxf); return; memerr: error(SYSTEM, "out of memory in setfunc"); @@ -137,50 +149,50 @@ register int n; if (n < 3) /* ray direction */ - return( ( fray->rdir[0]*fxf.xfm[0][n] + - fray->rdir[1]*fxf.xfm[1][n] + - fray->rdir[2]*fxf.xfm[2][n] ) - / fxf.sca ); + return( ( fray->rdir[0]*funcxf.xfm[0][n] + + fray->rdir[1]*funcxf.xfm[1][n] + + fray->rdir[2]*funcxf.xfm[2][n] ) + / funcxf.sca ); if (n < 6) /* surface normal */ - return( ( fray->ron[0]*fxf.xfm[0][n-3] + - fray->ron[1]*fxf.xfm[1][n-3] + - fray->ron[2]*fxf.xfm[2][n-3] ) - / fxf.sca ); + return( ( fray->ron[0]*funcxf.xfm[0][n-3] + + fray->ron[1]*funcxf.xfm[1][n-3] + + fray->ron[2]*funcxf.xfm[2][n-3] ) + / funcxf.sca ); if (n < 9) /* intersection */ - return( fray->rop[0]*fxf.xfm[0][n-6] + - fray->rop[1]*fxf.xfm[1][n-6] + - fray->rop[2]*fxf.xfm[2][n-6] + - fxf.xfm[3][n-6] ); + return( fray->rop[0]*funcxf.xfm[0][n-6] + + fray->rop[1]*funcxf.xfm[1][n-6] + + fray->rop[2]*funcxf.xfm[2][n-6] + + funcxf.xfm[3][n-6] ); if (n == 9) { /* distance */ sum = fray->rot; for (r = fray->parent; r != NULL; r = r->parent) sum += r->rot; - return(sum * fxf.sca); + return(sum * funcxf.sca); } if (n == 10) /* dot product */ return(fray->rod); if (n == 11) /* scale */ - return(fxf.sca); + return(funcxf.sca); if (n < 15) /* origin */ - return(fxf.xfm[3][n-12]); + return(funcxf.xfm[3][n-12]); if (n < 18) /* i unit vector */ - return(fxf.xfm[0][n-15] / fxf.sca); + return(funcxf.xfm[0][n-15] / funcxf.sca); if (n < 21) /* j unit vector */ - return(fxf.xfm[1][n-15] / fxf.sca); + return(funcxf.xfm[1][n-15] / funcxf.sca); if (n < 24) /* k unit vector */ - return(fxf.xfm[2][n-21] / fxf.sca); + return(funcxf.xfm[2][n-21] / funcxf.sca); badchan: error(USER, "illegal channel number"); }
