Eliminated copystruct() macro, which is unnecessary in ANSI. Reduced ambiguity warnings for nested if/if/else clauses.
Fixed bug in mesh (u,v) local coordinate indexing and old bug in I[xyz] value
Changes and check-in for 3.5 release Includes new source files and modifications not recorded for many years See ray/doc/notes/ReleaseNotes for notes between 3.1 and 3.5 release
added raydist() function
added fprism
minor optimization in use of REFVNAME (macro -> char constant)
fixed bug to catch illegal calls to chanvalue() and l_arg()
added Ts variable for single ray (or shadow ray) distance
minor improvements to getfunc()
minor improvement in error message
minor cosmetic surgery
changed location of context mark for locals (again!)
added special case for "." meaning no function file
added contexts to function files
changed position of initfile loading to catch conflicts
put in test to guarantee range of dot product as [-1,1]
added return value to setfunc() and setmap(): returns 1 if setting was made, 0 if function already set
reinstated repeat call test in setmap()
changed initialization for noise functions
changed funset() parameters
fixed incorrect test for repeat call added identity transform special case
changed handling of matrix transformations with new MAT4 & XF types dynamic allocation of ray transformations with newrayxf() added missing light source vector transformation to m_brdf.c
deleted unused #undef statement
changed ordering in chanvalue()
added line numbers to error reporting in cal functions
added direct access to coordinate transformation
Eliminated need to initialize matrix for call to xf() and invxf()
Changed getpath to check permissions
minor change to loop
changed order of parameters to setmap() for consistency with xfm()
portability fixes
